Question about OKIFAX 5780 All-In-One Led Printer
Printing (text suddenly blurry bold after closing lid).
So the paper got stuck. Opened and closed the lid.
Then text was blurry bold (like to much ink was used)
Opened and closed lid again and text was fixed for no reason but the glass or something had ink on it because the paper had a black shine (with one thick line more black) over the whole page.
I have an OKI 5700 laserprinter.
Please help.
Thanks
  • 320 Answers
Open the toner access door remove the toner, slowly lower the tone access door and ensure that the top roller (charge roller) is lowering straight. the roller in the bottom of the cavity (the transfer roller) push down on this to ensure that it has spring tension. if the top one is level and the bottom one has tension then you'll need to change the high voltage power supply.
Posted on Mar 06, 2010
Please reposition orignal bizhub 250
take everything out of the feeder and off the glass open and close the lid and make sure that the sensor that tells the machine the lid has been opened is not stuck if that dosnt work reboot the machine
Jul 04, 2014 | Konica Minolta PRINTING - Bizhub-250...
Printer only prints blank pages
I would suspect that the you didn't get the drum back in properly. There are contacts on the drum casing that need to make contact with the base of the printer. It's possible that either it's not seated properly or that some toner is lodged over the contact preventing a good electrical connection. Try removing the drum again and carefully reinsert.
Jun 16, 2017 | United Stationers Oki B2200 Laser Printer...
Opened the drawer while it was running now the drawer will not close
Turn off the mains power and back on and see if there is any change.
The drawer lid is stuck in close position when you opened the drawer. Try to select another program on the panel and see if it clears the stuck lid.
Jan 18, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Paper feed problem
Hi
This is happening due to paper jam on the gear or roller of the paper feed mechanism. Check for any small bits of paper or sheet stuck. To check lift up the top plastic lid of the Canon printer. Check to see if a jammed sheet of paper is visible inside the printer. Remove the cartridges and check for any small paper bits stuck under the print head. Pull the paper out gently through the bottom end of the printer(if any). Close the top plastic lid. Power On the printer and check.
If it doesn't work then power off the printer, wait 10 seconds and power it back on. try once again to print. If it doesn't work then Open the Canon printer software. Click "Options" and then select the "Clean Print Heads" button.
Daniel Scott
Jun 14, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
Hp laser jet 1320 stop printing
Try unplugging the power cord and plugging it back in. Check to make sure that there are no paper jams or foreign objects stuck in the rollers. Reseat the toner and make sure the lid is firmly closed.
Jun 19, 2009 | HP Laser Jet 1320 Printer
Print access door will not close
Hi..
See if something is stopping it to close...or call kodak:585-781-6231
Nov 25, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Lexmark x3470
Hi, can you help me? This printer1.gif was working fine for about 4 months and then in wont print anything anoymore. All it says to do is close the lid, but the dam thing isnt open. I tried opening and closing, removing ink4.gif cartrige and even slamming it down but still say door opened?
Feb 24, 2008 | Lexmark X3470 All-In-One InkJet Printer
HP 7660 "Print Cartridge Cradle is Stuck" Message
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
Dec 18, 2007 | HP Photosmart 7660v InkJet Printer
Blurred bands in prints
Try changing ink cartridge. Print only "grayscale" and if that happens, you need a black cartridge changed. If, not color
Mar 16, 2017 | HP DeskJet 460WF Mobile Color Printer
OKIFAX 5780 All-In-One Led Printer Logo
140 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
