Question about Magic Chef MCD1311ST Microwave Oven
Shuts down for 5 minutes
My large Magic Chef (2 weeks old/ mounted above the stove) shuts down after 3 usage of making popcorn. Then it resets after 5 minutes. Help…
  • raj7274 Apr 21, 2009
    by accident I turned on the microwave not realizing there was nothing inside. Silly me.  Anyways it shut down as if power was turned off.  Happened before a few months ago and came back after 10 minutes.  Hoping it resets soon!
I have the same problem with my new magic cheff over the stove microwave oven. I call magic chef and they gave me the 800 number for the service center (1-800-775-0202). When I described the problem they told me to just put a plate under the popper and this wouldn't happen anymore. I haven't tried it yet but here's hoping.
Posted on Jan 20, 2009
  • Magic Chef Master
  • 9,086 Answers
I would first check that the installation is correct as per the installation manual / owner's manual and that the filters are installed properly and not clogged.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
All things considered, since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Magic Chef / Ewave see here or their contact page.
You can download owner's manuals for many Magic Chef models here.
Posted on Jan 18, 2009
I have a Magic Chef microwave MCO160UB. I was cooking on the stove (microwave wasn't on) and the fan came on as it has done before. After a few minutes, it shut off and is now completely dead. I...
If the microwave is above the stove, the heat sensors in the microwave
may turn on fans to cool it even though the microwave itself is not
running. It tries to save its life. It should turn off when the stove is not
heating it.
Aug 29, 2011 | Magic Chef MCO160UB Microwave Oven
Magic Chef Model #MCO160UW
Call 888-775-0202 Magic chef they will replace the part free of charge even if its not longer under warranty
Aug 14, 2009 | Magic Chef CMV1000B Microwave Oven
Popcorn Castastrophy !!!
You would have to remove the top cover and check to see if the main fuse is blown. Usually a 20 amp slo-blow. There are thermal cut out devices, they will reset when the unit cools, so plug it in the next day and see if the clock and power is back up. good luck, Dale
Aug 06, 2009 | Magic Chef Microwave Ovens
My Magic Chef over the range microwave won't even pop popcorn without shutting down. Was told to put dish on sensor but it still shuts down. Any answers?
Magic Chef customer support recommends placing a glass of water inside the oven to absorb some of the energy. It works for us..Jan 1, 2010
Mar 31, 2009 | GE JVM1653 Microwave Oven
MCO160UW goes dead after 3 minutes
I returned the item to Home Depot and they took it back no questions asked.
Nov 30, 2008 | Magic Chef CMV1000B Microwave Oven
Oven turns off
You are running the risk of damaging the Magnatron by doing this.
Check the packets you are using, you will have to reduce your power output.
This is because microwaves act by being absorbed by water. There is very little in popcorn and in fat. Once this has been evaporated, the microwave energy builds up (as it is still being produced - but not absorbed), and ends up cooking the magnatron itself.
I have seen countless posts on here after cooking popcorn!
More fun on the hob anyway - and cheaper to buy in bulk!
Jun 21, 2008 | Magic Chef MCD1311ST Microwave Oven
Magic chef over the oven microwave shuts off.
Is not normal for a microwave to shutdown after 4 minutes of operation.
From the info you are providing, It looks like the magnetron might be overheating causing the thermal fuse to shut it down until it cools down. There may also be a loose connection in one of the switches or a cold solder joint in the low voltage power supply.
I would suggest to check and make sure that the fans are functional, If always did; it could be that there isn't much air circulation where the appliance was installed.
Mar 03, 2008 | Microwave Ovens
Magic Chef MCO153UW
The cooling fan is a must!
Otherwise, the magnetron will be ruined, and that drives up the repair cost.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order parts here: https://www.mcappliance.com/partorder.aspx
To contact Magic Chef about getting an *authorized* servicer, see: http://www.mcappliance.com/contactus/contactus.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 06, 2008 | Magic Chef CMV1000B Microwave Oven
MCO160UW
It sounds like the magnetron is overheating and the magnetron-mounted thermostat is tripping.
This can happen if the internal cooling fan is not running - do you feel air strongly coming out the back or other vent?
If it has grease or other filters, be sure they are clean and not blocked.
Otherwise, the magnetron may be failing. Please post back once you've looked this over if you need more help.
Nov 02, 2007 | Magic Chef CMV1000B Microwave Oven
Magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Sep 02, 2007 | Microwave Ovens
Magic Chef MCD1311ST Microwave Oven Logo
516 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
