Question about Sony PlayStation 2 (PS2) Console
Playstation 3 console lights stopped working
The system doesn't show lights and doesn't come one. I plugged it in to several outlets to make sure there was electricity. Is this something that can be fixed?????
The bulb has probly gone or the fuse in the plug has
ray yarnold you can tell me wether i was write at avfc123rayyarnold@hotmail.co.uk
Posted on Jan 15, 2009
PSP Orange light when charging but battery wont charge
Your Battery may have developed dead cells and is no longer capable of charging.
Replace battery with new one
Jun 28, 2013 | Sony PlayStation Portable (PSP) Console
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
My Ps3 Wont Turn On It indicates on stand by mode(solid red light).i pressed the power button; it wont turn on and it doesnt work or even beeps. i also tried using the ps button on the contoller.same...
Hi Shiman,
Are you seeing any flashingred/yellow lights?
If so this is the red lighterror and you will find that is why the system will not turn on.
Why Does It Happen?
The GPU and the CPU are the 2 main chips in the system and they deal with allof the number crunching however they can get very hot and if they loseconnection the system will either freeze up or turn off and give you the redflashing light.
How To Fix?
The key is stopping the heat build up and you can either send it in and theywill fix it for you.
Bear in mind that for the PS3red flashing light error you will be waiting for about 4 weeks and itwill also cost you $150 for the repair bill!
Other Ways To Fix?
You can also use a good PS3Repair Guide to fix it and this will show you how to stop the heatbuild up with a few household items.
Just make sure that you get a good guide there are some good ones out there!
Click Here For A CompleteReview Of All Available PS3 Repair Guides.
Hope this helps and any questions let me know?
Aug 13, 2011 | Sony Playstation 3 (PS3) Console
I updated my PS3 because it told me it would not run without and update and now it doesn't recognize the controller... CECHP01 used the latest update 3.66 (it asked for 2.76 or later.)
PS3's will sometimes loose their connection to the controllers. I have always fixed this problem with these steps:
1. Make sure the system is off (red light)
2. plug the control in with the usb cable
3. press the PS button in the middle of the controller (this will let the console relearn the controller)
4. once the lights on the front of the controller are not blinking red anymore, and have a single green light indicating which player the controller has taken, hold the PS button and turn off the system
5. once the system is off, unplug the usb cable
6. the controller should work without the cable now. (check by pressing the PS button to turn the system back on
Controllers will lose their connection to the PS3 when they die completely, during updates, power outages, etc. I don't know what exactly causes it, but I have had to do this process several times since I got my PS3.
Thanks,
John Vickers
Aug 12, 2011 | Sony Playstation 3 (PS3) Console
Went on vacation and left the PS3 powercord unplugged. Now it doesn't work, could it be the cable?
Hey there, a couple of things to verify here to get your ps3 back up and running. Do not worry about leaving your ps3 the whole week with the powercord unplugged, this is OK and should't have affected anything negatively.
1) Make sure that the powercord is well plugged on both ends: ps3 AND in the wall.
2) Make sure that the SWITCH is turned on (in the back of the ps3, there is also a POWER switch I/O). Turn it on by pushing on the I.
3) If it's still unpowered, try plugging the ps3 itself somewhere else in the house (to make sure it's not the power outlet)
Jun 23, 2011 | Sony Playstation 3 (PS3) Console
Will not power up
plug it in the wall outlet, make sure the main power button on the back of the playstation 3 is on so there is a red standby light on in the front
Nov 03, 2009 | Sony Playstation 3 (PS3) Console
Disk does'nty work on my playstation 3
If all games are like this then you might have a faulty system if it's only a few or one then it might be the disk. If it's not the disk then I don't know
Jul 22, 2009 | Sony Playstation 3 (PS3) Console
Playstation not receiving power
This could be a problem with your AC power cord, try these fixes. If they do not work you ca contact sony at:
www.us.playstation.com/Support/PS3
or
www.uk.playstation.com/help-support/ps3
  • The console might not be turned on. Turn on the console using the main power switch on the back of the console.
  • Make sure the AC power cord is securely connected.
  • Visually inspect the AC power cord for damage. Do not use if frayed, cut, or damaged in any way.
  • Confirm the wall power outlet is active (receiving power). Try a different power outlet.
  • If possible, test the power cord by connecting it to a different PLAYSTATION 3.
  • If possible, try another AC power cord on your PLAYSTATION 3.
  • If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PLAYSTATION 3 power supply and the PLAYSTATION 3 may need service.
  • Make sure the vents are not obstructed in anyway.
  • Make sure there is adequate ventilation for the PLAYSTATION 3. There should be at least four (4) inches of clearance between the air vents on the system and any walls, televisions, entertainment centers, etc. Otherwise the unit may not function properly due to what are actually environmental issues.
  • Jun 23, 2009 | Sony Playstation 3 (PS3) Console
    Sony PS3 will not power up -
    1. First check the power cable by removing it and then plugging it in again. You may find it is not pushed in far enough.
    If that is good then follow these steps
    I hope this helped
    cheers
    John
    Dec 01, 2008 | Sony Playstation 3 (PS3) Console
    Sony PlayStation 2 (PS2) Console Logo
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
