Question about Casio PRG-40T-7 Pathfinder
Changed dead batteries on PAG-40. Still one dead watch
After replacing all four batteries, keeping a 3 springs in place, no difference after watch put back together. No
displays, and no light when light button pushed.
Any ideas?
  • Anonymous Jan 16, 2009
    reset .push the terminals wt twzzrs it say so the wtch
  • pme5 Feb 13, 2009
    i cant see exactly which part i should connect to, the battery +ve is obvious but the "AC" is not any pictures?
There is a very small sticker with very small red print just adjacent to the battery compartment. This little sticker states "once batteries are replaced, you need to touch AC with tweezers". I did it with metal tweezers and the watch display came to life. Good luck!
Posted on Feb 19, 2009
Casio PAG 40 I took it apart to replace bateries and a spring came out and I don't know where it goes. The 2 gold ones are in place.
It's probably the small spring which makes electrical contact between the watch aluminum back and the outer housing, presumably to provide an electrical ground connection to the outside triple sensor. I've attached a photo with the location indicated by the yellow circle and arrow. It goes in the little hole and will fall out if you're not careful.11_14_2012_6_41_27_pm.jpg
Nov 06, 2012 | Casio PRG-40T-7 Pathfinder
Evening: I have had my data link for about 3 years. The battery went dead so I went to a watch repair place to have the battery replaced. The watch works great, BUT it doer not beep. All the beeps are...
Same thing happened to me, took watch to watch shop, they changed the battery and the chimes stopped working. Simple fix, the faceplate was put back on wrong. Unscrew the face plate and turn it upside down (or right side up depending on your POV) the circle on the inside of the faceplate will line up with the springs inside the watch and the chimes will start working again. If you have a pair of eyeglasses screwdrivers, like I did, you can do this yourself.
Nov 25, 2010 | Timex Ironman Data Link 5C291 Wrist Watch
When using the barometer or altimeter on my my pag 40 - 2271 it shows err. How do I fix it? Do you know what page in the users guide shows how or gives directions on how to fix?
Same problem with my SPF-40, module 2273, after a small helical compression spring, silver color, fell out. I could not determine where it is suppose to be located. It could be the barometric reference spring for sensing the barometric pressure.
Nov 18, 2010 | Casio PRG-40T-7 Pathfinder
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    I have a GUESS watch style 86013L and the battery was changed 3 days ago and it's already dead. What size battery does this watch take?
    Bring the watch back to the place where the battery was changed, after only 3 days they should at least try another battery , maybe this battery has just gotton loose.
    Jun 15, 2010 | Guess G66355L Wrist Watch
    How to replace battery for Timex expedition
    Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
    May 12, 2009 | Timex Expedition 84601 Wristwatch
    How do I rest my Casio PAG-40 after I replaced the batteries?
    You need to shortcut AC point and battery. Take tweezers and touch AC and battery (+) simultaneously. Use an eyeglass to find AC point. It is marked on the movement with letters AC.
    Here is the link for easy watch setting:
    http://world.casio.com/wat/download/en/manual/
    Rate me, please.
    Apr 04, 2009 | Casio Watches
    Casio Pathfinder PAG-50 battery replacement
    ensure all three of the springs are present
    the 2 at the top confirm that the case is closed the on at the bottom sends the sound signal.
    ensure the metal casing on the back of the movement is not touching the back. and check the movement is correctly seated
    Mar 28, 2009 | Casio Watches
    Casio SPF 40 beeper not working after battery change
    There is this little spring which fits in one of the small holes in the watch. When I tested my watch without the spring, there was no beep. With the spring in place the sound worked nice again. So (IMO) apparently the little spring is used as contact between the watch en the "speaker" placed at the back of the watch.
    regards,
    Pieter
    Oct 04, 2008 | Casio PRG-40T-7 Pathfinder
    CASIO PAG-40 Keeps good time but buttons stopped working
    open the backside.
    probably the light switch contact at the six side of the watch (attached to the steel mainframe) may have contact with the electronic cirquit
    Jan 13, 2008 | Casio PRG-40T-7 Pathfinder
    Casio PRG-40T-7 Pathfinder Logo
    1,225 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
