Question about Canon BJC 250 InkJet Printer
Printout is pale and almost ilegible
I have changed colour and black ink cartridges, done full maintenance etc. Printer is still printing out documents in very pale and distorted form which is barely legible. Printer is only two years old and has never given problems until now. Is not used frequently. Would be so very grateful for any help or advise as I urgently need to print an important document. Am using windows XP. Please be so kind and respond to my request for help at your earliest convenience.
  • 2 more comments
  • Renee Doyle Jun 17, 2007
    The ink cartridges are totally new, but thank you for your kind response. Will keep trying, although there does't appear to be much else I can do. Would using a driver for Canon 250 be any help? I'm afraid I am totally untechnical, so excuse my lack of the correct terminology here.
    Thanks again and can you please explain what downloading the correct driver may achieve and how do I apply it once downloaded? I am not really sure what the purpose is for downloading a driver! What a novice!
    Hi, if nothing works, would you be so kind and advise me as to which printer would be suitable for a home user who mainly uses it for correspondence such as word and excel documents, with the odd photo prints here and there. This Canon has unfortunately always been painfully slow, but perhaps I made a bad choice model wise.
    Thank you so much. Have tried all..no luck. Getting new one am!
    Genius:
  • 2,985 Answers
I wonder if you have got it set to draft mode? Check it out. Failing that go to www.fixyourownprinter.com
Posted on Jun 17, 2007
  • 1 more comment
  • john ash
    john ash Jun 17, 2007
    Infrequent use is the curse of printers.
    They should be used at once a week to prevent dry out problems.
    If the cartridges are of the Head-in tank type - with the contacts on the side.
    Try standing them in a saucer with a dampened tissue underneath to draw out the ink.
  • john ash
    Only the correct driver for your model will do
    May then its time to goe for a new one.
  • john ash
    You said would using the driver for a Canon 250 help. And I said only the correct driver will do.
    I presume you do the have corrected driver for you model?
    If you want to try this as a last ditch thing. do the following.
    Go to
    Start/printers and faxes/install new printer/when you are asked to provide the Cd or select from list. take select from list.
    Run down the makers list to Canon then move across to select the exact diver for your printer- click OK
    Now right click on this new driver and say make default printer.
    Try a print job.
    If all else fails - a nice new printer that you will print from at least once a week in full colour to keep it sweet is the next thing.
SOURCE:
Printer will only print purple
on a colour printer, black is mixed with the other colours. Try printing a black and withe photo and you always get a colour cast. If your black cartridge is empty or the nozzles are blocked, you get bad colour and fussy prints.
test all nozzles, like is explained in the manual.
Check, if you know how to do, if nothing fell in the printer, that is now on the print head. Sometimes just dust or paper scraps are picked up by the printhead, making it difficult for the printer to print a normal page.
Apr 15, 2014 | Epson PX730WD Stylus Photo
All the colours are working well, but the black ink is very very pale. I have done a deep clean in the print head - nothing - can you help ? I have a Lexmark Interpret S 405. thankyou, Vicki...
Try to check the ink level for the black cartridge. Press Setup > Maintenance > Ink Levels. If black ink is substantial for printing, try to reseat the cartridge. It could be that it's not seated properly in the carrier.
Also, make sure your printer is updated. You can download and install the update by visiting the Lexmark website at http://bit.ly/s405fw.
May 21, 2011 | Lexmark X1150 All-In-One InkJet Printer
My ink cartridge manager tells me that both the black and colour cartridges are full, yet documents will not print in black at all and even those in full colour only print in light blue
apply the following; after you done pressing into the PRINT button click first the MAINTENANCE button then click again the PRINT TEST PAGE button, then kindly and patiently do the procedures over and over again until the test print paper will resume to its normal color and functions..in that way the black and color cartridges will be recognize in that kind of procedures..in that way your problem has been solved already...
Mar 09, 2011 | HP PSC 1315 All-in-One Printer...
The ink level indicator is more than 1/2 full yet the print quality is pale. I cleaned printer heads several times, alligned etc., but still pale print quality. I changed ink cartridges, printed about 40...
try to change the properties of the printer. Usually it has a configuration to increase the printing quality.
And also, look for the configuration for ink drying wait time. Change it to long.
If you dont have any problems with your cartridge. then i think you should need some adjustments from your configuration.
well, i hope this works.. :)
Thank you.
Aug 08, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
'empty' ink cartridges - green prints!
just fill up all the catridge bcoz in colour printer anyone of them is not fill up the printout not coming properly , after filling the catridge just check
May 26, 2009 | Epson Stylus R265 InkJet Photo Printer
Replaced cartridges
keep cleaning untill it starts to print clearly, you may reuse the same paper for that purpose, if you don't see any progress after 10 cleans, consider getting lasser printers, they are immune to print head drying and save alot of money on ink replacements. go with brother color or black and white series. I switched and don't have problems anymore
May 20, 2009 | Canon i450 - Printer - color - ink-jet -...
Hi, Just replaced colour and black ink cartidges ( both new not refills)in our pixma ip1500. We have done all the maintenance but it seems like no ink is coming through. Every print is very pale, and...
Do not throw it away. It has taken you so much cost ok?. Print blank can be caused by:
  • Purge unit is faulty cannot **** ink from ink cartridge
  • Print head is faulty
  • Logic board is faulty
In some cases short circuitry in print head can cause this problem. Please be careful of this. Replacing print head can damage new print head. I suggest you to bring the printer to nearest service center.
I hope this will be useful for you and please your rating
Regards,
Nov 09, 2008 | Canon Office Equipment & Supplies
I have a epson stylus printer C65 series. I ran out of black ink so i changed the ink cartridge and it will only print colour not black now.
I have an Epson stylus 6000 series, second hand but was working just fine. I changed the ink cartridges and now the color won't print. Utilities shows all cartridges full, but only black and pale green-blue print. While it was printing color it was drinking the ink, but that's another story.
Yvonne
Aug 09, 2008 | Office Equipment & Supplies
White lines in print--looks like pinstripes
I asked the technician at Staples what he thought and he thought it was the ink cartridge. since I was using 3in1 cartridges and it was expensive to buy two; (1) Black with pale magenta and blue plus (2)red blue and yellow,we bought a new printer that uses one colour only cartidges so we can replace one colour at a time and also use a pale blue and pale magenta to get better reproductions. for a little more than double the price we bought an Hp printer Photosmart C7280 on sale with single cartridges. It will pay off, They are a fraction of the cost of 3in1 colours.
May 22, 2008 | HP PSC 1350 All-In-One Thermal Printer
Printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Dec 28, 2006 | Brother MFC 210C All-In-One InkJet Printer
Canon BJC 250 InkJet Printer Logo
107 people viewed this question
Clive
Clive
old marine
old marine
