Question about Linksys Wireless-G WRT54G Router
Making computer safe
I have a Linksys model WRT54G and want to only allow peple with a password to use my internet for safety reasons. How do I do this
  • 54 Answers
Here is a solution to your problem
Posted on Jan 15, 2009
Forgot user id for router
Look on the back of your router for a url (numerical Web address) that is the format of 123.456.7.8 In your PC Internet browser put said url in address bar and connect to your router. Your user id should be on the first page. If you have forgotten your password contact your service provider to reset.
However your user ID and preset password should be on the sticker on the back of your router. If none of this works contact your service provider.
Sep 25, 2011 | Linksys Wireless-G WRT54G Router
How do set a password to secure my connection
I have found this website detailing the steps necessary to setting up your Linksys Wireless-G WRT54G Router with a password. You can skip steps 7 - 8, unless you know about MAC address filtering, and wish to implement it (MAC address filtering allows only the computers you specify by their MAC address to connect to your network, eliminating outside computers from connecting to it).
Here is the link --> Set Up Linksys Wireless-G WRT54G Router
Mar 05, 2011 | Linksys Wireless-G WRT54G Router
How to cennecting Aztech modem DSL600E with Router linksys WRT54G
First!
Do you have a connection in your modem?
if you do, you need to set up the linksys router in DHCP internet set up.
To have access to the linksys you need to go to:
http://192.168.1.1
The password it's admin
and the username in blank (no password)
change the internet setup to DHCP
Make sure you don't have the Same address for 192.168.1.1 or you modem cause if you do you'll need to change the ip address on the linksys router...
Apr 25, 2010 | Linksys Wireless-G WRT54G Router
How to configure Linksys WRT54G router with BSNL's C2110 modem?
The Linksys WRT54G broadband router is one of the most popular consumer routers there are. Linksys makes configuring your router easy. This article will walk you through the initial setup options for this particular model, but many of the basics we talk about here can be applied to any router setup. Setting up the router consists of four basic steps, such as Testing your Internet connection, connecting your hardware, setting up the connection and power cycling the entire network. Aside, from setup, we'll also describe some security concerns so you can make an educated decision on the administration of your home network.
Test Your Internet Connection First While this seems like something you would not need to be, make sure your Internet connection actually works. If you haven't already, plug the cable modem directly into the back of the computer and make sure you can get onto the internet. You may need to reboot the machine first.
Connect The Modem and Router to the PC Now that we have confirmed the Internet connection works, the next step is to connect the modem to the router and the router to the PC. The modem will attach to the router's Internet Port. You will then attach the router to the PC via any of the four Ethernet ports in the rear. Check the LED lights in the front of the router to confirm all of the connections are properly made. The Power, WLAN, Ethernet Port to PC and the Internet should all be lit.
Configure The Linksys WRT54G Settings With all connection made, you will now need to login to the router via your web browser. Type 192.168.1.1 and hit enter. You should see the login screen. Leave the username blank and type admin as the password and hit enter.
You will now need to configure the router's connection to the Internet. Under the Setup / Basic Setup section, make sure the router is setup to Automatic Configuration - DHCP. This allows the router to receive an IP address from your Internet Service Provider.
Next, go to the MAC Address Clone tab in the same area and enable Mac Address Cloning. This allows the router to clone your PCs MAC address, as the ISP may require this.
Power Cycle the Router and Modem Now that everything is configured, you'll want to power cycle everything. This is done to make sure everything has an IP address from the modem all the way through to the PC. To power cycle, shutdown everything. Unplug the modem and router power source. Shutdown the computer. Plug in the modem and wait for all green lights. Next, plug in the router and wait a few minutes until its lights are also green. Lastly, boot up the PC. You should have an Internet connection.
Change the Linksys WRT54G Router Password You noticed when setting up the router, that there was a default username of nothing and a password of "admin." Be sure to log back into the router once everything is running properly and type in a username and change the password. If you don't, a hacker that sees you have a WRT54G router could login to the router with the default credentials.
Jan 10, 2010 | Linksys Wireless-G WRT54G Router
Linksys WRT54G Wireless Router Issue Allows 1 Computer at a time
Your router my not be DCHP enabled or it might not be assigning the IP addresses either.
I would do a reset and start all over with your security settings and see if that works. Worst case scenario you could always turn security off when your parents or others are there.
Link HERE for more Linksys information
pls rate 4 stars
Dec 01, 2009 | Linksys Wireless-G WRT54G Router
No internet connection to main computer when router connected
If you are getting lights on the Internet LED. Go to the router's setup page 192.168.1.1 and put in your username and your password if you are on DSL. For cable connection try to reset your router by resetting the router
Jun 04, 2009 | Linksys Wireless-G WRT54G Router
Trouble senting up router to my computer
Press and hold the reset button for 10 seconds. This will reset it back to defaults.
You may have to unplug the power your modem and wait 20 seconds before you plug it back in. This will refresh the DNS information.
Type in from internet explorer http://192.168.0.1.
user id is admin
password is linksys
press the status button
make sure that you setup the router through a wired connected computer to the router. Linksys routers do not allow wireless admin connects by default.
Jul 15, 2008 | Linksys Wireless-G WRT54G Router
Router issues
Hi Pzarek,
The first thing that comes to mind is that your Linksys modem is using the same IP address as the router and it's causing a conflict. The quickest way to find out if there is a conflict is to get into the administration setup on the router and manually change the IP address of the router itself (currently it's most likely 192.168.1.1 - change it to 192.168.1.250). Linksys has most of its devices that provide dynamic IPs set to 192.168.1.1 by default so I would suggest that.
To log into the router (assuming you have your computer plugged into the router):
Bring up Internet Explorer and type in 192.168.1.1 into the address bar.
When it asks for a username/password, type in 'admin' for the username and 'admin' for the password (without the quotes).
You can change the IP address from 192.168.1.1 to 192.168.1.250 on the first page that comes up.
If you're unable to access the setup, make sure the router is powered up and hold in the Reset button on the back for 30 full seconds. At that point the information provided will allow you to access it.
Ben
Feb 18, 2008 | Linksys Wireless-G WRT54G Router
Installation broadband router linksys WRT54G v5
Please connect the laptop to the linksys router with the cable provided. On the linksys, connect the able in any port from 1-4. Please do not connect the laptop to the Internet port.
From the start menu, select Run. Type in cmd and press enter. At the prompt, type in ipconfig. On the line that says Default Gateway -> this is the address of the router when connected to the computer and (DHCP being on).
Make a note of the Default Gateway and type it in the address bar in an Internet Explorer window. At the login prompt, leave the username prompt blank and type admin for password.
This will allow you to access the web GUI.
Hope this helps :) Kindly leave a good feedback. Thanks...
Nov 27, 2007 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
