Question about KitchenAid KSRD25FK Side by Side Refrigerator
Superba Fridge 1998 KSRS25Q???WH01
We inherited this fridge recently - it was seemed to just need a good cleaning - so we did that and hooked up the water line to it and nothing. No ice, no water in the door. The fridge is cooling and the freezer is very cold, but we can't figure out if the ice maker needs to be completely replaced or what. There is water in the line, but just not pulling into the fridge.
If we can't fix this, what is this fridge worth if we wanted to sell it? If we can fix it - what would it sell for?
Thank you!
We had this problem with our ice maker. We could get water through the door water dispenser but it stopped making ice.
We had read that the line could be frozen and that was the case.
The easiest way to thaw it out was to remove the two screws holding the water hose elbow into the back of the freezer (pull the fridge out away from the wall to access it). It will come out with about a 5-6 inch long hard plastic tube which goes through the back freezer wall and joins with an aluminum tube (which may also be plugged with ice) that reaches the ice maker. Looking inside the tube we could see the ice blockage. Heating it up with a hair dryer made the ice plug drop right out. We had tried to thaw it out by heating the tube inside the freezer, but the ice plug was actually in the wall part of the freezer and we wouldn't have been able to thaw it out from the inside (short of shutting the refrigerator off). When the heat was applied...a 3 inch plug of ice dropped out of the tube, and there was even a very small piece of ice blocking the elbow part. We wouldn't have been able to thaw that area out without taking it apart.
Posted on Feb 16, 2011
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
Kitchenaid superba making noise
Check the fan on the back and blow air through it to clear any dust accumulation.
May 04, 2017 | KitchenAid Superba KSRG25FK Side by Side...
KSCS25FJSS01 - The water dispenser line from the solenoid is cracked about 18 inches from the solenoid, before it enters the back of the fridge. It seems easy enough to fix as long as i can get some 5/16...
Good day,
The line runs from the solenoid, into the fresh food compartment where a cooling tank is located behind the crispers, where it is precooled so your dispenser doesn't feed you warm water.
It then comes back out and travels to the door.
Nov 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
Superba fridge 1992 occasonal water under bottom freezer drawer
you have a frozen defrost drain. in order to fix this you will need to remove all shelves and basket out of the freezer. then remove rear evap cover. one youve gained access to this area you will see at the bottom of the coil an aluminum pan that most likely wil be iced over. clear away this ice then try to flush out the drain line with warm water. sometimes its neccessary to force water into drain line with a large syringe or turkey baster. this should fix ya up.
good luck and thx for using fixya Peyton
Jan 27, 2009 | KitchenAid KSRD25FK Side by Side...
Fridge Filter
the filter islocated behind the toe grille, ordering instructions areprinted on the filter itself, and resetting the light is a matter of holdingin the button for 3-5 secs, its filtering your water and ice
Jan 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Daewoo regrigerator - Multi flow -
Go here at the bottom you will find yhe manual you need the model # though.
http://www.e-daewoo.com/owners_manual.asp
Good Luck And Please Rate FixYa!
Dec 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid superba door problem
HAVE YOU TRYED ADJUSTING THE TOP HINGE?MIKE
Oct 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba 48 Refrig
hi, is the fridge cold enough.pull fridge from wall, remove back panel. clean all coils. this should solve the problem. thanks the appliance doc
Oct 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Superba kitchenaid fridge not very cold, freezer is fine
do you have any frost build up it the freezer back wall... fan blowing in freezer and in back ...condeser coils clean... if all the above is ok ...must have temp. sensor or themostate cold control problem
Sep 02, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSRD25FK Side by Side Refrigerator Logo
1,185 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
