Question about Leviton #601-6696-I Ivory Wireless 3WY Switch
Leviton wireless switch fails to work all the time
Newly installed leviton wireless switch only works once in a while. Our electrician says it needs a booster on the main panel. An additional $85 plus. It controls the exterior lights on our detached garage. It is approx 50' or less away from the control. Why does it work sometimes? Is there anything I can try before spending another $100 or so with the electrician? I am not sure what model number it is-it was installed by the electrician.
  • 565 Answers
50 feet is the maximum range for the switch, per manufacturers spec. Range is diminished somewhat for walls, doors, etc.
IIRC, there is a plug in transceiver available from Leviton, however, if the price of the booster for the main panel is included in the $100 installation, then I'd say that's a fair price. You may try to keep fresh batteries in the switch.
Posted on Jan 25, 2009
Vizia VPT 24 - LCD not working, switch not working after power outage
faulty switch ? faulty breaker ? loose connection ?
get an electrician to test the circuit.
Dec 23, 2013 | Leviton Vizia + VP00R-7LZ Accessory Dimmer...
Leviton fan timer doesnt work
Copy following link for instructions wiring single-pole timer.
http://waterheatertimer.org/How-to-wire-timers.html
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Leviton countdown timer model number is unknown.
Which timer has green lights? I thought the leds were red.
Add comment with wire colors on timer and fuller description of timer, and what the timer does.
Apr 06, 2013 | Electrical Supplies
I remodeled my kitchen and replaced my leviton dimmer switch with another brand. After installation I turned the light fixture on. Only one of the three lights of the single fixture turned on for...
Hi Leonard,
I'm a licensed electrician and will be happy to help you get this working again. I suspect an incorrectly wired or incompatible switch or a load that is not designed for dimming. To know which one(s) is the problem and to be able to provide a solution, I need a little more information.
1) What was the old switch brand and model number?
2) What is the new Leviton switch's model number?
3) What type of light bulbs are you trying to operate in the 3 fixtures?
4) What is the number of and wattage of each lamp in the fixtures?
5) How many switches operate the lights?
5a) If more than one switch is used, what is the brand and model number of the other switch(es)?
Thanks
Oct 05, 2012 | Electrical Supplies
We have Leviton push button slide dimmers w/the locate lights for power outlets and lights throughout our house. A couple of months ago one stopped working...you push the button to turn it on and it...
Wiring is not best suspect.
If all the Leviton devices were installed same time, they may be failing at same time due to lifespan.
For example, ordinary on-off switch is a mechanical device with mechanical parts, and mechanical switches last many years longer than wiring devices that have electronic parts.
Electronic devices usually have standard 1 year limited warranty.
http://www.leviton.com/OA_HTML/ibeCZzpHome.jsp?minisite=10025&respid=22372
Jun 29, 2011 | Leviton Decora Light Dimmer Switch
Despite the fans working on a plain Jane single pole switches, I can't get these 6515M switches to work for my 1.3 ceiling fans. The fan hums and all I get on the timers are red LEDs. These timers...
1) Leviton 6515 is incandescent only:
http://www.amazon.com/Leviton-6515M-I-2-5-10-15-Electronic-Incandescent/dp/B0007NOZDI
2) Below is list of countdown timers with horsepower rating so they work for fans:
GE15088 countdown timer is rated 3/4 hp
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay
Intermatic spring wound countdown timers are rated for 2 horsepower
http://www.intermatic.com/products/timers/in-wall%20timers/decorator%20spring%20wound%20timers.aspx
Woods spring-wound countdown timer says bath/ ceiling fans, but doesn't give horsepower
http://waterheatertimer.org/pdf/Wood-59700-series--spring-wound.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#countdown
Woods push-button countdown is 1/4 horsepower
http://www.amazon.com/Woods-59014-Decora-12-8-4-2-12-Hour/dp/B002C54GH4
Wattstopper RT50 at Grainger shows 1/6 horsepower rating
http://www.grainger.com/Grainger/WATT-STOPPER-Time-Switch-2HTE1?Pid=search
3) Following timers are NOT rated for fans:
Lutron MA-T51 countdown timer specifically says it cannot be used for motors.
http://www.amazon.com/Lutron-MA-T51-WH-Maestro-Countdown-Timer/dp/B001EFV1DA
http://www.lutron.com/TechnicalDocumentLibrary/0301041A.pdf
Pass and Seymour RT1 countdown does not show rating for horsepower, so this timer will probably not work for fan motor
http://www.homedepot.com/Electrical/h_d1/N-5yc1vZ1xg8Zarcd/
Feb 26, 2011 | Leviton 6515M-W Timer Switch, 2-5-10-15...
How does levition 6696 switch work?
The Leviton 6696 Anywhere RF(Radio Frequency) lighting control allows you to add an additional (wireless) switch to an existing switched light(s) without having to hard wire it. For example, let's say that you have a bedroom with a switched overhead light. The Leviton 6696 RF receiver would be installed in place of the existing light switch. It will still function and is wired the same as an ordinary switch. The Leviton 6696 Anywhere RF transmitter (after installing the batteries) can then be used anywhere within 50 feet of the receiver (that replaced the existing light switch) to also control the light. You don't have to mount the transmitter if you don't want too. It can be on the night stand, (or carry it with you if you want) so you can turn the light ON and OFF from the bed or wherever.
Oct 21, 2010 | Leviton #601-6696-I Ivory Wireless 3WY...
On/off works but dimmers do not. leviton toggle
If each pendant has an individual transformer that is about the size of a hotwheel then you need a dimmer specifically for ELECTRONIC LOW VOLTAGE. A lot of electricians don't know that the different types of lights require different dimmers. Most store bought dimmers are for incandescent lights only, and some nicer dimmers like the Lutron Maestro's are rated for incandescent or MAGNETIC Low Voltage which require a different Sin wave interuption. I don't know that leviton makes a dimmer in that style for Electronic Low Voltage. You could install a Lutron DVELV300P-Wh, but that is a Decora opening. http://www.lutron.com/CMS400/WorkArea/downloadasset.aspx?id=25437
Here is a link to explain the difference in how the dimmer needs to work. Good luck!
Mar 03, 2010 | Leviton Toggle Touch Dimmer - TGI06-1LB -...
Wiring ceiling fan to a light/fan dimmer swich
I think you should get a licensed electrician , if you dont wire it up correctly you could burn your house down and i dont think insurance companys take klndly to diy electrical work around the home .
Jun 05, 2009 | Leviton Decora Light Dimmer Switch
Installing a Leviton 5225 switch with outlet.
A switch is wired using the hot wires only, the black wire. It is simply a break in the line so that when the switch is off no power flows and when the switch is on the power does flow.
You are correct that the middle outlet would have two black wires and two white wires.
If you want to tap into that middle outlet and run power up the wall I suggest you look into some wiremold products. Go to their website, or any home depot and check it out. Get back if you think I can help you further. I am an electrician.
Here is a link that may help you.
http://www.make-my-own-house.com/electrical-wiring-diagrams.html
Jun 02, 2009 | Leviton 5225WSP Switch and Outlet
Newly installed Leviton dimmer switch humming at the switch
Unfortunately, the hum is normal for operation of that type of dimmer at low levels.  Sometimes the lamp filaments will also "sing" a high pitched sound.
Mar 17, 2009 | Lutron #D-600PH-DK 600W SP Push Rotating...
Leviton #601-6696-I Ivory Wireless 3WY Switch Logo
238 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
