Question about Gateway 4026GZ Notebook
Boot up menu restart; will not power
I had just turned on the laptop, it wasn't plugged in. It had been charging for about an hour. Ten minutes after I turned it on, it shut off. I plugged it in, and it got half way through booting up (The Windows XP waiting screen) when it shut off again. Waited a few minutes, and the same thing happened.
Decided to leave it and let it charge. The green light was constant, until about 5 minutes later when it started blinking. Same thing happens no matter what outlet. Tried it a few more times, same turning off problem. Unplugged it and left it for a couple of days. Now the green light won't come on at all, and neither will the laptop.
Any help would be much appreciated. :)
  • righthereinh Jan 15, 2009
    I tried that, and half way through it booting up it shut off again.
  • 72 Answers
Boot up to the safe mode screen & select last known good configuration.
Posted on Jan 15, 2009
  • Muggs01
    Muggs01 Jan 15, 2009
    are you getting a blue screen??
My i pad is stuck in sleep mode
Perform a hard reset: Press both the Power and Home buttons and hold them down. Keep holding both buttons down until you see the Apple logo appear on the screen. The logo should appear between ten and twenty seconds after you start holding the buttons. After the Apple logo appears, your iPhone or iPad will boot back up normally.
Charge your iPhone: Connect the iPhone to the iPhone's USB power adapter and let it charge for at least ten minutes.
Get iPhone into Recovery Mode: Turn off you iPhone and just plug the USB cable into computer > Hold the HOME button when you connect USB to iPhone > Release the HOME button when you see the iTunes logo.
The Most Common iOS 9 9 2 1 9 3 9 3 3 9 3 4 Problems and Solutions
Aug 17, 2016 | Apple iPad (16 GB) WiFi Tablet PC
So my computer randomly went to a boot menu and from there it shut down. since then, I wasn't able to turn it back on. how do I turn my gateway ms2370 on?
Try , removing battery , press and hold power button for ten to twenty seconds , reconnect battery , connect mains and try to restart , doesn't sound good though
Jan 08, 2015 | Gateway Computers & Internet
I need to know how to use my new laptop battery correctly.
The first time you charge the battery allow 12 to 16 hours, after that 2 to 4 hours or when battery is charged. If you go on battery frequently drain it right down before charging it, this will give the maxi-um performance and longevity.
Mar 16, 2011 | Computers & Internet
2005 e machine laptop m622uk8x wont turn on after removing battery and reinserting it and now all the lights are on and it wont turn on
hold the power switch down for ten seconds then remove the battery hold power switch down for 30 seconds replace the battery hook up the charger to run on external power let charge for five minutes then restart if this dont work have to reset the bios by removing the motherboard battery for 2 minutes then startt
Nov 04, 2009 | E-Machines M2105 Notebook
MEDION MD96640 - plugged in, not charging
There is a possibility that the battery is defective.
Turn the laptop off and remove the battery and AC power. Clean the brass contacts on the battery and the laptop.
Plug in AC power only, boot the laptop up without the battery and go into the BIOS and set the BIOS to default settings. Save the changes and let the laptop boot into Windows. Once in Windows power down the laptop again and remove the AC power.
Reinsert the battery and AC power and boot the laptop up. See if that has helped.
Good luck.
Sep 21, 2009 | Computers & Internet
My netbook wont boot, i turn it on and i will hear the fan but nothing else, i was using it everything was going well, the batery ran out and it went into sleep mode, i pluged it in and since then i canot...
Leave it plugged in for about 10 minutes. The battery just needs to charge a little more. Then you can come out of sleep mode.
If it is locked in sleep mode. Just hold the power button down to shut off the computer. Let it charge, you can now reboot, and keep charging after about ten minutes.
Jun 28, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 2920 won't turn on, although plugged in with battery
First of all, what I'm about to tell you are general troubleshooting techniques - I make no claim that they will fix what you describe, but they may help lead you to a solution.
  1. Unplug the AC adapter and remove the battery
  2. Plug in the AC adapter and attempt to power on the laptop
  3. If it doesn't power on, see #6 below. If it does power on, but doesn't boot the OS, restart - pressing [SPACE] as the first Windows splash screen appears. When prompted, choose to delete the hibernation file and start a system boot.
  4. Shut the system down, disconnect the AC adapter, reinsert the battery, and attempt to power the laptop. If it doesn't start we know, at the very least, there's a battery problem.
  5. Plug in the AC adapter. If it shuts down immediately, or won't power back on after a shutdown. . .
  6. . . .there's a problem with the system board, probably the ciruitry associated with charging the battery.
I hope you 'see the light'. Good Luck!
Jun 15, 2009 | Acer LXA3706003 Notebook
Satellite a300 wont install windows (brand new)
turn off the computer and disconnect the battery . wait like half an hour. put it back in you have to wait a few minutes for the battery to finish charging then turn it on . this should help. the menu will pop up after you type your password in .
Mar 15, 2009 | Toshiba Satellite A300-0CF035 Notebook
Gateway 4026GZ Notebook Logo
131 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
