Question about Home
Corrosion to chrome towel radiator
I have recently fitted new chrome towel ladder radiators to a house where I have installed new bathrooms, one of the radiators corroded and was oozing brown liquid from one of the cross rails about 5 from the bottom, I took it back to the supplier who changed it but said that the radiator is probabley connected to an open system???? I said that all the radiators that I have changed were fed from the CH header tank in the loft, the radiator that I replaced in Sept 08 has today started to corrode and leak once again about 5 cross members from the bottom yet the other 2 appear to be fine, my supplier still insists it is on an open system( what does this mean and how can I find out) if they are all fed by the expansion pipe surely they would all suffer the same fate. Could it just be a dodgey batch of radiators or a more serious problem?
  • 69 Answers
Your completely right mate about most conventional heating systems are open vented unless its a pressurised system..im a plumber and had at least 4 chrome towel rail rads that this has happened with,its a manufacures problem not yours,
send it back
Posted on Aug 09, 2009
Towel ring won't stay tight
Try Straightening The Bracket Inside Then Re Fit The Towel Ring
Jan 26, 2013 | Moen YB8086 Mason Towel Ring Bathroom...
G5rv lite installation instructions
A G5RV antenna is a popular ham antenna due to its cost, weight and ease of installation. The G5RV is a really a dipole type, that looks like a "T" with the top of the T as the main radiator consisting of a single conductor main radiator and the bottom of the "T" (also radiating on certain bands) consisting of a 2 conductor 450 - 600 ohm "ladder line" that terminates in a fitting that converts ladder line to a coaxial connector.
One of the most popular configurations is the inverted "V". Depending on the version of the antenna, the main radiator will be either 102, 92 or 51 feet long. The ladder line will be 32, 42 or 16 feet (respectively) in length and will require a coax feed length of 70, 70 or 40 feet minimum (again, respectively) to present the proper range of impedences to your manual or auto tuner (the G5RV REQUIRES an external tuner to present an acceptable SWR or impedence match to your transmitter on all bands).
The inverted V requires a mast as high as you can erect, located as close as centered between support sources (trees, buildings, etc.). Ideally, there should be enough room between the mast and the main radiator supports to allow the main radiators to be fully extended. Also, the ladder line should be able to hang straight down without being coiled on the ground at the base. This means you'd need a 32 ~ 42 foot mast at minimum.
The top of the mast will be needed to be fitted with an anchor or hook that will support the center insulator that provides strain relief, splits the ladder line and allows connection of the ladder line conductors to the single conductor main radiators.
Unroll the antenna on the ground. Connect the center insulator to the top section of the mast by the hook. Install "antenna lead stand offs" every 3, 4 or 5 feet. Secure the ladder line to the stand off to keep it from touching / wrapping around the mast.
Use UV resistance parachute cord to connect to and support the main radiator insulator, and pull the slack from the line, from a point as high off the ground as possible. Do the same to the other radiator, trying to match the height above the ground as the first radiator. Go back and forth between the two radiators (or have a helper - so each can be pulled slowly, and evenly together. Inspect the mast to be sure it is still straight. Loosen or tighten the radiator support lines as needed to allow the mast to stand straight.
Secure all lines, connect and run coax to the connector at end / bottom of the ladder line. and connect the opposite end to your antenna tuner connector labeled "ANT". Connect a short coax cable between the transmitter's "ANT" connector and the tuner's "XMIT" connector.
Set xmit power to 5 - 10 watts, transmit and operate the tuner - or set up your radio to use an external auto tuner. Tune for lowest SWR or reflected power. The internal auto tuner on many radios is only good for correcting up to a 3.0:1 mismatch or SWR. The G5RV will present mismatches far in excess of 3.0:1 on certain frequencies and bands.
Jan 12, 2013 | Radio Communications
Where can I buy a new illuminated on/off switch?
An electronics shop or auto parts store should have one but it might not be an exact fit. If the switch is stuck in the ON position you could just leave it and put a new switch on the line cord.
Mar 13, 2011 | Warmrails & Chrome Towel Warmer & Drying...
