Question about Whirlpool AWM5125/1 Front Load Washer
Brushes on whirlpool awm5125
Please can someone tell me where the brushes are situated ,i took off the top but cant see them
  • martyrfc Jan 17, 2009
    i did this but the brushes are fine,the machine gets stuck between 10 and A sounds like its trying to fast spin but dies
  • Whirlpool Master
  • 3,463 Answers
Remove rear cover of washer, remove belt , and undo any bolts that you can see that secure the motor in place, unplug motor, and remove same
You will fnd the brushes located at the opposite end to the motor pulley.
Replace as req'd.
Plz rate my solution.
Thanks.
Posted on Jan 16, 2009
Front loader aw/m 5125 door wont lock at any cycle so programme cant commence. light is on bt door can still be opened.
There is likely to be a problem with either t
he door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 01, 2011 | Whirlpool AWM5125/1 Front Load Washer
My awm 5145/4 has stopped working! There is still power going to it but when you select a programme it does nothing,but it will drain,someone has suggested the brushes,where are these located on this...
Could well be the Carbon Motor brushes that are worn they last round 5 years hen need replaced..I lie under the machine to do this but you may find it simpler to remove the motor they are located at the side and are secured by two screws, parts cost around £25 per set.....
Feb 27, 2011 | Whirlpool AWM5125/1 Front Load Washer
Washer wont start.
£85 is the standard Whirlpool call out fee.
There could be a range of possibilities from faulty motor, burnt out brushes, etc.
Feb 16, 2009 | Whirlpool AWM5125/1 Front Load Washer
WHIRLPOOL 5125 LOUND NOISE
I take it you are refering to the AWM5125
The sound you hear are the bearings on their way out. You will need a replacement rear tub half
Jan 26, 2009 | Whirlpool AWM5125/1 Front Load Washer
I am trying to locate the brushes in my whirlpool awm 5125 washer i have taken the top off but cant locate them
the brushes are on the motor which is located at the rear of the machine sitting just under the wash unit.
You will need a 10mm spanner to remove the bolts holding the motor on. unclip the wiring to the motor and remove.
the carbon brushes are located on the rear of the motor - one on each side of the commutator,
you will need a philips screw driver to remove the brushes
Jan 15, 2009 | Whirlpool AWM5125/1 Front Load Washer
FITTING NEW DOOR SEAL ON WHIRLPOOL AWM5125
this is a complex repair and the machine complet frount has to be removed
May 10, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Usually it will be just be reversing the procedure of removing the old seal. At any rate, the door will need to be disassembled.
Mar 29, 2008 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool AMW5125 washing machine approx 4 years old Spin action not working
your brushes are gone its a easy job and first thing is wright down the model number of the machine its normally on the door when you open it go to ebay on you should get some for £5 ounce you have took off the motor it that easy to put back on
Nov 11, 2007 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool AWM5125 - door won't open
i unplugged mine from the wall and that worked
Nov 29, 2006 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool AWM5125/1 Front Load Washer Logo
114 people viewed this question
Dan Webster
Dan Webster
Sal De
