FixYa.com
Tags:
Acer AL2671W 26 in. LCD Television
TV losing its channel memory (by 6 users)
posted by old phil on Jun 16, 2007
Each time after I turn off my Tv it loses the position of all channels, so BBC 1 moves from channel 1 to channel 20, ITV 1 from channel 3 to channel 23 etc.
I have tried re-setting the channels, but as soon as I turn it off, it loses the position, always as above. Also I note on the menu, the country of use changes from the UK, to Austria, which just happens to be the first country on the list !
Can anyone help so I don't have to reprogramme the Tv each time.
Many Thanks Phil
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by jules227, posted on Jun 18, 2008
i am having the same problem so a solution would be great
Comment by Guest, posted on Feb 14, 2008
Same problem - anybody got any idea yet as to how to correct?
Comment by Guest, posted on Jan 09, 2008
I have same problem
Comment by robinhood, posted on Jan 02, 2008
I am facing the similar problem so please help me to solve the problem
Comment by kalem, posted on Dec 28, 2007
I've also got a AL2671W with the problem, that all the channel settings faal back to certain default values. I haven't seen on any ACER site, that there is a new firmware or gonna be and neither how it should be "installed" on the TV. So, I would be pleased to hear, if there are some news.
Best Solution
posted on Aug 24, 2007
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This is a known issue - Acer have a firmware update that resolves this issue
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Dec 15, 2007
Thanks for Trying (70)
Guest
Guest
Rating: 0%, 0 votes
I have the same pb with my Acer TV, I had 3 Acer laptop and each failed for different reasons! NEVER buy an ACER if you can help it!!!!!! ACER is cheap but never works longer than 18 months... ACER is worth crap!!!!!
Solution #3
posted on Feb 16, 2008
Not Rated (0)
erikfromrdam
Rating: 0%, 0 votes
Call Acer.
I had he same problem, Acer sent to me a technician who uploaded new firmware to the TV and in about 10 minutes the problem was solved.
Uploading the new firmware goes through a specific interface so unfortunately you can't do it yourself
Can you Help with these Flat Panel Televisions problems?
flat screen turns green
seems our flat screen tv when... Answer This...
acer tv
hi just wondering if you can... Answer This...
Acer AL2671W stuck in standby
Hi Tv Tech This Acer LCD TV is... Answer This...
acer 26 inch screen turning...
at first i had to keep powering... Answer This...
need help pls
Hi, I also have the same Acer... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
