Question about Creative Labs WebCam Live!
No thanths - Creative Labs WebCam Live!
    Sniper:
  • 54 Answers
Ok!!
Please rate me!!
Posted on Feb 02, 2009
49 FF81 error on HP Laserjet 3035xs MFP
49.XXXXX ERROR To continue turn off
then on
A critical firmware error has occurred.1. Turn the device off, and then turn the
device on.
2. Go to www.hp.com/support/
LJM3027mfp or www.hp.com/support/
LJM3035mfp to check the latest
firmware image version. If the latest
firmware image version is newer than
the one installed on the device, upgrade
the device.
3. Try printing a job from a different
software program. If the job prints, go
back to the first program and try printing
a different file. If the message appears
only with a certain software program or
print job, then the error is in the software
program and not in the device. If the job
fails to print using a different software
program, then turn off the device and
disconnect all cables that connect the
device to the network or to a computer.
4. Remove any DIMMs and EIO cards, and
then turn the device on.
5. If, after removing DIMMs and EIO cards,
the device behaves normally, turn off
the device and reinstall DIMMs and EIO
cards one-by-one, turning off the device
off and then on again each time you
reinstall a DIMM or EIO card. If a certain
DIMM or EIO card causes the message
to reappear, replace the DIMM or EIO
card.
6. Reconnect all cables that connect the
7. If the message persists, replace the
formatter (see Formatter on page 116).
Apr 03, 2012 | HP LaserJet M3035xs MFP All-In-One Printer
I sold an item on Ebay.But Before I gave the customer a shipping charge.he payed througth paypal an amount which was less thanthe fee which the Post office charges.Because the actual fee is greater he...
FIrst you need to check your site preference if you allowed the buyers to edit the payment totals, if it is set up as yes you will need to disable it.
well, the buyer should pay whatever amount of shipping that you have placed in your listing. If the buyer will fail to do so, you can report this to Trust and Safety by using the link below
http://pages.ebay.com/help/contact_us/_base/result_3_6_10.html
click the email us link at the bottom
It will be your discretion on what you can do about the buyer, you can issue refund and then add the buyer in the block bidder buyer list. Unfortunately, this buyer can still leave you negative so please do be careful in dealing with this type of buyer. You can grant the buyer's wish to cancel, file a cancel transaction and you will get the final value fee credit.
In the future, you may want to add a shipping table in your item description so that buyers will see it before they purchase your item.
I hope this helps you a little.
Aug 14, 2011 | eBay Auctions
I don't know the meaning of 49.ff04 error code
device on.
the device.
card.
formatter.
Jul 01, 2011 | HP LaserJet M3035 MFP Printer
Garmin 260w will not power up weve not used it in a while
Sounds like a bad or low battery. Do you have the Garminapproved charger / car charger?? You may have to send your GPS in for batteryreplacement or try this: There are three ways to charge the internal battery in yourautomotive GPS unit.1 Use the provided vehicle power cable that came with your GPSunit. The unit will charge while powered on and using the device as wellas when the GPS unit is powered off and plugged into a running vehicle. About 3hrs for a full charge. If the unit will not charge in the vehicle, check thefuse in the power cable for the unit and the power outlet in thevehicle. Use an AC power adaptor. Some units come with thispower cable to plug the GPS unit into a wall outlet allowing the GPS unit totake a charge. For units that do not come with this cable, one can bepurchased from Garmin's onlinestore. For most units, the final way of charging the battery is toplug the GPS into a powered on computer with a USB cable2. This method ofcharging will be a trickle charge and it may take longer (like a full day) thanthe other two options, however it will still charge the battery. A USBcable is provided with a few GPS models. For those that don't come with thiscable, one can either be ordered from the onlinestore or you can use a standard USB to mini-USB cable that fits the unitand plugs into your computer. 1 - Please note that temperature can play an effect on thecharging of a device. If the battery registers a temperature of 0°C and belowor 45°C and above (32°F and 113°F respectively) then it will not charge. Whenconnected to external power it will only be operating off of external power. 2 - The Quest® and Quest® 2 will not charge using a USBcable.
Dec 16, 2010 | Garmin nuvi 255W GPS Receiver
I INSTALLED THEM YESTERDAY AND I AM NOT GETTING ANY SOUND OTHER THANTHE POP WHEN I TURN THE POWER BUTTON ON AND OFF. HELP
Make sure that the small jack is connected to "audio-out" on your computer's sound-card (not "audio-in" and not "microphone-in").
Try connecting the speakers to an iPod - you might not get much volume, but you should get some, if you maximize the speaker-volume.
May 14, 2010 | GE HO98010 Computer Speakers
I have a Hotpoint Model HDA 110S-45WA. I have
If the flecks are as thin as a paint film, then they are most likely old dried-up food and garbage debri that has lodged itself in the crevices of the water jet paths. But, they usually only show when the dish washer sits for a long time unused, and then after such period, when you begin use, these pieces begin to flake off and of course show up. hey eventually stop. If it is pieces that are hard and rather thick, then it icould be shavings from the pump/grinder assembly within the dishwasher sump (pit ) area, and this is telling you that there is something lodged down there,or something is wearing loose and most likely there is some nosie associated with this (other thanthe normal running noise). Goodluck, Macgivor
Jan 02, 2010 | Dishwashers
JR3050T blade lock lever is stuck
Put a blade in it.
This will release the locked open feature.
Dec 30, 2009 | Makita JR3050T Recipro Saw 9 Amp
1993 Jeep Cherokee: hissing/weak brakes
If you are talking about when you push the pedal you hear an air noise and the pedal is real hard to push then you most likely have a bad power booster. If your pedal is weak and goes low to the ground you most likely have a bad master cylider as well. Best to just change both. For that year model shouldnt cost much and not hard to install.
Jul 11, 2009 | 1993 Jeep Cherokee Country
Brand new and will not take a charge keeps flashing red and green
Well Honestly, it says Hannah friggin Montana on the front of it and it's soposed to be an MP3 Player. I Would say that it's just a POS and there is not much you can do as it has a internal Lithium-Ion battery. Personally you can do one of these two things: First, Take the hannah montana MP3 Player and smash it against the ground, while making a great video for youtube :). Second: Find the Recipt, Return it to target, get your daughter somthing she would really love and might work good for her, as well as being ecinomial in price which is an iPod Shuffle, which an older model (which Personally I think is better thanthe new model) intodays economy can be found for as little as 40 dollars, and is somthing that she can use for longer than two days :)
Apr 10, 2009 | Disney Hannah Montana MP3 Player
Plasma tv connection to pc
when you say you have even changed the settings to pc...do you mean you have used PC..to try connect...through settings..??
I would have thought on the remote there is a button for setting up the Plasma TV? you checked to make sure there isn't a menu where you can tell the TV its connected to a PC??
It may be you will have to switch between the two. My reason is that on my TFT..there is a menu....when I check the list..there is an option to connect to PC..AV1 AV2.
With your lead connected you should get something?
hope helps
Feb 13, 2008 | Computers & Internet
Creative Labs WebCam Live! Logo
18 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
