Question about Kenmore 24032\24036 Top Load Washer
Sears kemore elite top load washer won't drain, loud squeely nois
This machine was purchased in 2000, not sure the modle. It was working just fine with the first load i did today. It filled up, washed and now it won't drain. There is a loud squeely noise on all of the rinse cycles.
  • nancyl51 Jan 15, 2009
    This machine is a Quick Pak II if that is of any difference
  • nancyl51 Jan 27, 2009
    danromarris -- Hit the nail on the head with this one. My man had the machine apart for a week and couldn't figure it out. We were about to call the repair man and i found this site. I didn't mention to him what I did until I got this response, he was so thrilled... THANK YOU DanRomarris ... Thank You FixYa, oh by the way it only cost 13.00 to fix.
    Novelist:
  • 101 Answers
You motor coupling is broken. It's a cheap part though and an easy repair. The motor coupling sits between the motor and the transmission and is what spins the transmission when the motor spins. It breaks from age or from over loading the machine too many times. If you want to replace it on your own it is simple, unplug the washer and tip it back. The motor sits right in the front. You will see the pump on the front which you will want to take off. Just pop off the clamps holding it on with a flat head screw driver. Don't take the pump off the hoses just push it aside. Next unplug the wires from the motor. There are two clamps holding the motor up. Remove the screws in the clamps and then pop the clamps off with your flat head. When you do this hold onto the motor, when you get the first clamp off the motor will drop and you don't want to smash your fingers. The motor coupling will come off with it. Put your new one on, (it only goes on one way) and put everything back together. You will back to as good as new again. You can get a motor coupling for around 10 dollars from your local appliance repair shop, they are very common and are always on hand. Let me know if you have any other questions and if this was helpful to you. Good luck and I am glad that I could help you.
Posted on Jan 22, 2009
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
Jan 23, 2014 | Sears Kenmore Elite 4.5 cu. ft....
Noisy when in spin cycle
This could be the drum baring and probably will need professional engineer to do it.
Jun 01, 2017 | Kenmore 24032\24036 Top Load Washer
My kenmore elite washer model # 110.24082200 is leaking from bottom. No visible leak from back panel acces...
my kemore whasing machine model10010 .25864400is not drain all c los left sam wather in dram and sound of water pamp like cenot turne tenks Bruno
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
How do i open the top of a kemore elite 110.24982300 where the controls are. I think I need to replace the board
First, see the Sears parts site for your washer: It has diagrams of all the major components along with parts, numbers and Sears prices.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24982300&pathTaken=partSearch
Next, see the following for how to release the console and pull the cabinet if necessary,
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=cd522bc789a1c2dfd6239645284bf1ff
Finally, see the following Whirlpool / Kenmore Service Manual for top load, direct drive washers. It has a complete description of how the washer works along with troubleshooting sections.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
You don't say what the problem is but most problems with these washers can be traced to either:
A faulty LID SWITCH (the Whirlpool manual has a description of how to bypass the switch to test it)
A faulty Motor coupler
Worn clutch,
or if it simply won't spin and the Lid Switch tests ok, a broken Neutral Drain Assembly.
Jul 09, 2010 | Kenmore Washing Machines
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite shaking during spin cycle
Moved a Kenmore Elite and when we put it back in place it vibrates loudly. We tried leveling it and that has not worked. Any ideas?
Sep 27, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Front Load Washing Machine
warranty is free of charge the only they may charge is material they use .
Dec 14, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore elite canyon capacity top load washer
check lid switch make sure its makeing contact right should hear it click
Sep 02, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 24032\24036 Top Load Washer Logo
43 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
