Question about Canon PC-1060 Black and White Copier
Paper jam that I can get the small pieces of paper out
Some one was trying to copy two sided and then the paper jamed as it came out of the body of the machine onto the tray. I can't get all the paper out to get it going again.
Help anyone?
  • 62 Answers
Sounds like your jammed paper is in the fixing assembly. (the one on the right side, where the paper comes out printed very hot)
you are gonna have to remove it from the copier to easily remove the paper.
here's some instrutions.
remove the cartridge. then remove the platten glass. you will need to remove a small plastic cover on the left side of the glass. then just remove the glass. then remove a black piece of plastic that covers a cable. now remove the control panel. like if you were to remove the cartridge open the uper cover and there you should see a screw. unscrew it, then the panel must slide a little to your left and then just carefully unplug the flat cable. now you need to remove all the covers on the left side of the copier. (...ok they dont sell this particular model around here but if you do not happen to see screws on the left side then you may have to remove even the front cover). once done, unplug the fixing assembly, there must be at least two connectors that go directly to the power supply, then unscrew it, from two holes located at the top (where you previously remove the platten glass), on one side there should be only one screw and on the other two. once is unplugged and unscrew it should come out 'easily' Caution: It could be hot! now you gotta remove the top cover of the assembly just unscrewing the two screws one per side. it still it doesnt pop up it has some kind of metal locks you just need to push or pull depending on how they're located. once you get to this point (or even before) you should be really able to remove all the paper jammed in there. Good luck!
Posted on Jan 29, 2009
It says my printer has a paper jam but i dont see no paper jamed and i refill it and it says say thing like it would let it go like its going to print then says jamed paper
Try and see if you can locate a small piece of paper that might be causing your printer to jam. Turn the rollers and see if you can see any small pieces of paper stuck in between the rollers.
Mar 02, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Paper jams every sheet. Checked the paper weight, made sure it was faned edges and not rolled. Catches on the left side as it rools in from the drawer. What can I do to fix it. I have used it many...
Marie, there is something stuck between the paper tray and the transport section of the copier. Probably a small piece of paper. try to push a piece of paper up from the tray to the rest of the machine to push this obstructing paper out of the paper path. Also try using the handfeed section on the right hand side of the machine by folding down the tray and putting paper in it. You may have to choose this "manual" feed tray on the operation panel. Good luck !
Feb 20, 2011 | Canon imageCLASS D860 All-In-One Laser...
Paper jamed
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
Error jam code
check for any remaining of torn small pieces of paper===check for no pins or other things inside in paper path=====check for free actuation of paper switches and the lever of the switches in a good condition ------later shut the machine off and then on.
Apr 06, 2009 | Sharp Office Equipment & Supplies
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine. ..
Jan 17, 2009 | HP Officejet 6310 All-In-One InkJet...
Panasonic FP-7750 will not feed paper through machine correctly
Look where you remove the last jamed piece of paper closest to the fixing unit. Dose it jame when you make one copy? If it dose jam in the same place, I would have to say the problem is in the fixing unit. Look, in the unit for any pieces of paer jamed and remove them. Also, is it only happen with one paper tray and not the other. If so make sure you haze the tray and paper are set correctly.... Really need some more info.
Aug 05, 2008 | Panasonic FP-7750 Black and White Copier
Ricoh AC 104 copier
If the paper jam occured behind the toner cartridge, did someone pull it out and leave a piece behind the toner? Look to see if there is a small piece of paper jamed in the connector of the toner / developing unit. Also look for any small piece of paper in the paper path.
May 24, 2008 | Office Equipment & Supplies
Paper jam
hi this is some small pieces of paper which had gone inside in ur printer when u prints. this one have to contact printer engineer to clean the printer
Mar 02, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Paper Jamming
Could be a faulty roller, or jam you have not found yet. Check again with a torch right up insied unit. If no go, try uninstalling and reinstalling printer.
Jun 29, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PC-1060 Black and White Copier Logo
159 people viewed this question
old marine
old marine
