Question about Magic Chef MCBR170 Compact Refrigerator
Not cooling I have a model MCBR170W, brand new, It worked fine for two weeks then quit cooling. Unable to tell if condensor is working but I do not hear anything. What should I check for
I pulled the plug once again from the electrical outlet and replugged back in after an hour. The unit then worked.
Posted on Jan 16, 2009
Frigidaire model number FRS6R5EMB8 Not cooling
Feel the top of the compressor and tell me what you feel
Oct 09, 2015 | Frigidaire Refrigerators
I have a Dometic rm3801 it was working fine on 120v and abruptly quit cooling all lights come on compressor and cooling fan don't run. I aam unable to try it on lpg. Fridge is level and cooling fins are...
If the rear cooling coils are warm and the refrigerator is level and there is still no cooling, then you more then likely will need to replace your cooling unit. It takes a couple of hours to do but you dont need any specialized tools. Check out ArctiCold Refrigeration We keep it cold Your unit can be found on ebay at under half the price of a new fridge. Link Below 11d6ec30-092e-426d-853a-24315c5d73c1.jpg Dometic RM3801 Brand New Manufactured Cooling Units LIFETIME WARRANTY...
Sep 25, 2013 | Dometic Refrigerators
My dehumidiyer fan runs, condensor seems to work but the coils do not get cold so thus no condensation. what can i do to get my humidiyer working?
typical for most brands of dehumidifiers.after 2-3 years use the refrigerant/freon leaks out and they wont cool,you can have it recharged,but quite expensive as i charge between $50.00 to $75.00 to do this
Aug 07, 2011 | Whirlpool AD40DSR Dehumidifier
I had an ice build up on the freezer and it was working. it melted and is not working at all now. It is less than a year old. the model is mcbr170w
i looked up the model number but couldn't find your machine,anyway don't touch it,call the factory and tell them what's happening,if you touch it or have someone else touch it you can void your warranty because it's under one year old
Oct 19, 2010 | Refrigerators
Need to check the condensor fan. If the fan quit working this could lock out the unit so the compressor does not over heat.
Nov 15, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Wiring Question York Diamond 90 Condensor Unit - New Capacitor
the wire diagram should tell you how. it all depends where wires lead to. be very carefull, capacitors can be dangerous. brown usaully go to fan black usaully goes to common red usaully goes to herm or compressor. it all depends where wires come from
Aug 27, 2009 | Heating & Cooling
The refrigeration works fine for a few months and at a random interval will stop working. The ice melts and everything else gets warm. When unplugged then plugged back in, it works fine.
What is probably happening is you have ice buildup on your condensor(usaully located behind a panel inside freezer compartment) what happens is ice buildup over time will cause the condensor to stop cooling efficiently.One solution is to unplug frig and let ice melt off condensor, which you should do anyway unless it is a frost free model ,in which case you have a defrost problem. If this is the problem, you should check out the solution in one of my earlier threads posted 9/23 Hope this helps.
Jul 25, 2009 | Refrigerators
The refrigerator portion has quit cooling.
I have the same problem and have found that if you take the panel off inside the refrigerator and with a blow dryer defrost it. It should work for a few weeks. I have been doing this once a month since March and I hope to found out how to fix it also.
May 17, 2009 | Samsung 26 Cu. Ft. Side-by-Side...
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Sanyo sr-1013w not cooling
sounds like it has a refrigerant leak somewhere in the unit.
Feb 20, 2009 | Sanyo BC-1206 Commercial Beverage...
Magic Chef MCBR170 Compact Refrigerator Logo
352 people viewed this question
Top Magic Chef Refrigerators Experts
Level 1 Expert
John Tripp
John Tripp
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