Replace thermostat
Two big hoses attach to your radiator. Look for the one that goes back to the TOP of the engine. There is a housing with two bolts in it that the hose connects to. Drain radiator, remove hose. Remove the two bolts. Remove the housing. Thermostat is inside housing or still on engine. It just pulls out. Remove any remaining thermostat housing gasket material from the housing and the engine. Install new thermostat. Should only fit in one way. Install new thermostat housing gasket and the housing. Reattach hose and fill radiator, leaving the cap off. Turn on the car and wait until car gets to warm condition. You will see the water start to move from the radiator to the engine when the new thermostat releases at the proper temperature. Replace the radiator cap and clean up, you are finished.
Oct 09, 2010 | 1993 Cadillac DeVille
Were is my thermostat in my 1997 eagle vision
REMOVAL & INSTALLATION
  1. Disconnect negative battery cable. CAUTION
    Do not remove the radiator pressure cap with the cooling system hot and under pressure. Serious burns from hot, pressurized coolant can result.
  2. Allow cooling system to cool completely. Place a pan under the radiator drain, located at the lower right side of the radiator. Open the valve to drain the cooling system to a level just below the thermostat. Do NOT drain the cooling system completely, unless the coolant is being changed. Close the valve.
  3. Loosen the radiator hose clamp from the upper radiator hose at the thermostat housing and if necessary disconnect the hose from the housing. Fig. 1: Loosen the radiator hose clamp from the upper radiator hose at the thermostat housing 88173p06.jpg
    Fig. 2: If necessary, separate the upper hose from the thermostat housing (it is not required) 88173p11.jpg
  4. Remove the thermostat bolts and housing. Fig. 3: Loosen the thermostat housing bolt with the proper size socket 88173p07.jpg
  5. Remove the thermostat and discard the gasket. Thoroughly clean both gasket sealing surfaces. Fig. 4: Separate the housing to access the thermostat 88173p08.jpg
    Fig. 5: Lift the thermostat out . . . 88173p09.jpg
    Fig. 6: . . . then clean the mating area 88173p10.jpg
    To install:
  6. Clean the thermostat housing bolts well. On any engine, bolts that thread into the water jacket are subject to rust and corrosion. A bolt with rust or debris in the threads can easily strip out the threads in an aluminum manifold requiring a time-consuming thread repair operation. Clean the bolts well and lightly lubricate before installation.
  7. Install the thermostat into the recess in the intake manifold. Place a new gasket, moistened with water, on the water inlet mating surface on the intake manifold.
  8. Install the thermostat housing over the gasket and thermostat and tighten the mounting bolts to 21 ft. lbs. (28 Nm) on the 3.3L engine and 105 inch lbs. (12 Nm) on the 3.5L engine.
  9. Connect the upper radiator hose to the thermostat housing and tighten the radiator hose clamp.
  10. Refill and bleed the cooling system.
Aug 19, 2010 | 1997 Eagle Vision
Small tear drop leak from chrome bathroom radiator, where the joint is, poor weld!
I turned off the radiator and let the leak stop, located the pin head hole, cleaned the tiny area with emery paper, put a spot of flux in the hole then applied a tiny drop of solder. Worked a treat.
Nov 08, 2009 | Google Chrome
Thermostat
  1. Disconnect the negative battery cable.
  2. Drain the cooling system.
  3. Remove the three bolts and position the A/C compressor aside.
  4. Remove the radiator hose clamp from the thermostat housing.
  5. Remove the radiator hose from the thermostat housing.
  6. Remove the three bolts and the thermostat housing.
  7. Remove the thermostat and the O-ring from the thermostat housing.
  8. Clean any corrosion or debris from the thermostat housing.
  9. Clean the mating surfaces.
  10. Inspect the thermostat.
To install:
WARNING Position the air bleed valve on the thermostat toward the top of the engine.
  1. Install the thermostat in the described position to the cylinder head.
  2. Install a new thermostat O-ring.
  3. Install the thermostat housing.
  4. Secure the thermostat housing with three bolts and tighten to 12 ft. lbs. (16 Nm).
  5. Install the A/C compressor and secure with three bolts. Tighten the A/C compressor bolts to 17 ft. lbs. (23 Nm).
  6. Install the radiator hose and clamp to the thermostat housing.
  7. Fill the radiator with approved coolant.
  8. Connect the negative battery cable.
  9. Start the engine.
  10. Allow the coolant to attain operating temperature (both hoses feel warm and the coolant is flowing through the radiator).
