Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My Wayne Dalton garage door will open with remote but not close. The only way it will close is to hold down the wall mounted garage door button. Then the light goes on and off while clicking. I have checked the alignment and both green and red lights are on. Do I need to reset something?? Please help!!
Your infrared sensor is either misaligned, faulty, or you have a broken wire from your sensor to your door opener. (Flashing light indicates infrared light path is broken). both sensors should indicate green led. door wil not come down is safty feature to prevent door from closing when light path is broken.
Posted on Jan 16, 2009
Wayne Dalton garage door opener
well one answer might be the down force and up force need to be adjusted. it starts to move and then reverses because the force is set too low.
Mar 26, 2016 | Building Materials
How do i reporgram a wayne dalton keypad
I would look into buying a liftmaster jack shaft its a much better unit but to get u buy just press the little red button on the opener type in your code
Feb 04, 2015 | Wayne Dalton Remotes Wayne Dalton 327308...
Garage Door Remote
Did you happen to put a new light bulb in it? I put an LED bulb in mine and the interference caused the remotes to stop working. I had a bear figuring it out, because it seemed to be totally random. Sometimes they would work and sometimes they wouldn't. Once I switched back to an incandescent, it worked fine.
Jan 17, 2014 | Genie Wayne Dalton 36560U 1/2 Hp Dc Belt...
Wall mount button LED is flashing, remotes won't work, door won't close unless the wall mount button is held down until the door is fully closed
Sounds like you have a couple problems. First of all press and hold the button on the wall control that has a lock icon for 3 seconds and release. This should take care of the flashing LED and the remotes will now work. Having to hold the button on the wall control until the door is closed is usually a problem with the door sensors. Make sure they are pointed at one another and the small light on each is lit and not flickering.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not open close with remote
Press and hold for 3 seconds the button on the wall control with the lock icon.
Aug 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
How to have security with a lost wayne dalton garage door remote
Go to this site and follow the instructions.
http://www.1stdooropeners.com/299264coding.htm
May 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wayne Dalton DoorMaster Model BDOR-2000/BIRW-2000
Check the contact at the bottom of the socket and (with the unit unplugged) lift (or pull) it up to make contact with the bulb easier or tighten the bulb a bit more than normal.
Does the light ever come on?
Apr 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pressing remotes the door won't go u[
It sounds like you have the lock enguaged. When it is flashing it locks out all remote access. Hold the lock button for 3 seconds. The green light should go solid. On the issue of closing, it is most likely a safety eye issue. Hold down the wall button. If it closes it is the safety eyes. Holding the button overrides the safety eyes. Make sure that thelight on both eyes are both lit.
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
820 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
