Question about Canon PowerShot S2 IS Digital Camera
Canon S2 IS won't turn on with rechargeable batteries??
My canon batteries(duracell powerpix AA's) went dead about 2 weeks ago. I kept forgetting to buy new ones since no events were coming up. I remembered the other day and thought I would try rechargeables. I bought the Energizer brand with the charger to them...charged them for 10hrs and put them in the camera..nothing. No power. I took them back and exchanged them for the Rayovac Hybrid with charger and it said they were ready to use, already charged. Put them in the camera..no power..so I thought, maybe they drained in the package. So plugged them in, paper said to charge them for 8 hrs. Well, they charged all night from 9pm until 11am today. took them out, cooled them down and put them in. Still no power. I did notice that the LED lights showing its charging was still on. I reread the instructions and it says LED will turn off when batteries are fully charged. now that I think about it, the energizers were still lit up too when I tried them out. Were they not fully charged? Could this cause them not to work in the camera? Because I tried them on my tv remote and they worked just fine. but wouldn't power up my camera. Guess I need to buy more duracell powerpix alkalines and check to make sure my camera IS working? I just really want to use rechargeables now that its summer time. Should I keep charging them until the LED light shuts off?
  • Julie Carrasco Jun 23, 2007
    It wasn't that. I fully charged them and it still had no power. I went and bought new duracell powerpix AA's like I always do and it still had no power. So I sent it off to Canon since its still under warranty.
    Problem Solver:
  • 40 Answers
I would let them charge til you get an indication that they are done. TV remotes require very little power to operate, while digital cameras need a lot, so that's why the batteries would work in the remotes though not fully charged.
Posted on Jun 23, 2007
SOURCE:
What type battery for powershotA480
Your camera uses 2 AA batteries, but if you use Alkaline batteries they will drain very fast. You are better off buying rechargeable batteries as you can recharge them several hundred times, cheaper than Duracell or Energizer Alkaline batteries in the long run. If you buy rechargeable batteries make sure you get a high mA capacity the higher the mA which stands for Milliamp Per Hour the longer the battery will last in terms of a charge.
Jun 20, 2014 | Canon PowerShot A480 Digital Camera
What kind of aa battery 2 use?
duracell or if you want to use rechargable take pre-charged model. there is pre-charged models Sanyo (eneloop), Varta, Sony etc. take at least 2000 mAh
Feb 26, 2011 | Canon PowerShot SX130 IS Digital Camera
Just bought a second hand Canon Powershot SX100 IS.
Try cleaning the battery contacts in the camera first with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol.
Mar 08, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
My Canon Powershot A2000 displays a low battery even when I've just replaced with new. I've replaced several times, each time with two identical batteries, each time from a different package. I may be able...
For the best results, I recommend you to use Canon rechargeable (NiMH) batteries. Rechargeable batteries provide the best performance and are the most economical choice.
Else......
AA alkaline batteries such as those from Energizer or Duracell will provide the best performance for non-rechargeable batteries.
Feb 11, 2010 | Canon Powershot A2000 IS Digital Camera
Batteries need replaced constantly. I am using 2 AA alkaline as instructed. As soon as I put them in it says batteries are low and shuts off. This is happening with all brands of new batteries. What's the...
Canon actually has recalled some serial numbers for your model camera for the problem that you're experiencing. Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Dec 24, 2009 | Canon PowerShot A540 Digital Camera
When I insert some batteries the red light begins blinking. I also have some Duracells that appear to be charging but when I place them in the appliance they are dead.
All chargers cannot charge all types of batteries. Are your Duracell batteries NiMH or Alkaline? These indications generally happen when you insert a battery type that is not rechargeable.
Dec 13, 2009 | Duracell AA/AAA NiMH Battery Charger with...
Lens will not open to take a picture
The first thing to try is new lithium ion batteries (Energizer Advanced or Duracell PowerPix) or quality rechargables. Battery type makes a difference with these cameras and regular alkalines (even new ones) often just don't cut it.
If it still doesn't turn on, or open up, press and hold the playback button [>] to start up the camera in Playback Mode (resets the lens).
If all else fails, the lens is probably jammed. If you bought it less than a year ago and saved the receipt, call Polaroid tech support and they may replace it. Be prepared to be without a camera for a few weeks.
Jul 29, 2009 | Polaroid i737 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
198 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
