Question about Dictaphone 3750 Desktop Cassette Transcriber / Recorder
Telephone recording won't work
Can't find instruction manual anywhere - when I push the telephone record button it looks like its going to work, then goes into pause and doesn't record. Any ideas?
  • Anonymous Apr 22, 2009
    how does it plug up to an avaya phone 2410
  • 43 Answers
You need to have a telephone record adapter plugged into the back of the 3750. Then you press and hold the Tel Rec button until it begins recording.
Also check to see if the 'Vox' or 'VA' switch is on (voice activation). This will cause the machine to pause if the volume is too low.
Posted on Mar 13, 2009
What button of my Coby MP3828 i push to take pictures and videos.In the instrucction manual said that he suport many formats of audio,but only support MP3 formats.
To take pictures and record videos simply push the power button once to take a picture or start recording. Push it again to stop recording.
Jan 01, 2013 | Coby MP828 MP3 Player
Hi, I'm having trouble with my marantz recorder. I've reached the 999 track limit, but despite deleting older tracks it still won't let me record. The solution must be something basic I've...
Since you have reached the 999 track limit, it is possible your CF card may have been corrupted.
On page 28 of your manual you should find the instructions for formatting your CF card.
"How to Format a CF Card."
This may get you going again.
Hope this helps.
Sep 14, 2011 | Marantz PMD660 Digital Voice Recorder
I need instructions on how to record a message on an AT & T Ansering Machine Model 1719. Lost the manual.
You can download the manual from the manufacturer's web site at
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=353
Apr 01, 2011 | AT&T 1719 Digital Answering Machine
How do i change the recorded message on my voicemail. i cannot find the answer to this question anywhere in my instruction manual. thanks.
Answering system settings
Record your own announcement
Using the telephone base:
Press •/REC while the telephone base is not in use.
Press /CID or /DIR to select Announcement, then press the SELECT softkey.
Press /CID or /DIR to select Mailbox 1 or Mailbox 2, then press the SELECT softkey. The corresponding icon, 1 or 2, flashes on the screen.
The telephone base announces, "Record after the tone. Press 5 when you are done." After the tone, speak towards MIC (microphone) of the telephone base. Press 5 or the STOP softkey when finished recording.
The answering system automatically plays back the newly recorded announcement. Press 5 to stop the playback at any time.
-OR-
Press the MENU softkey when the telephone base is not in use.
Press the SELECT softkey to select Answering sys.
Press (down arrow)CID or (up arrow)DIR to select Mailbox 1 or Mailbox 2, then press the SELECT softkey. The corresponding icon, 1 or 2, flashes on the screen.
Press CID or DIR to select Ans sys setup, then press the SELECT softkey.
Press CID or DIR to select Announcement, then press the SELECT softkey.
The telephone base announces, "To play, press 2. To record, press 7." Press 7 to record and the screen shows Recording announcement ..., or press CANCEL to exit to the previous menu.
The answering system automatically plays back the newly recorded announcement. Press 5 to stop the playback at any time; 2 to replay the recorded announcement; or 7 to record again if desired.
Press CANCEL to exit to the previous menu.
Feb 03, 2011 | Vtech DECT 6.0 Digital Cordless Phone
How to use olympus telephone pickup tp7
Look this instructions is the same operation Comparable Models:
  • SONY ECM-TL1 Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • Olympus TP7 Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • TC-L Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • CC-10 Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • CC-20 Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • TC-W Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter http://www.tvps.com/ecsdownloads/ECS-EBPR/ECS-EBPR-Cordless-Cellular-Telephone-Recording-Adaptor.pdf
Feb 11, 2010 | Olympus Audio Players & Recorders
RCA 25205 Visys will not record message
Called the company. There is a misprint in the instructions.
In the section titled "Out-Going Announcement RECORD" on last step it says Press Exit to stop recording. It should have said Press Sel/Save.
I did this and it worked.
Repeat for Line 2 if you are doing both lines.
Next thing is to make sure you go right to the section titled "Configure Out-Going Announcement" and select the right type of message you want callers to hear for each line.
Worked like a charm and took 3 seconds to get 2 different personal messages on the machine.
Aug 07, 2008 | RCA 25205RE1 Phone
Dvd recorder
Hi there! No!! I have not solved this problem. I have done everything from following the Manual Instructions on p.22, to unplugging the Recorder for several days and then plugging it back in with the hope that in would work, to finally, taking out the batteries of the Remote and pushing each of the buttons twice ...a suggestion that I found on the Internet. All of these solutions were supposed to return the Remote back to the default setting of DV3. Go figure! How are things going for you? I am sure that you have noticed that there are NO references for "technical support” anywhere in the Manual.  .... no e-mails or phone #'s. Any ideas where to go form here?  johnb
Jul 05, 2008 | Televison & Video
Recording
You need to buy the - disks. (+ will not work).
The instruction manual can be found online.
Nov 10, 2007 | Sylvania DVR90VE DVD Recorder/VCR
Lucent Digital Answering Machine Model 1715
If you search for an AT&T Digital Answering machine model 1715, you will be sent to a free service with an abreviated manual.
Oct 08, 2007 | Lands Phones
Dictaphone 3750 Desktop Cassette Transcriber / Recorder Logo
147 people viewed this question
Top Dictaphone Audio Players & Recorders Experts
Alan W Kelly
Alan W Kelly
Pennywhistler
Pennywhistler
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
