EN9250 worked graet 20 minutes ago. Unpluged it to move computer- Plugged it right back in and now no signal. I have checked all connections and still no signal
  • BillW50 May 11, 2010
    Are you sure you plugged it into the right video socket on the back of the computer? There might be more than one.
    Scholar:
  • 62 Answers
Make sure the cable is plugged into the video in. Shut down the computer and unplug it. Unplug you monitor again and also check conections by removing the cable make sure no pins are bent on the monitor or the conection to the computer. Plug all back in. Turn the monitor on first and then the computer. I hope this helps. If not let me know I will need so more info. Good Luck.
Posted on Jan 16, 2009
2008 envoy Denali right turn signal and right hazard quit. replaced relay worked for 20 minutes of driving then right turn and right hazard quit again??? LEFT SIDE IS FINE
Sounds like you have a wiring issue ! Maybe when you installed the turn / hazard relay you moved the wiring harness in such away that made it work. Grab the wiring harness an do the wiggle test an see if it works . Mite have lose connection where the relay plugs in, close the terminals a little bit. I don't know what you know about electrical systems on automobiles or I'd tell you to do a voltage drop test to find the problem . Need volt ohm meter an a wiring diagram to do this test. Electric Testing Techniques You Need to Know
Feb 28, 2015 | 2008 GMC Envoy Denali
My computer turns on, i can hear it, but the monitor displays "no signal"
Because you are getting no signal on monitor, The first check would be the VGA cable! Do you have a spare to test with?
Jan 18, 2015 | AMD Computers & Internet
We moved a week ago and just now plugged in the freezer and no power at all.It worked just fine before we moved
it is possible the freezer went into a defrost cycle leave it plugged in and in about 20 minutes it may come back on, or you may have a dead plugin . plug something else into the plug to make it is working
Jul 19, 2014 | Danby Freezers
Dvd player moving image
Check your connections. Check connection cords and eliminate all connections that look worn out or broken. Shut off you system and wait about 5 minutes with it unpluged. Turn on the system before you plug it back up to clear it out. Then plug it up and start it over.
Good Luck!
Apr 18, 2014 | LG Televison & Video
Unpluged dryer to move it, when plugged back in it wont work.
Make sure it is plugged in all the way, It might be making a good connection Check for 240 volts between themobilian_968.jpgred and black or the 2 outer gray wires. Your fuse is right herethemobilian_969.jpg
Sometimes you move one and the junk buildup in that filterthemobilian_970.jpg chute drops down a little and blocks the heat in which naturally blow the fusethemobilian_971.jpg
If your door switch was broken during the move then that could be it also.
I have a service manual and some videos with more repair photos HERE
Jan 21, 2011 | Whirlpool LER5636P Electric Dryer
Humming when no input in jack; works fine with rca inserted; worries me that somethings is not right even though works fine with RCA or XLR plugged in, right channel only
Sounds like it could be feedback hum. Is there anything near it that could cause a reaction when unpluged? Such as a turntable, cassette etc. If so move them and see if it goes away. Even then it won't hurt the amp. I think otherwise worry when there's a hum when they are plugged in. PS check any earth connections too!
Jun 21, 2010 | Adcom GFA-5802 2-Channel Amplifier
Error message on Syncmaster- check signal cable
sounds like it might be a graphics card. if u have an old graphics or vidio card, open the case and remove your card then install the old one. if it works now youll know your card is bad. If u have an old video card and an open pci slot install it and move the monitor cable to the old video card plugin. if it works now same thing your graphics card is bad. to know which card to remove just remember which one the monitor is plugged into.
Jul 29, 2009 | Samsung SyncMaster 940B Monitor
Network Cable Unplugged
mairelina, if all was well 2 days ago then resetting the router should fix your problem. usually a small button on the back of the router.
chelliepooh, you need to check that the router's wireless function is on. connect using the ethernet and go to the config page (usually 192.168.1.1) make sure wireless is on and security is set to wpa-psk.
May 19, 2008 | NetGear WGR614 Wireless Router
Monitor has no picture
Yes! :)
Your monitor is not the problem. Check all the connections from the back of the monitor, to the computer.
"No Signal Analog" means your monitor is working perfectly, however is not receiving signal from the computer.
Didnt find any loose cables?
Try unplugging everything. Leave it unplugged for at least 5 minutes. You need to give the system time to drain all the excess power.
Again your monitor is fine, blue light > No signal > orange light is totally normal for your montior.
Oct 12, 2007 | ViewSonic VX922 19" Monitor Flat Panel
Computers & Internet Logo
399 people viewed this question
David Payne
David Payne
