Question about Nintendo DS Lite Console
Nintendo ds lite wont turn on
The green light comes on for approx 2 seconds then the top screen flashes and the green liight goes out can anyone help? thanks
  • stevangie_wi Jan 16, 2009
    already changed battery. i would like to try and fix this myself if possible
    thnaks
    Problem Solver:
  • 11 Answers
Well go to your battery store or what ever has ds battery packs buy a knew one it is because your battery cant charge anymore so get a new one and it should work otherwise send it off to nintendo
Posted on Jan 15, 2009
My ds lite power gooes off as soon as you turn it on
The bottom screen flashes an then the green light goes off new top screen is needed very common on ds lite i repair them for a living an can sort yours for about 18 quid
Simon
Dsdoc
Nov 26, 2011 | Nintendo DS Lite Console
My problem is that every time I turn on my ds lite the white light flashes and then it shuts off and it's fully charged.
Hi the solution to your problem is
A failed top screen the ribbon had gone
The green light comes on screen flashes an then goes off
I repair nintendo ds lites in the uk
So can sort you out for a reasonable price
Apr 23, 2011 | Nintendo DS Lite Console
I turn My nintendo DS lite on and after maybe 2 seconds the green light flashed and shuts off. Help!?
Do either of the screens flash just before the green led goes of?
If it does then the screen that doesn't flash is faulty... If you have a warranty then i'd suggest sending it in for repair if not and you fancy a go at a bit of DIY let me know and I will take you through the process of dismantling the DS lite, reconnecting the screen to see if its just come loose and if you need to I can tell you how to go about fitting a new screen.
Hope this helps,
Regards,
SOD69
Feb 02, 2010 | Nintendo DS Lite
My ds lite wont power on how can i fix it?
One of you're screens is broken or the F2 fuse has blown.
Check youtube for a video on "how to check my DS lite F2 fuses" there are several available that give step by step guidance on how to do this.
Having checked these (and replaced blown ones) and you're screens are still not working then it is a screen that has blown.
If the bottom screen flashes for a split second when you turn it on then it is you're TOP screen that has blown and needs to be replaced. If it doen't flash then it is you're bottom screen that is broken and needs to be replaced.
Sep 10, 2009 | Nintendo DS Lite Console
My sons nintendo ds wont turn on, when we charge it, turn power on , the green light comes on and bottom screen blinks for a split second then goes dead.. Is this fixable , if so what do i try??? thanks
yes it is fixable sounds like your fault is with the top screen are the hinges ok has it been dropped.
most green light and screen flashes point to a defective screen or connection on the mother board or sometimes fuses. id start with checking the motherboard connection if its ok check the fuses if all is ok buy a new top screen and replace it.
Jun 30, 2009 | Nintendo DS Lite Console
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
Wont turn on
I'll quote GBATemp here:
symptom:
the ds lite powers up for a brief instant, but then shuts off
potential solution:
disassemble the lower shell and check the connections of upper and lower displays (all three flexible cable connections).
You can view the full and detailed guide here:
http://gbatemp.net/index.php?showtopic=98240
GMAC
Jun 14, 2009 | Nintendo DS Lite Console
Nintendo DS Lite won't turn on
My kids did the same thing. What I did to get it to work was to push back on the top and hold it turn it on. If it comes on then turns off after you let it go get 2 rubber bands and put the 1st. one on the top left down to the bottom right. The 2nd. one goes from the top right right to the bottom left. Then keep turning it on while moving the top to find the sweet spot.
Jun 03, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
143 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
