Question about Acer Computers & Internet
Wireless laptop disconnects from internet when power cable connec
I have wireless connectivity from my laptop, when the power cable is not connected. The second I connect the power cable, I am disconnected from the internet. Hope you can assist.
Cheers.
James.
  • James Hill
    James Hill Jan 15, 2009
    Thank you Teis and BillW50 for your quick response. When the power cable is NOT connected to the Acer Aspire 9300, I am able to connect to the internet (as I am doing now). However, as my battery starts to go low, I then connect the power cable to the Acer and...I am immediately disconnected from the internet. For BillW50, it does not reconnect. In fact the list of wireless networks I had are all gone and one general wireless network fills the place of what used to be several wireless network choices. Hope this helps. I am using Sympatico and do not think there is a capacity to change to a different channel.
  • Teis Thomsen
    Teis Thomsen May 11, 2010
    Need clarification, as you
    write two thing of the same case, i.e.
    "I have wireless connectivity from my laptop, when the
    power cable is not connected."
    and
    "The second I
    connect the power cable, I am disconnected from the internet."
    Which is the
    problem you want solved?
    /Teis
  • 114 Answers
Does it reconnected again then? Or it never reconnects on the AC? I would try different channels on the wireless router first. Hopefully that will solve the problem do to some interference. If not, report back and I have other things you can try.
Posted on Jan 15, 2009
  • BillW50 Jan 15, 2009
    You can also open up the Device Manager and find the wireless under Networks. And right click and select properties. And under the Advanced (tab) look for Power Save Mode and disable it. That might help if you have this option.
My laptop and my iphone indicate that my wireless-g broadband router is putting out a wireless signal; but neither accessory works on the network, even though the bars are entirely full on the devices.
The bars on your laptop or iPhone means that you are connected to the router! Not necessarily to internet. Your internet depends on ISP Internet service provider and modem which connected to your router. To check if you have active internet connection connect your laptop directly to modem provided by your ISP with ethernet cable and try to open a internet browser IE or Safari or Chrome or Firefox and open a webpage! If you are able to connect internet by this mean you have internet connection active. Now disconnect your lap top from modem and connect modem to your Linksys router using WAN port of LINKSYS! Its good to power off and power on (power cycle) once on modem and router to make it work!
good luck!
Sep 14, 2011 | Linksys Wireless-G Broadband Router
D-link DIR-625 wireless router is setup and wired to laptop
First of all make sure the Wireless switch in your Laptop is turned on.
Now Disconnect the cable from the Laptop to the Wireless router
Now go to your Wireless Network connection and search for the available network. Select the appropriate network and connect.
Thanks
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Cannot get my new laptop to use my wireless connection to my adsl router- wireless g old laptop using xp no problem
For connecting new laptop using windows 7
Goto Control panel-Network and Internet--Click connect to a network on left side of pane--It should show all the wireless networks including your adsl router--Click connect it would ask for security key-Enter your security key for router-You should be able to connect.
If unable to find wireless network of router then try following steps.
> Turn off laptop
>Turn off router and modem (Disconnect power cable)
>Power on router first then laptop
>Then follow first method.
Thankyou
Sep 09, 2010 | Computers & Internet
I want to connect to a wireless router with my laptopbut dont seem to the wireless drivers.i have tried to connectwith virgin media modem and router .followed all instructions and when i remove ethernet...
Sir, try downloading the wireless driver from your laptop company's website. Or form the drivers cd/dvd they provided you. Then you can connect to any wireless capable modem/router from your laptop.
The ethernet cable provides the internet pulses into your laptop. If you remove it, your internet connection gets disconnected.
Jun 30, 2010 | Advent Netbook
I have a wireless connectivity issue from my laptop. When the power cable is connected, the internet works. When I disconnect the power cord, I am disconnected from the internet. This problem has only...
I would say you need a new battery, if when you disconnect the charger your losing your wireless connection, you need more power to hold the wireless connection or that make sure when you remove your charger press your wireless button near your volume control on laptop to make sure its on, blue, not off red ok
Jun 29, 2009 | Acer Aspire 3680 Laptop
NETWORK IS NOT CONNECING IN wi-fi in our wireless network with WPA2 system. but its detecting the network. should i install any new software to support WPA2.
try to setup again  wireless card's driver  if it doesnt work your wireless car is break down.
have a nice day and sorry for english.
May 27, 2009 | Acer Aspire 3680 Laptop
I have a cable connection to the internet and when I hook up the
1. Disconnect the cable from your cable modem and connect it to one of the four on the back of the wireless router.
2 Connect a cable from the back of the cable modem to the LAN port on the wireless router.
3. disconnect the power on the cable modem for about 30 seconds.
4. reconnect the power to the cable modem and wait until the unit boots completely.
all but the activity light should be on.
5 power up the router and wait a few moments.
You should now have access on your computer that you have connected to the router. verify this by going to a web page.
6. on the laptop, open the control panel and then the network connections control panel (this assumes we are working with windows).
7. Highlight the wireless adapter by clicking on it once.
8. To the right of the icon will be a list of links. (assuming windows XP). click the one that says "view available wireless networks". Your router should be in the list. If so, highlight it and click connect at the bottom of the window.
Did this resolve your issue?
Apr 05, 2009 | Linksys Wireless-G WRT54G Router
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Connect xbox360 and linksys wrt54g
There are several possible reasons why XBOX doesn't connec to the Internet through the router:
  • Check physical connections between XBOX and router.
  • Try different Ethernet ports on the router and use known working Ethernet cable.
  • You may also connect your XBOX directly to your modem and check if it will connect to the Internet.
  • Check the IP address that your XBOX is getting when connected to the router.
  • Take note of the error message you get from XBOX for us to know the real problem.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G WRT54G Router
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Computers & Internet Logo
593 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
