No hot filling washer. just a buzzing noise. cold water ok.
No hot water coming in to the washer. maytag model la506 model 10
  • 15,935 Answers
The miver water valve has a failed solenoid. Replace the entire valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Whirlpool washing machine does not rinse just a buzzing noise
The buzzing is the water valve, the timer is sending power to the valve but no water is coming out. I would set to wash and as it is filling up change the water to cold then to hot while it's filling. I bet either cold or hot will buzz (usually hot). Once you determine which (clod or hot) shut that supply off, take that water line off the washer, put the end in the washer and turn the supply back on. If water comes out then look inside the valve where the hose connects, it could be clogged. If you have water going to the valve and you don't see a clog then the problem is inside the valve...replace valve.
Oct 21, 2014 | Whirlpool Washing Machines
Roper washer model RAS8245EQ1 not working, buzzing noise
Her you'll find your answer..
http://www.appliancerepair.net/washing-machines-forward.html
Mar 08, 2013 | Roper Washing Machines
We have a Maytag A612 washer. Today it wouldn't fill all the way with cold water (for a cold water load). If I hit the Warm or Hot button, it resumes filling with Hot water, but I don't want Hot so I hit...
Turn off the cold water faucet.
Remove the water hose from the machine and the faucet.
Clean out the filter screen in the washer water valve.
Look in the hose for a secondary screen and clean it also if one if there.
Not all hoses have screens.
All water valves do have screens.
Sep 05, 2010 | Maytag SAV4655A Top Load Washer
Will fill with cold water but not hot
the hot water inlet valve is shot replace it
Apr 27, 2010 | Maytag Atlantis MAV7551 Top Load Washer
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
Hot or cold water won't come on
If there's no water at all, make these checks:
  • Is there water getting to the machine?
    Check to be sure that someone did not turn off the water, usually the faucet or faucets are on the wall behind the machine.
  • Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
  • If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
  • Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Aug 03, 2009 | GE WDSR2080D Top Load Washer
Maytag Legacy Series Top Load Washer model SAV515DAWW When filling, the cold water just trickles in and takes a long, long time to fill. When I unscrew the hose from the washer and turn the water on it...
From what you have said, you may have a bad solenoid in your water fill valve. it's the rubber piece under the debris screen. if you can get that out and replace it, you'll be golden.
Feb 22, 2009 | Maytag Legacy Series Top Load Washer
No hot water filling washer
Check to see if there is a filter located in the valve, remove and clean.
If still no hot water then disconnect hose and make sure you have actually got water at valve, if you have and it still does not come in, and you can hear a buzzing noise, then I would say that it is sticking and you have a faulty inlet valve, only solution is to replace said valve.
Plz rate my solution.
Thanks.
Jan 15, 2009 | Washing Machines
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
