Question about Toshiba Satellite P35-S609: Pentium 4-3.2 GHZ, 512MB RAM, 80GB Hard Drive, DVD-RW/CD-RW, 56K Modem, Network ... (SATELLITEP35S609PENTIUM) PC Notebook
Memory chip set.
Shortly after solving an unrelated problem of crashing, due to overheating, I was unable to boot the computer up. It was discovered that I had a bad memory chip (supposedly). I replaced the chip only to have the same problem immediately so I removed the chip. I'm currently operating with only one 512mb chip and the computer seems very slow.
My question is:
How can I determine if I've actually got a problem with the chip or whether I might have a problem with the socket?
The computer is rated for up to 2048mb, can I use a single 2048 chip or do I need to use two 1024mb chips to achieve 2048mb?
  • 54 Answers
If you have overheated the computer you may have already done your damage to the mainboard. It may be time to replace the main board if it has been overheated. The CPU could have been overheated and damaged.
Posted on Jan 15, 2009
Why does my Dell Dimension E310 w/XP Home Media. Locks up shortly after booting?
It's a memory faulty -- not a hard drive error. Move the DIMM to the other socket (or swap it with the other one if there are two). Re-test. If the error follows the DIMM, the module is bad - replace it with a new one. If the memory occurs with the other module in DIMMA, it's the socket that's bad and you'll need to replace the system board.
Aug 05, 2014 | Dell Computers & Internet
4 two tone beeps on startup
Sounds like your memory or video card is the issue. I would try the memory.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 29, 2012 | Intel D865PERL Motherboard
Meening of motherboard beep
The beeps or blinking lights tells the technician what is wrong with the computer. Most times it's a memory or video card issue. If you are getting beeps, try checking your memory.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 24, 2012 | Compaq (261671-001) Motherboard
Continuous beeping noise on boot up
Sounds like you have a bad memory chip or one of the memory slots is bad.
Remove the Power Cord, Remove the battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 02, 2012 | Computers & Internet
Acer travelmate 5735z keeps beeping
You have an issue with your memory or a memory slot more than likely.
Remove the Power Cord, Remove the Battery, Remove the cover on the bottom of the laptop that houses the memory then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 02, 2012 | Acer TravelMate 512T Notebook
Powers on then off in 2 sec
Do you see any blinking lights or hear any beeps? Beeps and Blinking lights tells the technician what is going on with the computer.
Either your video card is bad or you might have some bad memory. Does the video ever post anything on the screen when you press the power button to start the computer?
It really sounds like a memory problem.
While you have the case open check for dust around the fans and inside the computer. If dust is clogging the fans, vents and inside the computer blow it out with a can of compressed air.
This is a sign of overheating also, but I'm assuming that this is happening after your computer has been sitting around idle for a while then you turn it on and it shuts off in two seconds, so it couldn't be running hot.
Apr 02, 2012 | Dell Inspiron 519 Desktop PC Bundle
Power button does not work vostro 1700
LOL, sounds like a lemon. I would think either the memory, power cord or CMOS battery might be the cause. But since it boots each time after you go thru the process you described it has me baffled.
Maybe one of your memory chips is bad.
Mar 31, 2012 | Dell Vostro 1700 Notebook
Samsung beep codes
I bet you've got a bad memory chip.
Mar 30, 2012 | Samsung R580 PC Notebook
Crashing issues
Hi, I'm assuming that you're running vista. It's not a heating issue, otherwise the machine would shut down dead in an instant. It could be a duff ram chip, which would give the problems you are seeing. Simply burn off a Ubuntu disk, and test your Ram. If it's not that, its a software issue, and may well be Windows Ram management playing up. This is a common problem in all windows OS's. Boot up off the windows disk (if you have it) and click the 'Repair' option. Alternatively if you have an onboard restore partition, you can click F8 on booting, and 'Repair this computer'.
Jul 01, 2010 | Gateway P-6860FX Notebook
My laptop Compaq Armada 1573D dosnot see the added memory that i have put in it is with in the spec ie 64meg
Are you sure that the new memory is fully seated? Did both side clips click tight into place against the memory chip? If this is does not solve the problem move on to step 2. Remove the original memory, keeping the new memory in place. Restart the computer. If there is nothing wrong with the memory, then i should recognise the new memory w/out any problem. If you can not boot due to "no memory present" or some similar error message then the memory chip is no good or unrecogisable by your laptop. If the chip is good and the computr starts w/no problem, then reinstall the original memory chip and restart the computer. If the problem persists the two memory chips are incompatible.
Here is what crucial.com says you can install in you compaq armada.
http://www.crucial.com/store/listparts.aspx?model=Armada%201573D
Please let me know if this solves your problem, you can contact me at johnkariotisjr91741@yahoo.com
John Kariotis
Oct 28, 2009 | Compaq Armada 1573D Notebook
Computers & Internet Logo
116 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
