Question about Akira ILT-260W Television
Akira tv 21 slim pure flat CT-21 CSL 5AT-TT ,SCREEN LUCKED
Wwhile,tvonhotel mode,and av lucked on;and change
vidio to ch+ then,look screen lucked,remote not working,any swiss tv not working ecept on and off, thanks
Saya punya tv 21akira slim kadang hidup-mati semua tegangan drop tapi kadang bisa hidup normal
Posted on Aug 05, 2009
Akira tv help to adjust tint too much red on screen
What is the exact model number to your Akira TV? Provide more details please. http://electronicshelponline.blogspot.com/. Check this link. It has repair help to Akira TVs. Pull up older posts.
Jun 06, 2013 | Televison & Video
Screen changes color from white - black - red - green - blue. The entire screen changes on it own. Nothing else on the screen.
push the vol up and then the vol down on the side of the tv or ch up then ch down, the set is stuck in a factory mode, this will clear it.
Aug 19, 2011 | Philips 37PF7320A 37 in. HD-Ready LCD...
I have a 42inch sharp aquos LCD tv and there is no power. The power button keeps blinking. There is no picture and sound. What is the fix to this problem.
Power problem are cause by many reasons, i.e Power supply circuit, Lamp driver circuit and most often the TV detects an error cause by power surges. To protect TV from further damage most LCD TV have protection circuit built internally. If this is the reason of your LCD TV not powering On, an error data must be reset back to zero.
To change data you will need to access the service mode and change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV * Press and hold the {VOL -} + {CH+} buttons located on LCD TV unit (not in remote control) Note: If above didn't work, alternately use (VOL -) + (TV/AV input) buttons located on LCD TV unit (not in remote control) * While holding the above buttons, plug in the TV. * The TV will turn on with the "K" or "K123" appears om screen. * Use {CH+} {CH -} buttons to go and display the service menu. Note: If above didn't work, alternately use (VOL -) + (CH -) buttons. * Search for "LAMP ERROR menu" from the displayed service menu by using "up or Down cursor" from remote control, or alternatively use "CH - or CH+ to select "LAMP ERROR" * change it to zero (0) value, using {VOL+} or (VOL -) on remote control. * Turn the set off to exit the Service Menu.
Jul 03, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV dead other than green flashing light
The problem might be cause by lamp error, need to access the service mode to change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV
Jul 03, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Hi i have an old bush crt 32 tv .the only buttons on the front is the vol & chan. the remote isnt working can i change to av
Hi
If your external equ is connected with a full 21 pin scart lead, to a A/V socket switching the external equ on off should tell the tv to sw to a-v . when external unit is switched off tv will return to tv ch,s . Hope this will help regards windyhouse
Jun 01, 2011 | Televison & Video
Problem with JVC CRT TV (slim) with screen to have red color at the lower left (facing the TV) corner and a green color on the upper right corner of the screen. Sometimes while watching TV shows, the upper...
There is strong magnetic field around the TV. This may be due to the tower speakers or any portable radio kept close by.
Re orient the TV try switching OFF / ON at the intervals of 30 minutes. The built in auto de-gauser will correct the problem. In cable TV program if the picture is OK, nothing wrong in the TV.
Check with a different CD.
May 19, 2010 | JVC AV-21QMG3 21" TV
TELEVISI
you need to remove back cover and check for possible burn parts, take note for the board control # for the replacement.
Apr 13, 2010 | Akira HPT5001D Television
Tv/video mode with no remote
you should have a menu button on the
frount of the tv press it and then select
with the (ch up) (ch dn) to highlight the
input/sorce or ant select with the enter
button then (ch up ) ( ch dn) highlight
video 1 or 2 press enter .
If this was not helpful tell me the
model # and look it up on my data base.
Rob
Sep 21, 2009 | Microsoft Xbox 360 Console
Broke HDMi connector on TV
If you are talking about the part connected to the tv, you need a new part. Investigate ! In the meantime use a S Vidio plug, or the red, white and yellow cables to get you going.
Sep 19, 2009 | Televison & Video
Cant get vidiogame channel
look on the remote for av/tv or input select av input
May 02, 2009 | RCA F27641BC 27" TV
Televison & Video Logo
629 people viewed this question
Top Akira Televison & Video Experts
Electro Med Services...
jasbo
jasbo
ray gallant
Are you an Akira Televison and Video Expert? Answer questions, earn points and help others
