Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer making loud noises
When I turn on the dryer it sounds like a heavy piece of something inside hitting every time it turns. This happens even when there is nothing in the dryer?
  • 87 Answers
You need a new drum roller in the back of drum housing.
Posted on Jun 17, 2007
SOURCE:
What is making mywhirlpool/admiral electric dryer sound loud and thumping noise
You dryer belt may be shot and a piece of rubber is missing making it jump while working. Needs replacing before it completely quits. It will eventually just break apart.
Apr 13, 2015 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Haier dryer makes ticking noise
The ticking noise could be either a piece of the belt hitting as it spins around, it could be something stuck in the drum that is hitting it as it turns too, or it could be the electric motor making the noise. Either way it sounds like you may need to tear it apart to see what's going on.
Jul 18, 2014 | Haier HLP140E Electric Portable Dryer
Whirlpool dryer leq8611lw0 shakes violently and makes loud noise
Something must be inside the blower wheel. I cannot imagine why it would shake like that. This dryer has 4 wheels instead of 2 so it oughta be stable. The only thing to do is get inside the machine and see what is causing it. The dryer with a filter inside is also sometimes known as a series 90 dryer. Look for some series 90 dryer videos on youtube. Like this crappy one I made:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 22, 2014 | Dryers
ELectric dryer on any setting makes a "Rubbing or squealing"sound when turned on and inside "drum" is rotating. Does heat up, just very loud/ Whats wrong?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 21, 2010 | Frigidaire Electric Dryer
When Dryer is on it makes loud banging noises almost like the cylinder is hitting the sides. It also seems to be excessively hot even set on low heat, and has an almost burning smell inside after running.
heatman101
Sep 15, 2010 | Asko T700 Electric Commercial Dryer
The dryer is making a loud noise when running. the drum is turning. almost sounds like something is rolling around under the drum.
heatman101
6565ggf
Feb 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Drum not turning-very loud sound coming frm dryer when turned on
There could be multiple problems with you whirlpool dyer depending on the type of noise you are hearing. If the noise is a low grumble or loud buzzing sound this could indicate a bad motor. Which could explain you not hearing the drum turning. If however you hear a grating or grinding type noise but the drum is turning, this could indicate that something is rubbing or has become jammed inside the blower fan that circulates the air. if this is the case it too may have to be replaced. Also the drum can sometime come off the drum support rollers at the back of the dryer, but this is very uncommon, and only happens if they are very worn or broken. This can easily be diagnosed by a technician and if the motor is fine, will cost little to repair.Hope this helps.
Thanks
Nov 07, 2009 | Whirlpool LER4634J Electric Dryer
Drum making intermittent sqeaky noise for 3-4 minutes then stops
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
Clunking grinding sound
It sound like there is change or hard object in the inner dryer tumbler fins Not sure what model or make the dryer is need more info please.Maytag inglis??????
May 07, 2009 | Dryers
Dryer appears broken, heard LOUD sound from other room (broken belt?)
gjtgjtgjtgjytgfjytjytgjtgyjtgujytgujttjtytgjtjytgjtgjtyjtgjytjytjgjykykuiykyyuuxuxxudkdssyzxhclds dskhsdlhkshkchdsflfhlhsdlo
Apr 14, 2008 | Kenmore Elite HE4 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
95 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Craig Butler
Craig Butler
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
