Question about Aiwa AVJX 5 System
Aiwa avj x55 home theatre system sound problems
On playing dvd films sound is fine on all aspects of the dvd until playing the actual film, when playing film background music is clear but voices are muffled and barely heard turning volume up just increases background noise i.e music aaargh ive tried everything any ideas? dont understand how voices on film cant be heard but on bonus features there are no probs at all? (tried several dvds all the same)
SOURCE:
jango2
  • 38 Answers
SOURCE: Speakers are making a crackling sound then cut out.
Sounds like an internal loose connection somewhere, possibly anywhere, a connector on a pcb, a dry solder, loose pin on an IC. Tough for an end user to solve this, would entail opening the unit and investigating. I checked the rear panel in the op manual and this model has no ribbon connectors else i'd have asked you to check them.
Posted on May 20, 2008
  • 38 Answers
SOURCE: aiwa cx na555u
Dear shelnaaqua,
Please connect the headphone to your system and check the sound quality,If it sound good then the connection of the speakers are not ok. This system has HI & low frequency output. Connect woofer to LOW frequency output and tweaters to HI frequency.
please take trouble to vote for me if this solve your problems
ramesh22
Posted on Jun 09, 2008
kakee
  • 1269 Answers
SOURCE: Clear all the pre-set channels
There's no clear all settings there. You need to manually delete each saved station. Try to unplug the power of the unit for few hours and check if that clears all.
Posted on Mar 16, 2009
Ganx
  • 113 Answers
SOURCE: hi i have just purchased a second hand ht-dv90,the
Hi, sounds like a zone issue. Check the zone on the one works and I'm sure you will find it different to the others. Not sure if there is a slution there as will have to change the zoning on it.
Regards
Posted on Jul 25, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have an Aiwa cx-nma545 that I just hooked up to
On most TV's with speaker control there's a way to disable the TV's volume control effect on the level fed out to an external amplifier. Find it and disable it it or select FIXED for its level, or, while listening through the Aiwa, raise the TV's volume through its own remote and see if that affects what the Aiwa gets for volume.
Or, enable the TV's speakers but find the same interna lAudio setting and make it Fixed, but turn the TV volume down if you don't want to hear its speakers. That way, you could actually listen to the TV on its own speakers if you want, say, for casual watching of the Weather Channel or news, for example.
Posted on Nov 29, 2009
Installing sony dvd home theatre dvd recorder to digital tv
you may have to press the audio button or set the audio stream on the dvd's (disc) menu, as some films use the 2 channel audio as default
Jan 02, 2010 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Home Theatre system goes into MUTE mode while film playing
Sounds like your system is going into a safe mode. This happens when you have a neg/pos reversed hooked up, or your wires are touching. This feature prevents you from blowing up your amp. Check your wires, and make sure the positive is hooked to positive etc. and make sure no bare wires are touching.
Sep 01, 2009 | Audio Players & Recorders
Hi i have just purchased a second hand ht-dv90,the problem is it will only play one dvd film that i have and will not play any of the others ,any ideas on what the problem is.i dont fancy watching the same...
Regards
Jul 24, 2009 | Aiwa HT-DV90 System
DV 370.This player wil not accept a dvd-rw disc that has been recorded and formatted on a Toshiba.It will play a CD and all film videos.What is wrong?
Normally Home DVD players do not accept DVD-RWs. Basically DVD-RW is to be used to carry Data, and useful for PCs not DVD players.
May 13, 2009 | Aiwa XD-DV370 DVD Player
Does not read cd or dvs
Could be many things. But it probably needs a new pick-up (laser). You can try cleaning it with rubbing alcohol on a cotton swab.
Jan 30, 2009 | Audio Players & Recorders
Audio function "Bypass" - problem
try to increse the volume centre channel level so that u could hear better vocals. or do one thing if u r connected with optical cable only. just connect single RCA cable from dvd players centre channel output to the TV input (Left/mono) so that u can only hear the center channel volume thru TV and all other from speakers even the LG is working..
[email protected]
www.kanny-sounds.blogspot.com
Jan 24, 2009 | LG LHT734 System
The speach during a movie sounds muffled
Please download Instruction Manual of DAV-DZ260 from Sony Support and go to page 25 and select appropriate sound option.
The disc in player doesn't match with current sound selection thats why you hear muffled sound.
Thank you.
Dec 16, 2008 | Sony DAV-SA30 System
Bose 123
Reset the system by unplugging the power cord and wait a minute before reconnecting power. The vocals will return. You should also contact Bose to see if your system needs a software update.
Oct 21, 2008 | Bose 3 2 1 GSX System
LX3000D DVD Digital Surround System
the dvd player has a strip that comes from the lens to the board have that checked out by a yech probably it is broken or needs to be cleaned.
Mar 07, 2007 | Philips LX3000D System
Aiwa AVJX 5 System Logo
221 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
