Question about Linksys Wireless-G WRT54G Router
Open ports how do you change your ports on linsky wrt54g-v8
  • fabe68 Jan 15, 2009
    screen was to small and I could not keep up when you were talking. if you could submit in writing I would appreciate it.
  • Stephen Horan
    Stephen Horan May 11, 2010
    Change ports as in prot forwarding or port triggering?
  • 54 Answers
Here is a solution to your problem.
Posted on Jan 15, 2009
  • Stephen Horan
    Stephen Horan Jan 15, 2009
    There should a port forwarding selection on your router. In that option you basically select the port that wish to use, then select the IP address that you want the port to be assigned to. Example:
    you ip address is 192.168.1.2. You are hosting a website from your house and you want the outside world to see it but your setting behind a router. http:// uses the port 80. In that case you would take port 80 and forward it to your computer 192.168.1.2 that way any request that come into your router asking to see port 80 will go to your computer and no where else on the network, meaning your leaving the port open. This applys the same for video game applications, FTPS, video game server and so on.
Wireless 2.4ghz router for wifi
Wrt54g can be used as either a wireless router or access point. I am not familiar with your broadband service, but if it has a data port just connect it to Internet port.
Nov 02, 2017 | Linksys Wireless-g 2.4 Ghz Broadband...
Can't access linskys router setting page.
You can try resetting your router.
Do not connect computer or modem to the router. Press and hold the reset button for 30 seconds. Release the reset button and wait for 30 seconds. Power cycle the router.
Now connect the computer to the router and try to open the setup page using 192.168.1.1.
Make sure that there is no static IP address on your computer.
See How to reset and reconfigure Linksys router
Apr 10, 2012 | Linksys Wireless-G WRT54G Router
Hello i need to open some ports in order for my ps3 will function properly..I need the Tcp ports open #'s (80)(443)(5223)(10070)(10080) and also need the UDP ports open #'s (3478)(3479)(3658)(10070) model...
LINKSYS ::::
NAT STRICT
Step 1 : Connect Router - Computer
Step 2 : Open Router Setup by typing http ://192.168.1.1
Step 3 : Click Applications and Gaming
Step 4 : Click DMZ
Step 5 : Select Enable and Give the IP Address of the XBOX/PS3/Wii in it
Step 6 : Click Save settings
Step 7 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 8 : Plug the power cord back to the router and wait till the lights are Solid
Step 9 : Turn on the Xbox/PS3/Wii
Step 10 : Test the Connection
Else ...
Under application and gaming you can find port range forward
There you can open the ports one by one
And give the IP Address of the PS3 for all the ports opened
Dec 21, 2010 | Linksys Wireless-G WRT54G Router
Im tryig to piggyback my wrt54g router to another part of the house. I have a cable coming from my linksys e1000 n router which is my main router. When i plug the cable into the 54g i can access the router...
What is the IP address of the E1000 router ?
If the IP address of E1000 router is 192.168.1.1, Then change the IP address of WRT54G router to 192.168.1.2. Connect the Ethernet cable from the Ethernet port of E1000 router to the Ethernet port of WRT54G router ( port 1 of E1000 to port 1 of WRT54g). Disable the DHCP server.
You can do it in a different way also.
If the IP address of E1000 is 192.168.1.1. then change the IP address of the WRT54g to 192.168.2.1. Do not disable the DHCP server of the WRT54G. Connect the E1000 to the Internet port of WRT54G.
Click Here to know more about router and network
Sep 03, 2010 | Linksys Wireless-G WRT54G Router
Lost my linskys wireless-g wrt54gs cd installer
you can setup the router manually without the CD.
1> plug a network cable into the router, and your computer
2> type the following into your web browser http://192.168.1.1
3> enter your settings for your ISP
4> choose your wireless settings (it is recomended to setup some security on your network so people can't have access to your network without authorization)
Oct 27, 2009 | Linksys Wireless-G WRT54G Router
How do you change the firewall on my Linksys WRT54G so i can play PS3 online
you'll need to open ports, go to portforward.com this site will show you how to open ports.
Sep 06, 2009 | Linksys Wireless-G WRT54G Router
Using my linskys router
If you have internet through a cellphone, it doesn't sound like the router can help you-- it's meant to split up a wired broadband connection like cable internet or DSL internet from your home phone lines. the router certainly was built to let you share a broadbank net connection-- you didnt mention if you have one or not-- not a cellphone connection... you might have to spring for another card if you need to stick with just the cellphone connection.
Jan 30, 2009 | Linksys Wireless-G WRT54G Router
Login on to linsky
Under this condition you should connect the linksys router physically by LAN cable and that try to get connected with and reconfigure it properly as per your requirement. If still unable to solve the problem than kindly reset the unit to factory default by pressing the reset button.and that try to get connected with and reconfigure it properly as per your requirement.
Dec 23, 2008 | Linksys Wireless-G Broadband Router
Reconnecting linsky router
make sure that DHCP should be enabled or you can put IP address mannuly. 69 port for DNS should be open otherwise it will not get updated from vonage.
Deepak RG Sharma
Dec 02, 2007 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
115 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
