Question about Tappan TGF363 Gas Kitchen Range
Takes hours for my tappan gas range to light and bake
My range stays on preheat for hours and does not heat and then all of a sudden it will light and work
  • 375 Answers
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Posted on Jul 15, 2010
I tried to cook a frozen pizza in my Tappan electric range last night (which required it to be preheated to 400 degrees) and it would not preheat at all, even after about a 3 hour wait. I just turned up...
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5153992&diagram_id=1251523#d1251523
your looking for part number 67 on that part breakdown
it is the bake element and if you inspect it im sure you will find it cooked or broken
befor you actually order the part take the unit out
unplug it
and inspect your wire connections to both sides of the element
Oct 17, 2009 | Tappan 30IN ELEC IGNa Oven
Tappan gas range TGF364 not heating properly
try changing oven senso located in the oven cavity (upper right or left). its approximately 4-6" long and has a plug-in on the back of the oven
Mar 11, 2009 | Tappan TGF364AS Gas Kitchen Range
Oven controls
those failure codes usually mean the oven sensor is out of range or has an open circuit.
you can replace the sensor for about 50-75 bucks and that will allow the oven to heat properly again.
you wont need to do any reseting or clearing of the code, just fix the problem and that code will go away.
Jan 14, 2009 | Tappan TGF320 Gas Kitchen Range
TAPPAN gas range model 30-3991-00/03 oven won't work.
the button your holding is the switch that tells the board that the consumer whats to bake.so if holding the switch causes that message to work[or oven to heat] and letting go of that button ,then no work .its that button ,but its all part of the board .just that part of its funktion is broken.,if it was lets say your oven ignitor or oven gas safty valve ,the board/oven control[the one with the button]would continue to try after you have selected bake [pushed button]or would give error code.hope that helps you. God bless you , tom
Jan 05, 2009 | Tappan Kitchen Ranges
Oven makes an exploding sound when put on "bake" smell of gas
sounds like the oven valve is leaking slightly. just as a precaution i wouldn't use it till you can get a repair man out there.
Jan 02, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan Millennia range's baking component doesn't work.
Your ignitor has gone out or is no longer drawing enough current to open the gas valve. Replace the oven ignitor and it will fix your problem.
Nov 26, 2008 | Tappan TGF320 Gas Kitchen Range
Preheat worksoven wont bake
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Nov 06, 2008 | Tappan 30IN ELEC IGNa Oven
Oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Mar 26, 2008 | Kitchen Ranges
Oven
sounds like a bad ignitor, sometimes lighting and not relighting during extended cooking time. dies it take longer than a minute to ignite gas? more then 10 in to preheat? smell gas while cookin?? all signs of a bad bake ignitor
Mar 08, 2008 | Magic Chef CGR1110 Gas Kitchen Range
Oven takes up to 25 min. to preheat
I would suggest looking at how long before the bake burner ignites. If taking longer than 5 minutes before it ignites, then you are looking at a possible bad ignitor. The ignitors just don't last more than 5 yrs with regular use.
Jan 06, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan TGF363 Gas Kitchen Range Logo
115 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
