Question about Indesit W 123 Front Load Washer
Washing machine fault
When i plug the machine in the red light comes on but after a couple of minutes the house sockets fuse , when reset the same thing happens again.
  • 247 Answers
This is usually down to the water heater element needing replacing (when the machine has filled up enough, it turns on the heater - and that's when the fault on the element takes the power out). To check, unplug the machine from the electricity supply and take the back cover off. In the middle of all the clutter, you'll see the large stainless tank that encloses the drum. Somewhere near the bottom of this, you'll find an oval plate with three terminals (a live, a neutral and an earth). Double check that the machine is unplugged, then remove the live and the neutral (these are the two that go onto slightly insulated posts). Leave the earth (the one that goes straight onto the metalwork) on. If there's any risk that the wires you've taken off are going to touch anything, tape them back with insulating tape. Now plug the machine back in and see if it will run. If it goes further into the cycle without blowing the house electrics, you've proved you have a heater element problem. Replacements are available off the net or from any local washing machine spares shop - expect to pay a little under £20. A.
Posted on Jun 16, 2007
Washer does not start, replaced lid switch, and timer still doesn't work. when parts mentioned were replace. washer did start and fill but then stopped.
Hello there and welcome to fixya
I am sorry to hear that you are having problems i will post some information on some more parts that need to be tested ok?
Washing machine is dead, wont start Obviously the first thing to check is that the socket is supplying power by plugging another appliance in such as a lamp. It is less likely to be the socket but you'd be daft not to check it out before calling an engineer as it does occasionally turn out to be a faulty wall socket. This is only necessary though if there are no led indicator lights lit up on your washer as any light that's on shows that the machine is getting a live and neutral supply from the socket.
The second thing to check is the fuse in the plug. Either put the fuse into something else and check the appliance still works or try another fuse that you know to be OK in the washer. Make sure you use a 13 amp fuse and never by-pass a fuse! If both of those are OK, then the most common cause for a washing machine that wont start is the door interlock, particularly if the mains lights on the washing machine has come on, but nothing works. However, the fault could also be in wiring to the door interlock or even the door catch not activating it properly, or the on off switch or the main control module. With some Indesit and Hotpoint washing machines even an open circuit heater or motor can cause the entire washing machine to stop working except the led lights.
You need to know what you are doing to trace this type of fault so if it isn't the wall socket or the plug you'd be better getting an engineer to trace it. Do not work on a live washing machine. Engineers should use a continuity test meter to trace faults with the washing machine unplugged and never test with a live washing machine.
Sep 24, 2011 | Maytag Washing Machines
Have a GE Select washing machine that won't start or operate ? Can you help ?
Hello there and than you for choosing fixya
Feb 06, 2011 | Washing Machines
Washing machine wont work at all
Mar 19, 2010 | Washing Machines
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
Candy GO1482 washing machine blows house fuse
u have an earth fault on mc caused by damp or water across the neutral check for water on electrical components
Nov 18, 2009 | Washing Machines
My Hotpoint 960 is 18 months old and has develped a fault where the mains light and programmer display flicker simultaneously, and the machine cannot proceed through the programme. It does not respond to...
Flickering lights might just be caused by loose wires in the mains plug on the machine's power cable. I would suggest checking that first - for some reason the neutral wire seems more likely than the others to come loose. There might be brown / purple marks around the terminal inside the plug if this is the case. Also try replacing the mains fuse in the plug.
While you are there you might also try plugging a normal table lamp into the socket you use for the machine - if the house cabling to the socket is defective the lamp should flicker too.
If neither of these ideas is productive, the problem would appear to be within the machine, so please ask again. Good Luck D.
Jun 29, 2008 | Hotpoint Washing Machines
Indesit WIXXL146 washing machine will not turn on
sounds like interlock or pcb try lock first as this is cheap to replace regards jason
May 08, 2008 | Indesit W 123 Front Load Washer
Red light padlock symbol? what does it mean
the padlock led indicates that bthe door is open or poss interlock fault, however since you said it now trips fuses, IF you are not electrically minded call an expert something could of become disconnected or moisture could of got into the machine and blown the module
Jan 09, 2007 | Indesit WA 125 Front Load Washer
Indesit W 123 Front Load Washer Logo
89 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
