My phonograph is humming
Hi I just bought a second hand phonograph. the guy I bought it from let me listen to a few records and they all sounded great (so I know the phonograph works fine).
My amp does not have a PHONO in, so I bought a simple pre-amp. The problem is that my amp also doesn't have an EARTH or GROUND connection, and I don't know what I can connect the phonograph's earth wire to. Folllowing an advice from another technical support website, I tried to connect it to the amp's body - it did reduce the humming but not enough - it sounds much worse than when I bought it.
Help! :)
  • 1 more comment
  • galzohar5 Jan 16, 2009
    Connecting the chassis of the player to the chassis of the amp reduces the humming significantly but it is still there and very noticeable. The record player is CEC BD-3200.
  • fluffhead76
    fluffhead76 Feb 18, 2012
    I have the same exact problem!!!!
More flexibility wanted in home theatre.
I have installed a new Denon AVR689 receiver in my home media center. I have more old analog components than can be easily connected, 2 tape decks, Dolby NR, DBX NR, turntable, etc. There is actually no "phono" connection on the Denon. Looks like a preamp is in order for the turntable.
If I am going to add a preamp for the turntable anyway, would it work to add a regular component preamp to the system that would would handle several more analog componets at the same tiem? Can I run rca connectors from the external preamp to a line input on the receiver, then select that input as the path to additional components connected to the separate preamp?
If this will not work, how can I add more components to my system?
Thanks,
Vann
Posted on Apr 19, 2009
  • 10,594 Answers
There is no need of earth wire between units if audio connecting cables are OK. Any how, connect a wire between PreAmp and Amplifier as earth or ground. If you connect earth wire between amplifier and phono this will cause hummm noise.
Please aslo check and make sure that audio connecting cables are OK and plugged properly.
Posted on Jan 16, 2009
    Scholar:
  • 160 Answers
Problem with the ic on the main board of the amplifier that needs to be replaced
    Brigadier General:
  • 8,619 Answers
Hi!
A ground loop typically adds a loud low-frequency hum or buzz as soon as you plug in any of various audio or video components, including subwoofers, cable-TV outboard boxes, satellite-TV feeds, TV displays, amplifiers, A/V receivers or turntables. The buzz/hum is a byproduct of the multiple power supply cables and a ground voltage differential within your system and its network of interconnecting cables.
  • Rylee Smith
    Rylee Smith Jan 16, 2009
    You get your system up and running and hear an audible buzz or hum, the first culprit to look at is either the powered subwoofer or your cable-TV or satellite-box feed at the entry point to your system.
  • First, the subwoofer: unplug the coaxial cable that connects to your powered subwoofer to see if the ground-loop hum disappears. If it does, it's likely coming in through your cable/satellite TV feed.
  • Reconnect your subwoofer's coaxial cable from the subwoofer input to your receiver's subwoofer output and disconnect the cable-TV feed (or satellite feed) from your outboard set-top cable box or satellite tuner. Be sure and disconnect the cable before any splitters. Now see if the hum/buzz from your subwoofer stops.
  • Rylee Smith
    And if that doesn't work then you need a phono preamp. You aren't hearing just 60 cycle hum, you're getting all the noise and junk from the low output of the table, plus there's a huge impedence mismatch.
    Ask for clarifications
      Top Expert:
    • Audio Player... Master
    • 77,499 Answers
    All u need to do is run a wire from the record player chassis to the chassis of the amp, any screw will do as long as the 2 chassis are hooked togeather. The hum is AC current hum.
    • yadayada
      yadayada Jan 16, 2009
      all record players have some hum (a common complaint in favor of CD players), the next thing to do is remove the cartridge and clean the contacts, this is another source of hum, u can also install a surge protector on the power supply ( just like the one on any PC), this cleans up and filters the power and will also reduce hum, I have had ever issue with hum that there is and one or more of these fixes will work.
    Phono input only plays one speaker and receiver shuts down after playing record for a few minutes
    are you using a phonograph with a built-in preamp? If so, then you need to hook it up to a different input. Phono input is only for non-amplifier phonographs, otherwise you will over-drive the amp.
    Oct 10, 2015 | Sherwood RX-4109 Stereo Receiver Black
    When the dryer switch is turned on, it makes a humming sound for a few seconds and then stops but the dryer does not come on. What is the problem?
    The slipper pads are most likely warn out and the motor is tripping on overload. Was it making a rubbing noise when the drum is rotating, try turning the drum by hand and listen. If you have a drier that will run inverted turn it over and try.
    Apr 24, 2015 | Dryers
    Do you have to pull the gas tank out to check e\for fuel pump operatons
    no remove fuel cap put your ear close to open filler neck have some one turn on key you should hear a humming sound if not bump key then listen again it will only hum for a few seconds
    Jan 21, 2013 | Cars & Trucks
    Where can i obtain a realistic 32-1200 manual for free? or what does cera and mag on the back of the mixer mean?
