Question about Canon DR-9080C Path-Through Scanner
When scanning to "batch to file" or "scan job" in captureperfect
To a folder on the "c drive" it generates another folder instead of a pdf file
  • 490 Answers
Check if thee is virus in your system. Some 'autoplay' viruses do this.
S. Mohan
Posted on Apr 09, 2009
I can't scan different document sizes (A3 and A4) in one batch with the Canon 9080C.
IF you are using CapturePerfect 3. version, you can select "Auto detection" for page size, and under 'more' select 'image size' instead of guide plate. Also you may have to select option '1' under user code U10 in case you want to scan pages over 17 inches long. (Press Newfile and Countonly simultaneously, press 'newfile' till you get U10, press 'countonly' and select 1. This will enable scanning upto 1 meter long).
CP3 has "Skip Blank page option", this helps you to automatically delete blank pages on the back side and scan only those with data.
S. Mohan, Chennai, India
Dec 03, 2010 | Canon DR-9080C Path-Through Scanner
How do i get my Canon 5080C scanner to scan in a PDF format?
Assuming you are using CapturePerfect Scanning software, you need to select the output as PDF. If you want multiple pages in a PDF file, you need to select 'multipage' option.
S. Mohan
Nov 09, 2010 | Canon DR 5080C Path-Through Scanner
Why can't I scan and save to a PDF file? My computer doesnt give me the option. all I can save to is to a TIF file, GPJ file, ect, but not PDF..why?
This depends upon the Scanning software you are using. if you are using DR series of Scanners, you can download Captureperfect 2 from the Internet which has the option to save directly as a PDF file.
Oct 09, 2010 | Canon Office Equipment & Supplies
HP WILL NOT SCAN AS PDF FILE
It'll not scan as PDF instead you need to save the image as PDF or change the settings to save to PDF by default
Follow instructions to change the default settings using the manuals:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3390949&
Sep 08, 2009 | HP DeskJet F4280 All In One Printer InkJet
Acrobat and Canon DR-9080C not working
You are right, it is driver related issue. Acobat 9 has more features that may not be compatible with the existing driver. may be you can use CapturePerfect and directly create PDF and then use the Optimising features of Acrobat 9. Ofcourse you have to do it twice, but you can use the 'batch' process and do it automatically.
S. Mohan
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
When ever I scan, Capture Perfect adds zero's to
On the screen "scan batch to file setting" in the middle of the page under "save as type" change "type of batch separation" to "none". This will fix the problem.
Apr 24, 2009 | Canon PIXMA MX310 All-In-One Printer
I have a new DR-5010C scanner. I used to use the
I havent used Canon 2580C and hence cant comment on Scan Panel. But you can download SU5000 or Captureperfect 2.0 from Canon website (http://software.canon-europe.com/). This is easy to use and probably offers more features as compared to ScanPanel. Canon 5010C is a higher model as compared to 2589C and Captureperfect may offer better user interface.
S. Mohan. Chennai, India
Mar 19, 2009 | Canon DR-5010C Scanner
I have a canon DR-9080c that gives me a PAFCV2.DLL load error
I have resolved this in the past and a new user just brought it up again.
The pafcv2.dll in Captureperfect 2 does not seem to work. If you install CapturePerfect 3 and copy the pafcv2.dll into captureperfect (c:\program files\canon electronics\captureperfect2 or whatever install path you used), you will find that you can now scan into PDF, even in batches!
Feb 23, 2009 | Canon DR-9080C Path-Through Scanner
Want to scan to pdf a document larger than one auto-feed tray
I'm just thinking off the top of my head but there is an option in copying called 'job build' in special functions. This enables you to add many document sets into one print job. This may also work for scanning although i can't remember trying. Try it.
Feb 16, 2009 | Canon IMAGERUNNER 6570 Copier
Scanning large documents to PDF takes a long time
Try to use Compact PDF or a lower resolution.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jan 14, 2009 | Konica Minolta bizhub C250 All-In-One...
Canon DR-9080C Path-Through Scanner Logo
421 people viewed this question
old marine
old marine
