Question about GE Profile WPRE6100G Top Load Washer
New belt i have a new belt for my GE washer, old belt was so wore out did not have to take anything apart. what is the process to get the new belt on? thx
    Scholar:
  • 42 Answers
Basically, you need access and loop/connect around 2 pulleys using a long screw-driver to assist when looping your final pulley. The pulleys are metal; circular in shape; older models have 3 pulleys (water pump).
When looping your belt onto your final pulley, I typiclly use and wedge a long screw-driver in-between the pulley and belt, while simultaneously rotating the metal pulley to completely loop the belt on.
Posted on Jan 26, 2009
We are seniors on a budget. Our 25 yr old Maytag died in January, have been using the laundromat since. Saw this model GE washer (WHDSR315DS5WW ) in a Hbitat for Humanity thrift store . Cosmetically it...
Wouldn't touch a GE. If you have a real Maytag washer, 2 belt, it is worth repairing so long as its not rusted out and parts are available. If you have the model number you can call our shop and tell us the particulars. 425-453-8845.
Kihm
Jul 03, 2017 | GE WBSR3140D Top Load Washer
My GE Dryer that is around 3 years old squeals or screeches loudly when drum it moving. What could be causing this and is it possible to take apart a new GE Dryer yourself?
its a chore but can be taken apart.... the unit most likely either has bad rollers or the belt tensioner which is under tub is bad... has a wheel on the tensioner that guides belt adn could have a bad bearing ....good luckkkkk
Dec 31, 2010 | Dryers
My ryobi oss450 has stoped oscillating. Is there anything I can do to repair it? It operates just fine except for the oscillating.
You can try taking it apart and cleaning the mechanism that makes it oscillate, but i have found most times when those stop they are just wore out and need replaced. Those sanders are pretty much disposable.
Mar 17, 2010 | Tools & Hardware - Others
My washer won't spin or drain
you will have to drain the washer no matter what. scoop out as much of the water as you can. carefully pull it out and remove the lower panel. if it is an old one, the belt could be bad. it could be a bad motor or a bad timer also. if the belt IS bad, you must determine if the belt just wore out or if something locked up i.e. the water pump. also just a long shot, wiggle the timer around in different settings and see if it makes an effort. if it does then you need a new timer.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Microwave won't heat anything
Yeah, it's time to invest in a new oven. The magnetron tube in yours most likely just finally wore out. It's the source of the microwaves, and like any tube it gets weaker with age and finally just quits altogether. It would cost more for a new magnetron than it would for a new oven these days.
May 15, 2009 | GE Microwave Ovens
GE WASHER WJRR4170G0WW-SPIN Cycle does not work- just make sound.
My washer is 2 years old and this is 1/2 the cost I paid for it new. My review of this product after 35 years of technical experience; GE products (Hotpoint)aren't worth buying any longer.
The problem is the Motor. There is an electronic PC Board attached to the top of the motor and under the drip protector, which protects the PC Board. On this board, there is a green flashing light which displays trouble codes by flashing. Unplug the washer, remove the 3 screws from behind the control panel. Slowly pull the control panel toward you and slide it to the right to release. Inside the washer, there is a diagram with the trouble codes printed in the lower right hand corner. Everything else is self explained. Flashes indicate the problem and the solution is all written. Since I have the same problem and a technician, this is a defective product GE has discontinued and re-manufactured. After phoning GE the motor # Normal 0 WH20X10051 cost $252.25 to ship to my location.
Jan 09, 2009 | Washing Machines
Changing the belt on a GE front loading washer
Hello , i can try to help , I have always got these belts on by starting the belt on the small pulley/motor , then rolling it on the large pulley , kinda like putting a bike chain on. Let me know if you have any other questions and how it turns out.
Phil
Jan 07, 2009 | GE WSXH208A Front Load Washer
GE WBSR WASHER WATER OVERFLOWS
He probably disconnected the water level sensor when replacing the belt or the timer is dead.
Check for any unconnected sensor or check if the main program button is turning propely..
cheers
Dec 20, 2008 | GE WBSR3140DW Top Load Washer
I have a old hoover washer model# 0512 serial# 70404 and i need to know if i can still get a fill house and new belts for it and can u tell me how old this thing is cause everything works just the belts...
Fill hoses are more or less standard for all washers, so no prob there, re belts depending where you are located, try your nearest hoover dealer,I would not have thought you will have any trouble obtaining replacements,
If no joy there try a good shop that sells w/m spare parts, they might have good second belts.
Plz rate this solution
Thanks.
Dec 16, 2008 | Washing Machines
GE Profile WPRE6100G Top Load Washer Logo
62 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
