Question about Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator
Control board damaged how & where can we replace
Liebherr 3846 stack (fridge on top/freezer below) fridge not working, freezer is will prefer replacement if possibe sourced in usa
  • Liebherr Master
  • 19,396 Answers
You can buy the part from website below:
You find parts and diagrams by entering model number here.
Posted on Jan 23, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
Please tell me your exact loacation where you are located so i can help you out.
http://www.fixya.com/repair/refrigerators
Posted on Jan 15, 2009
    President:
  • 1,990 Answers
Welcome to Fixya! The Manufacturers Website has the Parts list under Customer Service. You can Actually Search by Part Number or Model.
The fridge and the bottom freezer are working fine. However there is a lot of ice developing at the bottom of the (bottom) freezer. Although we recently de-frosted the freezer and removed the ice (water),...
there is only 2 things if you dont have an ice maker inside your door is not sealing all the way around or the drain is cloged with ice and everytime the ref goes into defrost the water leak into the fzr unplug for 2 days that shoud fix it
May 30, 2010 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Freezer not freezing, or if it is lettuce etc in fridge freezes
With fridge freezers, there is usually a solenoid at the back that controls where the refrigerent goes. It consists of a sealed valve and a solenoid coil. It is possible that this has become open circuit so cannot direct refrigerant to the freezer section.
Another alternative problem may be the thermistor in the freezer section. This sensor will tell the control board the temperature in the freezer section. If it gets it wrong, then the freezer will overcool or not cool at all. Often a manufaturer will standardise on a part, so swapping the fridge and freezer thermistors around can identify that this is the fault - then just buy another 1.
If these tests don't work, you're looking at a new control board. Second hand ones may be available.
Best of luck.
Feb 08, 2010 | Liebherr Premium K 2954 Top Freezer...
Fridge and freezer display shows ON and not
Hi, if the display is supposed to show the temperature of the fridge/freezer on the display then what appears to have happened is that the remote temperature bulb has come out of place. If you can get to it you may be able to put it back in place. You will have to start at the display and will see the temp. cable and follow it back to see where the bulb is now resting. If it is not exposed for you to be able to excess it, I would call asap from where you bought it as it is new and tell them about this condition! Keep me updated on this please.
Sincerely,
Shastalaker7
PS It would not be the compressors unless the unit is not cooling at all then you could have a serious problem.
Jan 17, 2010 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
Sep 07, 2008 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Stainless steel finish on Liebherr fridge
if you have scratched or damaged the surface, you can get a stainless steel foil product to cover your refrigerator from www.applianceart.com. If its not that bad, make sure you are using a stainless steel cleaner after you have washed it with a regular cleaner.
Jul 06, 2008 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Thermometer
YOu have to be more clear on the post it dont make much since, also if its brand new should be under warranty
Aug 21, 2007 | Liebherr KGBN 3846 Premium BioFresh Bottom...
BEKO FRIDGE
Leaking what? And where from. If it is water inside you have a blocked drain if on the floor then you may have a hole in the pan on top of the compressor. If not water I have no idea?
Aug 17, 2007 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator Logo
115 people viewed this question
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
