Question about Hunter Ceiling Fan Control Switch
Hunter ceiling fan
I have 3 Hunter 5 blade, flush mounted ceiling fans with two light bulb light fixture operated with a programmed remote control through each bedrooms original light switch. In two of the three ceiling fans, a light bulb burned out and now the remote will not work to turn on the fan or lights. We can turn the light on with the pull chain but when clicking on the remote to operate the fan, all we hear is a click and the fan will not operate. I've replaced the battery in the remote but this did not help. Any ideas? Mike
  • 5 more comments
  • Anonymous Mar 16, 2014
    how to replace light switch in emerson ceiling fan. It is stuck on the on position for the lights.
  • Anonymous Mar 18, 2014
    remote quit operating fan and light-changed battery in remote and all is well for a few days-battery went dead-changed battery and everything is fine for another few days now second battery is dead what are my options?
  • Anonymous Mar 22, 2014
    The remote quit working. I turned off the electricity, it would not reset. The remote does not work at all. The light works on the pull chain, the fan does not, no speeds. Can I bypass the remote?
  • Anonymous Mar 23, 2014
    Remote works fine for the light, I have no control over the fan
  • Anonymous Mar 25, 2014
    We installed everything ok then later light won't shut off with remote so used pull cord light went out turned off fan with remote now nothing works
  • Anonymous Mar 27, 2014
    fitted by an electrician so I know all is correct. fan was originally in another room and worked fine. moved it to the bedroom and the remote won't do anything
  • Anonymous Mar 28, 2014
    Am changing out the control switch on a hunter 3 speed ceiling fan. What is the color code.
  • 51 Answers
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Posted on Jul 25, 2007
SOURCE:
How to fix ceiling fan light
Make sure the light wire is connected to the receiver & bottom of fan.You should set the light to the on position when using the remote and leave it that way.
Sep 10, 2015 | Hunter 52" Ceiling Fan With Light And...
The ceiling light on my hunter will notcome on using the remote
The receiver may not be functioning, the bulbs can be burned out or the wire going to the lights can be disconnected.
Oct 21, 2014 | Hunter Sontera 52" Ceiling Fan with...
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
Dec 30, 2012 | Hunter 52" Ceiling Fan With Light And...
RECENTLY THE REMOTE AND THE WALL SWITCH WILL NOT OPERATE EITHER THE FAN OR THE LIGHT IN OUR HUNDER FAN. THE REMOTE HAS MODEL UC7848T ON THE BACK. I CANNOT FIND ANY NUMBERS ON THE BODY OF THE FAN. THE...
Hi Does the light fixture have a globe under the fan? What does the light fixture look like? Most of the light fixtures have small screw surrounding the globe that simply unscrew and the globe drops down. All fans are different and I will have to know what this one looks like. In the mean time I will look at some hunter fans on line and see what I find.
Jul 25, 2011 | Hunter 27187 Remote Control
I have a ceiling light that does not have a switch anywhere. Can a hunter 27185 remote control be used to control the ceiling light fixture only. There is no fan in this scenario. How should it be wired?...
Connect the lamp output wire of the receiver to the hot wire of the fixture, and the incoming hot wire to the hot input of the receiver. Be sure to insulate the fan output wire(s) so nothing nasty happens if someone presses the fan on button.
Check the remote control manual to see if you can use compact fluorescent bulbs. You probably cannot if this is a dimming lamp control; most CF bulbs flicker wildly if used with dimmers, and will not last long.
You can also buy remote lamp-only switches.
Sep 22, 2010 | Hunter 27185 Remote Control
The remote control works other than changing the direction of the blade. how do i manually change blade direction?
Look on the side of the Fan above the light fixture there is a little black switch you just need to switch it, make sure the fan is off before switching it.
Jan 11, 2010 | Hunter 52" Ceiling Fan With Light And...
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Apr 06, 2009 | Hunter 27187 Remote Control
Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Mar 15, 2009 | Hunter Low Profile III 20807 Ceiling Fan
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
1,212 people viewed this question
Top Hunter Dryers Experts
Joe Paxton
Level 1 Expert
Paul Bade
Craig Butler
Craig Butler
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
