Question about Olympus VN-1000 Digital Voice Recorder
Not Able to Record/Playback
Recently, I my batteries ran out of power and upon changing batteries, my recorder has been absolutly unresponsive when and after I try to record. After putting new batteries in, I would be able to listen to audio, but when I pushed the record button, it froze. I pushed the record button and it said REC, then when I pushed stop to end the recording, it had the file number of said recording (14) and AM 12:01 on the screen. Then when I push the play button, the red light over the DISPLAY text flashes. When I push stop, it flashes green and displays how much time is left (5 hours). It even let me cycle through recordings (but not listen to them), but then I pushed record again and the display got stuck on REC. Every time I reinsert the batteries, it does the same thing: lets me listen to recordings but freezes when I try to record.
  • 5 more comments
  • Matt Batt Jun 16, 2007
    And another time when I tried to record, I pressed stop then cycled through the folders and the file number went down to zero on each of them. (However, they are no deleted because I can still hear then if I take bateries out then put them back in.)
  • cjdaweasel Nov 17, 2007
    I have the same exact issue. After my batteries died and I installed new ones I can't record. It just freezes when I try. After I press record it acts like its recording and then does nothing. I have to take out the batteries and put them back in to make it do anything.
  • lacc22 Dec 09, 2007
    I have the same problem. And when I push rec button twice, the voice recorder becomes frezze! and I need quit the batteries and place again. I can't record.
  • Anonymous Feb 27, 2008
    I have the EXACT same problem and am going to try to call someone about it.  I am writing a book and this has really interfered!  I have the right batteries. When I push record, it is just unresponsive. I'm stuck.
  • Anonymous Apr 06, 2008
    I have the same problem even I replaced with new batteries, power on and off again. The first time I hit 'rec', it showes 'rec' and does nothing actually. After I hit 'stop' and it returns to normal. But if I hit 'rec' second time, it stalls in 'rec' and can't respond any key.
  • whatever85 Apr 09, 2008
    Airraid, you described my problem to the T !! If anyone can help, please let us know!! Thanks!
  • cindcind May 27, 2008
    I only used it a few times and have not used it for 6 months after batteries ran out put new batteries in today tried to record it goes to record then i cannot release it it sticks cannot get out the only way take the batteries out, it just wont record if you try to record first you can release it by the stop button even though it has not done anything put it in record the second time you cannot stop it even though it is not recording all buttons wont release it does anyone know why or is it a dead duck if it is i definately never got my moneys worth
Can't record on the my Olympus VN-1000
+ I press rec button and it just shows rec in display (no recording time is shown ONLY rec)
+ there is no play back  or stop function
+ i can only stop  rec by removing batteries (stop or play will stop rec only ONCE - but there is no  useful function - such as play or stop or rec.)
+ I tried all trouble shooting tips in manual  with no effect
+  i cleaned the spring contacts inside battery compartment that interface with the  batteries
+ it was barely used - and has not been used for a 1 year ( no batteries were inside it )     it was inside a drawer
THANK YOU
Posted on Nov 23, 2008
SOURCE:
I have been trying to change our company greeting on the Panasonic KX-T7731 and can't figure out how. I have searched all the manuals. I also wasnt sure if I need to be on a certain phone/extension to
It's not part if the phone but deoends upon which switch (exchange) you are using and also if your using an external voicemail system or on the KXTES824 if you're using the built-in AA (Automatic Attendant)
Jan 15, 2015 | Panasonic KX-T7730 Corded Phone
Low volume recording on reel to reel tape deck
Problem could be in either the record or playback circuits of unit. Try playing back a tape in another machine to see what the volume is like. If also low then the issue is with the record amp circuits.
Fixing will not be cost effective, however.
Aug 21, 2017 | Audio Players & Recorders
In playback my camcorder stops and 31:11 flashes. Any ideas?
This most likely means the taps is jammed.
You can try and get the tape to eject. To do this, remove your battery from the back of the camera. Also if your camera has another small battery under the LCD (the size if a nickel) remove it too. Wait 2 minutes. Then, plug the camera in with the power cord. Try changing the camera from playback to record mode. The tape should eject at this point. If this doesn't work, try it again but this time start in record mode and change to playback after plugging it in.
I hope this helps.
Mar 31, 2011 | Cameras
I've had a DR-MV5S DVD video recorder & video cassette recorder for years to transfer DVD over to VHS tapes. Something has recently happened where I can't record VHS tapes. Can't play VHS tapes on the...
Register and download the manual for free audio.manualsonline.com
http://portablemedia.manualsonline.com/manuals/mfg/jvc/jvc_dr_drmv5s.html
If it won't PLAY VHS tapes it must have a serious mechanical problem (if it even loads) or its heads are glommed up, so it obviously won't record them either. When's the last time you ran a cleaning tape through it?
Solve the load or playback problem and it will probably record.
Time and poor storage conditions are the mortal enemies of tapes. Store the in a 'played
Feb 26, 2011 | JVC DR-MV5S DVD Recorder/VCR
Zoom H4 Battery Problem
I am having the same problem with my Zoom-H2. I have 2 2650 mah rechargeables, and the draw is such that 20-30 minutes of record &/or playback kills the batteries. Last night I just turned the power on and did nothing. 5 hours later the batteries were dead...
This isn't a solution. It is a reaffirmation that you aren't crazy!
Jan 05, 2010 | Zoom H4 Handy Recorder
Sanyo Xacti VPC-HD1- doesn't do anything in record mode
As I have been writing on other HD1/2 problems, sometimes it can be the card which is an issue. If the card is too slow or perhaps corrupted then the device can find it difficult to record.
This and other soft faults (that are reperable by turning the power on and off, changing or reinserting the card, removing the battery) are often indicated by a flashing red recording light.
Apr 25, 2008 | Sanyo Xacti VPC-HD1000 Flash Media...
Actually, it's an MW24FP3 VCR unresponsive
After Checking Toshiba FAQ, it turns out that the record button must be turned off to do anything, including playback.
Mar 31, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Records media but playback has no audio.
Are you absolutely sure that it is receiving an audio signal?
What input are you using? Try recording using alternate inputs.
Audio part of a VCR is normally way more reliable than the video.
The exception is on high-end stereo types where they record the extra audio signals using the video head cylinder in which case it can easily be lost.
Jan 24, 2008 | GE VG4054 VCR
Record on DC210 and playback on home DVD
You should absolutely be able to play the recorded DVDs from your camcorder in your DVD player, as long as you remember to finalize the disc and the disc is compatible with the player. If your DVD player is less than five years old or so, you should be fine, provided you're not using dual-layer discs.
Dec 02, 2007 | Canon DC210 DVD Camcorder
454 people viewed this question
Top Olympus Audio Players & Recorders Experts
Ekse
leoz
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
