Question about Sector 450 2653450035 Wrist Watch
Analog part of Sector Analog digital watch doesn't work
I have a new Sector analog/digital model 3251211025-15056 watch. The digital functions work but the minutes, hour and second hands do not move when the crown is pushed in. Is the watch defective?
  • 2501 Answers
SOURCE: Setting Analog Hands
I can't find the instructions for this watch but Casio instructions may be similar, so you could try this:-
Press the "mode" button until you get an abbreviated message for hand setting mode (HS?)
When in this mode, I expect that two of the other buttons make the hands go forward or backward.
Some experimenting will be required. When you have finished, press the mode button until normal operation has been achieved.
Posted on Feb 11, 2010
Casio CPW-500H-1AV analog watch not working
That certainly wouldn't hurt - be sure you use good new batteries.
Aug 06, 2014 | Casio Watches
Watch digital section has shut down while smaller part works
there are two batteries in the watch one for digital movement and one for analog it probably needs new battery
Mar 09, 2013 | Diesel Watch DZ7231
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
    Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Aug 21, 2010 | Casio Watches
Manuel for yacht timer 700 please. Best regards P.Hessner
Could not find a download for instructions on this watch, but I did manage to find some basic instructions for the Sector brand. I hope this helps as this is the best I can come up with.
Good luck.
Sector Chronograph Watch Instructions
  • Most chronograph watches have screw-down crowns for water resistance. You must unscrew the watch crown before you can make any changes to the watch time. After time is set screw the crown back in. To utilize the chronograph dials, use the buttons on the side of the watch. One button will be for the second timer. Press once for the second hand to start timing. Press again to stop it. Another button will be to reset the second hand timer back to zero. Sector Chronograph watches may have different dial functions (see link in References).
  • Sector Dual-Time Watch Instructions
  • Because Sector watches are known for their sports capabilities, the Dual-Time watches have screw-down crowns. For Dual-Time timepieces, unscrew the crown counterclockwise. Pull the crown to middle position to set the date. Pull the crown out to its fully extended position and rotate it to set the day of the week, hour and time. Press and hold in the crown and turn clockwise to seal the crown back in to the watch.
  • Sector Ana-Digi Watch Instructions
  • Sector Ana-Digi timepieces have analog hands plus digital timekeeping functionality. To set the time, unscrew the crown counterclockwise and then clockwise to the appropriate time. The digital functionalities are programmed by the buttons on the side of the case. Depending on the style of the Sector watch, you can set the digital time with one button, set the date display, 1/100 seconds chronograph timer, altimeter, thermometer and alarm functions.
  • Aug 12, 2010 | Sector 700 2653700025 Watch
    Feb 10, 2010 | Sector 450 2653450035 Wrist Watch
    Digital/analog watch... analog part doesn't run
    A lot of times they hide a second battery for the analog display under the larger battery used to run the digital display. Also, the 2025 may not have a full charge.
    Oct 17, 2009 | Watches
    The hour & minute hands on my pulsar nx14-x001 do not move. the second hand quivers, but also does not move. the digital time and other functions are okay. HELP!
    Without knowing the model of the watch i would say you need a new battery. It is typical for this style of watch to have two batteries or one lithium battery. In either case the analog movement will drain faster than the digital portion of the watch and will stop working first.
    Sep 21, 2009 | Pulsar Watches
    It stop working, analog and digital
    Unfortunately the watch may have been on display for some time and the battery may have run low. If you go back to the place of purchase they should change the battery free of charge. Make sure that you have the watch resealed to manufacturers water resistance rating or you void Sectors warranty. The retailer may also replace the watch with a model in stock but you may have the same issue with display time effecting the battery life.
    Sep 17, 2009 | Sector 3251908015 Mountain Master watch
    Sector 450 2653450035 Wrist Watch Logo
    83 people viewed this question
    Top Sector Watches Experts
    Tom Chichester
    Are you a Sector Watch Expert? Answer questions, earn points and help others
