Question about Reddy R155D Utility Heater
Just keeps shuting off
Thers half a tank of diseal fuel in it but it keeps shuting off and ive only used it 10 2 20 hrs
  • 92 Answers
Try K1 kerosene after you clean it out, diesel burns dirty and has a higher ignition temp.
Posted on Jan 22, 2009
I have a diseal generator its a tahoe brand it starts for awhile than it tuens itself off
Depends on how old it is,if it has a load of fancy electronics then iam not the man to answer this question but it its all manual then check the fuel flow ,if its one of them ones with a fuel tank above the engine and its gravity fed then check the feed line from the tank and remove the fuel cut off switch as their is a gauze filter above this tap and often they get blocked or partially blocked and it lets the fuel through but after a while the engine uses the fuel in the pipe but not enough is coming through to keep the engine supplied at speed .
Jan 27, 2015 | Cars & Trucks
Kabata g 1800 has diseal leak in the front how do I find it and fix it
This motor uses indirect injection. IF it is leaking fuel, the leak is probably before the injectors and is not pressure related. You can pressure test the tank to see where the leak is and you need to check all the fuel lines. The manual is here: http://www.ssbtractor.com/tractor_manual_display.cgi?m=Kubota&o=Kubota%20G1800
Sep 20, 2014 | Garden
My 1991 honda civic dx sedan jerks after getting below a half tank of gas
check the hose in the fuel tank, the hose going out of the tank may have holes causing the fuel to go out and back to the tank.
Feb 08, 2013 | 1991 Honda Civic
I have vw type 25 diesel 1600 cc .it takes ages to start the fuel seems to **** back into the tank so ive got to keep trying to start the engine till the fuel gets ther
I would try changing your fuel filter. Inspect the fuel lines for leaks. Air getting in the line would cause fuel to flow back into the tank.
I really suspect that the long cranking time may be a problem not with the fuel system but with the glow plugs, You probably need to replace the plugs as they are not pre-heating the combustion chamber properly to allow ignition of the diesel fuel. To start a diesel motor with out glow plugs you have to crank the motor until enough heat is generated to ignite the fuel. Glow plugs are not very expensive and fairly easy to change your self.
Dec 12, 2010 | 1986 Volkswagen Wagon Camper
The fuel filler kicks off when i try to put gas in my 06 ion. Is this a common problem with these cars??
it's not the car, it's the ven't tube for the fuel tank if the tank can't ven't it will keep shuting off the gas pump!
Jun 04, 2010 | 2006 Saturn ION
2000 GSX-R 600: my 2000 gsxr 600 keeps shuting off i rchanged the ...
try draining your fuel tank and running it with fresh gas.
May 18, 2010 | 2000 Suzuki GSX-R 600
I got a dodge dually that will quit running just goin down road for no reason its a cummins diseal and it not uel filter
check the fuel lines from the tank to the high pressure pump ,could be drawing in air ,but where??
Jan 09, 2010 | 2004 Dodge Ram
I HAVE A 2002 DODGE CARAVN 3.3L COMES UP WITH MULTIPLE CODES LEAN, WILL START IN THE AM, AFTER DRIVING AND SHUTING OFF IT IS HARD TO RESTART, ONCE IT'S STARTED THER IS POPING NOISES GOING THROUGH THE...
Sounds like fuel pump is on its way out. Lower fuel level, or even a good hot day in the sun, may also affect how far you get. With more fuel in tank, it takes longer for it to heat up and start acting up. You'll probably have proper ( or close to it ) fuel pressure in the morning because vehicle, gas & pump are cool, then as you use it, it heats up, and doesn't pump up to pressure, which would be a good time to have fuel pressure tested to be 100% sure. You may get a few more miles out of it by changing filter, but no guarantee's.
Nov 18, 2009 | 2003 Dodge Caravan
Filling the gas tank.
try putting the nozzle half-way to allow breathing
Sep 30, 2009 | 2007 Mazda B2300
Car problems.
Ok first you must stop allowing the fuel to get low keeit at least 1/2 tank at all times because the fuel covering the fuel pump in the tank cools it and makes it last longer remember this: its much easier to fill up the top half of the fas tank than the bottom half and cheaper too here in Wa state gas is still 4$ for reg and $4.80 for premium anyway
The fast that it starts right back up makes this problem much more broad as to what it can be. Because if it were a electronic module it would have to cool a bit before it would start. Does it Idle excessivly low now as compared to the way it used to? Theck for vacuum hoses adn caps (small plugs on the drivers side rear of the top of the engine make sure none are missing or cracked to a point where there is a hole.
Also check the air intake hose for any cracks or holes rake it off and clex it and inspect closly make sure its on completely and the clamps are tight
Does this problem happen if the fuel is half or more full if tou don't know fill it up and see and keep it more than half all the time
Aug 19, 2008 | 1999 Nissan Pathfinder
Reddy R155D Utility Heater Logo
52 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
