Question about Kenmore 47752 / 47754 / 47759 Electric Double Oven
How to change back to farenheit on display
We had a power outage and the display went from F to C degrees. We are trying to locate manual now. Anybody got a quick reset process?
  • 878 Answers
Coasty, try this, press and hold the broil pad for 7 seconds. C or F should appear, press the up or down ^ keys to toggle between them, Catriver.
Posted on Jun 17, 2007
Blomberg BEP 906. After power went out a couple
When baking or cooking common foods in your oven, it is important that the oven heats to the proper temperature. Otherwise, the food in your oven could become over- or undercooked. The electric ovens are able to be calibrated if only slightly off, however, if the temperature is 25 degrees off or more, you should replace the oven sensor. The oven sensor is the device in the oven the detects the temperature. The control board increases or decreases the oven temperature, depending on the oven sensor reading. Before calling a repair technician, attempt to calibrate your oven or change the oven sensor.
1 Turn on the oven and set the temperature to a medium-heat setting, such as 350 degrees.
2 Allow the oven to preheat and then open the door and insert the oven thermometer.
3 Allow the oven thermometer to remain in the oven for a few minutes and the look at the temperature reading, comparing it to the oven temperature setting.
4 Recalibrate the oven if the temperature is only slightly off, or replace the oven sensor if the temperature is greatly off, such as 25 degrees or more.
Calibrating the Oven
1 Turn off the oven to prior to calibrating.
2 Press and hold the "Bake" button until the calibration settings are displayed on the display.
3 Use the arrow buttons or "+" and "-" buttons to adjust the temperature the number of degrees that the oven is out of calibration.
4 Press the "Start" button to save the calibration settings.
Replacing the Oven Sensor
1 Unplug the oven from the wall or cut the power to the oven in your breaker panel.
2 Open the oven door and remove the oven racks.
3 Locate the oven sensor, located at the top-center of the rear oven wall.
4 Remove the mounting screw securing the oven sensor to the wall and then pull the oven sensor away from the wall.
5 Remove the cable connected to the terminal on the rear of the oven sensor and then discard the oven sensor.
6 Connect the cable to the terminal on the new oven sensor and then reposition the oven sensor and secure it using the mounting screw.
7 Replace the oven racks and then restore power to the oven.
Dec 23, 2011 | Ovens
Cant figure out how to get back to farenheit temp..
to change between fahrenheit and celsius
The temperature is preset at Fahrenheit, but can be changed to
To Change: Press and hold CUSTOM BROIL for 5 seconds. A
tone will sound and “C” will appear on the display. Repeat to
change back to Fahrenheit. To remove, press UPPER OFF,
LOWER OFF or OFF/CANCEL. you can click on the link for guide
Aug 16, 2008 | Whirlpool GBS277PDS Electric Single Oven
My Thermador RDDS30VRS only heats up to 230 degrees
If you have the use and care manual, check to see if your unit has the option to change from farenheit to celcius. If so, make sure yours was not accidentally changed to celcius.
Sep 07, 2011 | Thermador SEC301 Electric Single Oven
I have a whirlpool accubake oven that is stuck on the celcius temperature and I don't have an owners manual and I need to reset it to farenheit. Please help!
To switch it to and hold the BROIL button for up to ten seconds and the display of the broil temp will change from 500 to F then push clear/off button...if later on it needs to be switched back to C do the same thing
Aug 28, 2011 | Whirlpool Ovens
The electricity went off while cooking and when it came back on, the oven display reads "off" and wont allow us to resume cooking
try turning power of to the unit at the breaker box for 5 minutes,, if still having problems after turn power back on, i hate to tell this is common after power outages when the power comes back on as u might know the initial jolt will sometimes blow electronics,, and guess what allot of these wall ovens have touchpads and electronic control boards ... i tthink u might have blown ur control board
Jan 30, 2010 | Jenn-Air JJW8230D Electric Double Oven
4 Elements and Oven not working
If there was a power surge when the power went out or came back on, it could have fried the controller.
Jan 16, 2009 | Frigidaire Ovens
How do I change my whirlpool oven back to Farenheit instead of celcius...
its in your manual, did not give model number so i looked up anyone. if this does not work you can enter your model number here for a copy of user manual
To Change:
Nov 07, 2008 | Whirlpool Ovens
Door Keeps Locking and Unlocking after Power Outage
Located the switch - resetting fixed my stove as well.
Dec 17, 2007 | GE Profile JTP18 Electric Single Oven
Kenmore 47752 / 47754 / 47759 Electric Double Oven Logo
136 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