    In reference to the question -
    " what does cera and mag on the back of the mixer mean? "
    these jacks are for the input of phonograph record cartridge signals.
    Phonograph cartridges are of two types -
    1. "Cera"mic (ceramic) cartridges generate their signal using a ceramic crystal which provides almost 1/2 a volt of current.
    2. "Mag"netic (magnetic) cartridges generate a more accurate signal than a ceramic cartridge but the magnetic cartridge generates its signal using a moving-magnet mechanism (rather than a ceramic crystal) and the magnetic cartridge generates much less current than a ceramic cartridge, so its signal needs a lot more amplification than a ceramic crystal's output. So the two jacks on the back of the mixer provide different levels of amplification for the phono cartridges, less amplification for a ceramic cartridge and more amplification for a magnetic cartridge.
    Since few people play phonograph records any more it is understandable that the public has little knowledge of the differences between ceramic and magnetic cartridges. But each have their own benefits and usually ceramic cartridges are cheaper than magnetic cartridges simply because it takes a lot more sophisticated manufacturing technology to make a magnetic cartridge, though magnetics are usually preferred over ceramics because of their more accurate generation of a signal from the wiggling groove in a phonograph record. But for those who can hear, the complete sound signal from a phonograph record is much preferred over the dead and dry sampled sound from a digital CD. And the old 1/4" reel-to-reel tape recordings are the highest sound quality of all because they are direct copies of the original magnetic tape masters with no digitizing at all. The fullness of their sound is astounding compared to any digitized signal..
    A mag input is down at the mic level.
    A ceramic input is almost up at the line level.
    Jul 25, 2011 | Audio Players & Recorders
    Engine won't crank. seems like no fuel getting to engine. Had the dealer replace the fuel relay worked for several days... replace it again myself....but still won't crank.
    SOUND LIKE FUEL PUMP FAILURE FUEL FILTER LOCATED ON THE FUEL PUMP ASSEMBLY REPLACE THE SOCK FILTER IT COULD BE PLUGGED IF FUEL FILTER OKAY OR CANT BE REPLACED YOU HAVE TO REPLACE WHOLE FUEL PUMP ASSEMBLY WITH FUEL FILTER TO REMOVE FUEL PUMP YOU NEED TO REMOVE SECOND ROW LEFT HAND SEAT, REMOVE THIRD ROW SEAT,REMOVE SECOND AND THIRD ROW SEAT BELT BUCKLES MOUNTED TO THE FLOOR,REMOVE LEFT HAND CENTER PILLAR,REMOVE LEFT HAND REAR TRIM PANEL, REMOVE LEFT HAND REAR SIDE DOOR KICK PLATE AND WEATHER STRIPPING, REMOVE SECOND ROW REAR CENTER CONSOLE AND BASE IF EQUIPPED, REMOVE THE INSPECTION HOLE COVER UNDER CARPET BY TURNING RETAINER 90 DEGREES REMOVE ELECTRICAL CONNECTORS, REMOVE EVAP HOSE.REMOVE SUPPLY HOSE, REMOVE LOCK RING USING SPECIAL TOOL J - 46214, REMOVE FUEL LEVEL SENSOR, REMOVE FUEL FILTER AND THE FUEL PUMP ASSEMBLY.BESURE DEPRESSURIZE FUEL SYSTEM BEFORE DISCONNECTING ANY FUEL LINES AT THR FUEL TANK.
    Jul 16, 2011 | 2004 Nissan Armada
    Pump just hums but wont start
    Sounds like its frozen and causing a very heavy load on your circuit. If the motor gets hot within seconds, its shot and needs replacing. Have you attempted to turn the motor over by hand ?
    Jun 22, 2009 | AO Smith SQ1202 Pool Pump Motor
    Trouble recording records
    When recording from a phonograph, I use the following items.
    Depending on the phonograph whether or not it's MC or MM makes a difference in sound although most can't tell the difference. Also, you need to know if your phonograph requires a pre-pre amp or if that pre-pre amp is built in and the line coming out is at line level. The Rolls item is a pre-pre amp unit which takes to older phonographs signal level to that of input levels which allow the phonograph to be connected to any aux line in.
    On the back of the computer, you can plug the RCA jacks from the phonograph into the adapter and directly into your computer via the MIC (usually pink) input. Most of the time this is sufficient. If the volume is too loud, or sounds horrible, chances are you have a pre-pre amp and you then plug it into the line in (usually blue)
    First I would connect the RCA's from the phonograph to the adapter and plug it into the mic and see how the sound is.
    Keep in mind that you do not use the ROLLs unit when connecting this way. If it's too loud or distorted, plug it into the line in.
    For recording, you can download Audacity which is free and a wonderful editing program.
    Nov 26, 2008 | Televison & Video
    Webcam is slow
    have you plugged it into a front usb port?
    try plugging it into a back one. it worked for me :D
    hope it works our for you!
    Feb 14, 2008 | Microsoft LifeCam VX-3000 Web Camera
    1,474 people viewed this question
     Grubhead
    Grubhead
