Question about HP 49g+ Calculator
The low battery indicator does not turn off, although I changed all the batteries including the back up battery. The calculator is a HP49g+
  • odelgado Jan 16, 2009
    The problem continue
    I clean the contacts but the Low battery indicator still is on.
    Scholar:
  • 160 Answers
Its the fault in the internal circuit of the device as its not detecting the battery properly and needs to be repaired to make it proper.
Posted on Jan 16, 2009
    Top Expert:
  • HP Master
  • 78,267 Answers
Take the batteries out for 5 minutes and then, clean the contacts and then reinstall the batteries, make sure u pay attention to proper battery polarity as marked on the battery, this should fix the problem
  • HP Master
  • 6,487 Answers
This is a problem with the battery sensor of your unit and it needs a repair already , i suggest you to take it to a service center near you if its still under warranty...
    Genius:
  • 1,199 Answers
The battery contacts may need cleaned
  • 679 Answers
Go for a repair...
  • rockfixya
    rockfixya Jan 16, 2009
    ok... First try to reset method.
    follow the link>>
    http://newsgroups.derkeiler.com/Archive/...
    if reset did not works means its a time to repair the calculator.
  • rockfixya
    rockfixya Jan 20, 2009
    please let me know if problem solved.
    Thanks for using FixYa.
    Sergeant:
  • 221 Answers
Just check out the connectors in the socket where you insert the battery.if they r dirty they needs cleaning.just clean them and try again.
How to check how much battery is left?
If the battery level drops to a certain level the calculator will tell you so when you turn it on. Otherwise there is no battery status indication, that is, if the calculator doesn't tell you the batteries are low then they're still good.
If you really want to know the battery level, take the batteries out and check them one by one with a voltmeter.
Jan 24, 2014 | Texas Instruments TI-83 Plus Calculator
My for the TI 84 Plus Silver Edition screen doesn't work. I changed he batteries including the back-up. The screen won't light up. I bought this calculator around 3 years ago.
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If that doesn't work, remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries.
If that doesn't fix it, please append a comment to this post and we'll go on from there.
Sep 12, 2010 | Texas Instruments TI-84 Plus Silver...
My TI-84 won't turn on. If I replace the
Remove all four AAA batteries. Press and hold down the ON key for at least ten seconds. Replace the batteries. Turn the calculator on.
May 15, 2010 | Texas Instruments TI-84 Plus Silver...
My TI 84plus silver calculator won't turn on
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. First, make sure the batteries are in the right way. Then turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Mar 28, 2010 | Texas Instruments TI-84 Plus Silver...
It will not turn on. I've replaced the batteries
Sep 23, 2009 | Texas Instruments TI-84 Plus Silver...
I change batteries and the sign "Low battery" remain there
If you do not want to lose your programs, move them to an SD Card, and perform a reset. Maybe the problem will be solved.Then you can transfer the programs to theit directory.
Hope it helps.
Jan 21, 2009 | HP 49g+ Calculator
TI 86
If batteries are inserted correctly you can adjust the contrast
Press [2nd] key and release it
Press and hold [UPArrow] key to darken till contrast is dark enough.
To enlighten screen, do as above but use the [DownArrow] key.
Hope it helps.
Oct 24, 2008 | Texas Instruments TI-86 Calculator
The calculator, hp49g+, will not turn on by pressing the "ON".
If batteries are fresh use a paper clip and insert it in the hole (reset) to the left of the serial number. Press gently.
Hope it helps.
Oct 10, 2008 | HP 49g+ Calculator
TI 83 Plus Calculator
You can try to turn the contrast down by pressing 2nd and then hold "down" If the screen does not fix, put new batteries in (including the back up batteries). The problem will be resolved. Hope this helps...
Aug 18, 2007 | Texas Instruments TI-89 Calculator
Low Battery when using screen
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Oct 21, 2006 | Canon PowerShot G2 Digital Camera
HP 49g+ Calculator Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
