Question about Sony BRAVIA KLV-40U100M 40 in. HD-Ready LCD Television
Sony bravia 40" hd lcd gets picture but no sound from cable box
While I get a beautiful picture from the hdmi connection, I get no sound. I'm using an hd cable box from time warner. I purchased the hdmi cable to simplify connections and want to stay away from the three wire component cables
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Few HDMI units requires Audio input from RCA pins as HDMI cable carry video data only. Please hook red-white audio cable between two units.
    Problem Solver:
  • 5 Answers
You will have to go into the settings of the hd box by pressing the settings button twice and then scroll down to "audio digital out". chances are that it is set to Dolby Digital. If you right arrow over you can then set it to HDMI. this should bring your volume back. Hope this helps.
Posted on Feb 10, 2009
I have a sony bravia 40 inch hd tv. i also have a comcast hd box that always worked on the tv through the hdmi. One day i was having trouble with cable box so i unpluged it to reset it. now my tv will...
Your PS3 working doesn't mean a thing for the cable unless you are using that cable for your PS3. I would bet you have a bad HDMI. They are pretty sensitive to being bent. Try replacing that first. The other thing to check is to first make sure you have the proper input selected on the TV for where you have the HDMI plugged into on your TV.
Aug 25, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Feb 05, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
On Sony Bravia KDL-S40A12U screen occasionally turns black for a couple of seconds. Only happens on the HDMI channel. Sound still works, but no picture?
Possibly source issue(Box/Satt). Some HD boxes do not have very good HDMI processors or the actual program source feed may be faulty. HD sources are still not 100% efficient
Dec 03, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Ps3 hdmi cable problem
I have a sony bravia 42 LCD TV and cannot get it to take HD from my Virgin + box. We have put an HDMI cable as suggested which works with the PS3 but not with our box.
Nov 17, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a sony bravia kdl-26m4000
Cable boxes have notoriously flaky HDMI outputs. I have seen No pic and no sound with their HDMI outputs as well as a host of other problems. You can try getting the cable box replaced; unfortunately I have seen multiple cable box replacements not fix the problem. The best solution is to leave the component cables connected; you're not losing hardly any resolution/picture quality by using the component instead of the HDMI. Solution #2: switch to a satellite provider. I rarely see HDMI problems with satellite boxes
May 28, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Sony Bravia 40"
Do you have a cable or satellite box connected to the tv?
Dec 31, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
No Digital Signal to TV
make sure you have Tv on that particular HDMI input .I believe video 6 or 7 .if you do check menu make sure that input is not blocked. or you might want to try the component outputs of cable box and connect that to a component input on tv to see if that is working,,i have seen these tv HDMI input board bad..lets hoe this is not the case..
Dec 16, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony kdl-40s2000
Probably need a software upgrade. Contact Sony for that information. This would be a common fix in most sistuations when using HDMI.
Dec 30, 2006 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KLV-40U100M 40 in. HD-Ready LCD Television Logo
1,087 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