  11. Check for leaks in the cooling system.
  12. Shut off the engine.
  13. Install the radiator cap.
Short answer is that it is located in the housing that the TOP radiator hose is attached to at the engine block.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 05, 2009 | 2002 Chevrolet Tracker
1997 Town & Country Radiator Thermostat
2.4L Engine
See Figure 1
  2. Place a large drain pan under the radiator drain plug. Allow the cooling system to sufficiently cool down before opening the drain plug to avoid personal injury. Drain the coolant to below the thermostat level.
  3. Disconnect the upper radiator hose at the thermostat housing.
  4. Remove the thermostat housing bolts and coolant outlet connector of the thermostat housing.
  5. Remove the thermostat assembly from the vehicle and discard. Discard the old thermostat gasket.
0900c1528003c458.jpgFig. 1: Thermostat installation-2.4L engineTo install:
  1. Clean all gasket mating surfaces.
  2. Install the new thermostat in the correct position. If equipped, align the air bleed valve on top of thermostat to the vent recess in the water box (engine side) of the thermostat housing.
  3. Dip the new new gasket in clean water and install on the water box surface of the thermostat housing.
  4. Install the thermostat housing over the gasket and thermostat, making sure the thermostat is in correct position.
  5. Install the thermostat housing bolts and torque to 20 ft. lbs. (28 Nm).
  6. Reconnect the radiator hose. Tighten the radiator hose clamp.
  7. Connect the negative battery cable.
  8. Fill and bleed the engine cooling system.
  9. Pressure test for leaks.
3.0L, 3.3L and 3.8L Engines
See Figures 2, 3, 4, 5, 6 and 7
  2. Place a drain pan under the radiator drain and drain the cooling system to just below the thermostat level. Close the drain.
  3. Remove the upper radiator hose from the thermostat housing, then remove the housing.
  4. Remove the thermostat and discard the gasket.
0900c1528003c459.jpgFig. 2: Thermostat installation detail-3.0L engine 0900c1528003c45a.jpgFig. 3: Thermostat installation detail-3.3L and 3.8L enginesTo install:
  1. Clean the housing mating surfaces.
  2. Dip the new gasket in clean water and place it on the water box surface.
  3. Center the thermostat on the gasket, in the water box.
0900c1528003c45b.jpgFig. 4: Remove the radiator hose from the waterneck by loosening the hose clamp ...
  1. Make certain the bolt threads are clean. Threaded bolt holes exposed to coolant are subject to corrosion and should be cleaned with a small wire brush or correct size thread-cutting tap. Install the housing, making sure the thermostat is still in the recess, and tighten the retaining bolts to 105 inch lbs. (12 Nm) for 3.0L engine or to 21 ft. lbs. (28 Nm) for 3.3L and 3.8L engines. Reconnect the upper radiator hose and tighten the hose clamp.
  2. Connect the negative battery cable.
  3. Fill and bleed the engine cooling system with a clean 50/50 mixture of ethylene glycol antifreeze and water.
0900c1528003c45c.jpgFig. 5: Lift the waterneck housing off of the lower intake manifold, then ... 0900c1528003c45d.jpgFig. 6: ... remove the thermostat out of its mounting flange
  1. Make sure the radiator is full and start the vehicle.
CAUTION Do not remove the radiator cap once the vehicle is warm. Coolant is under pressure and may cause scalding or personal injury.
  1. Run the vehicle until the thermostat opens. Check the coolant level in the overflow tank and fill if necessary.
  2. Pressure test for leaks.
0900c1528003c45e.jpgFig. 7: Make sure to clean the waterneck before installation
Nov 27, 2008 | 1997 Chrysler Town & Country
Plumbing
you -do not have to drain completely- respond and I will guide you through it -expert at this
Oct 25, 2008 | Water Heaters
Home Logo
489 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
