Question about Philips 42PF9631D 42 in. Plasma Television
Phillips model 42PF9631D/37 Plasma TV PIP Setup
I lost the owner's manual to this TV and I can not figure out how to set up PIP dual screen so it plays two different channels or sources. I can get the dual screen on, but can only get a signal on the left box and the right side always says "source unavailable". Anyone know how to set this up?...Im trying to get 2 PS2's on the screen at the same time. Thanks.
  • BJoyce May 04, 2008
    I have a 42" Philips model 42PF9631D/37. When I try and use the picture in picture feature, a black box appears in the upper left and it says "Source Not Available" in the upper right. I am using HDMI cables in both my Cable Box and Blu-Ray player. How do I set this up to work correctly. I haven't been able to get any assistance from the users manual.
    Sergeant:
    Champion:
  • 326 Answers
Hello, please try this link: http://www.p4c.philips.com/na4/4/42pf9631d_37b/42pf9631d_37b_dfu_aen.pdf Best regards, Arpi
Posted on Jun 17, 2007
I have phillips 42pf9631d/37 that wont turn on and blinks red seven times
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.com
Oct 25, 2011 | Philips 42PF9631D 42 in. Plasma Television
Philips 42pf9631d/37 6 slow red flashes and 3 fast
6-7 blinks means there is an issue with the power supply...
I found a replacement for my 42pf9631d/37
Part # Lj44-00117A
at TSM Inc. for $110.95 with free shipping...
http://www.tristatemodule.com/p-10120-lj44-00117a-samsung-tv-module-power-supply.aspx
Jan 28, 2010 | Philips 42PF9631D 42 in. Plasma Television
I have a dvp 3960/37 player I am trying to hookup to a Sony KV 32fs120 TV using YPrPb as a component. The Sony manual says the DVP must be Setup before connecting. The Phillips manual says to use the TV's...
If you are using the component output from the dvd player (3 wire video) progressive scan connect corresponding cable to tv . Besure to match colors. If you are getting a black and white double image you need to set the output of the dvd player to progressive scan. See owners manual for dvd player to set this. The yelow color jack on the tv is composite video and is not compatible with the 3 wire video .
Nov 20, 2009 | Car Audio & Video
I have a Phillips LCD tv model #42PF7421D/37. and
I know on the plasma TV's it was a matter of updating or downloading and re-installing the firmware/software for the TV to fix the issue. Go to the following page and if the model you have is indeed a 42PF7421D/37 download the software on the page. Make sure you follow the installation instructions to update the software otherwise the set will become a 150 lb paper weight.
&scy=US&slg=AEN&sct=LCD_TV_SU&cat=TV_CA&grp=SOUND_AND_VISION_GR&session=20091111140139_64.85.227.44&ctn=42PF7421D/37&mid=Link_Software&hlt=Link_Software">Philips Support Page
Nov 11, 2009 | Televison & Video
PIP problems Philips model 42PF9631D/37.
if you have a cable box and run it thour the cable box it will not work. cable befor the cable box you can do it put a spirer on the line be for the box run one to cable box 2 to the tv ant1 ant2 that is the way you can do it.
Sep 09, 2009 | Philips 42PF9631D 42 in. Plasma Television
Removing closed captioning
Worked it out. The Direct TV remote has a yellow button and that did it. I don't know whether I had inadvertently programmed it that way but problem gone.
Thanks.
Jan 18, 2009 | Philips 42PF9631D 42 in. Plasma Television
Flickering contrast
Could be a bad tcon or main board, below is the link for the manual if that helps
Philips 42 50 63PF9631D 37 Manual
Jan 27, 2018 | Philips 42PF9631D 42 in. Plasma Television
Can't remove blue PIP (?) section in lower RH corner
I have the Olevia TV with RC-LTU remote, To get rid of PIP just press the (VIEW) button twice.
Nov 13, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Philips 42PF9631D 42 in. Plasma Television Logo
1,843 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
