Question about Dryers
I need to change the heating element in my Amana Dryer model number LE4317S2, and I didn't want to take any unneccasry steps. Should I do this from the front or the back of the dryer? How do I get the top off?
I decided to take my time evaluate every angle before I began. I first figured out how to take the front of the dryer off, and then I found the heating element attached to the back wall. With a long nut driver I was able to get to the element without taking out the drum. I then rebuilt the new element and reversed my actions.
Posted on Jan 16, 2009
Dryer not heating
Hello there and welcome to fixya
Here are the most common things that will need to be checked with a meter to ensure there is continuity on these parts no continuity means that the part is bad and needs replacement ok?
Thermal Fuse
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric solenoids which open the valve to let the gas flow into the burner assembly. If the dryer doesn't heat one or more of the solenoids may be defective. If the igniter glows for 90 seconds but the burner flame doesn't light, replace these coils as a set.
Dryer Igniter
If the dryer doesn't heat, the igniter might be burned out. Check the igniter for continuity with an ohm meter. Dryer igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can burn out over time. If the dryer doesn't heat, the element should be checked for continuity. The heating element cannot be repaired and must be replaced if defective.
Heating Element Assembly
The heating element assembly on an electric dryer can burn out over time. If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the heat given off by the flame. If the dryer doesn't heat, the flame sensor might be defective. Check the flame sensor for continuity. This is not as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn't heat the high limit thermostat can be defective. It can be checked for continuity. If the thermostat is "open" the dryer doesn't heat.
Cycling Thermostat
The cycling thermostat regulates the temperature of the air in the dryer. If the dryer doesn't heat it may be caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at fault when the dryer doesn't heat. Check all of the other components in this troubleshooting guide before replacing the main control board. The main control board cannot be tested easily and must be replaced if it is defective.
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer
Oct 14, 2013 | Amana Dryers
TAKES ALONG TIME TO DRY
Hi and welcome to FixYa. I am Kelly.
You did not mention if the dryer was even warm to the touch during operation.
The generic service manual can be found here:
http://www.servicematters.com/maytag_library/docs/RS3200007R0.pdf
I would follow the troubleshooting process in step 9 of page 21.
To gain access to the unit you will need to remove the service access panel Pg 28 of manual
Gas burner circuits steps are on page 32
A little about heat control circuits. They are series circuits and any one of the following can prevent the dryer from heating.
1. Motor switch
2. heat control
3. cycle thermostat
4. high limit thermostat
5. thermistor
6. heating element
in addition to the above
For gas burners
1. Gas valve
2. Gas safety valve
3. Ignitor
4. Flame sensor
Most dryers have at least 5 of the 6 components listed in the first set of components above. The high limit thermostat is replaced by the thermistor in newer models. Thermistors are a one time fail item and if it has opened it must be replaced.
The warranty for this dryer is as follows:
1 year full coverage
Limited Warranty
After one year from the date of original retail purchase, Amana will provide a replacement part, f.o.b. Amana, Iowa, as listed below, for any part that fails due to a defect in materials or workmanship. The owner will be responsible for paying all other costs including labor, mileage, and transportation.
Second through Third Year
Amana will provide any part.
Third through Fifth Year
Amana will provide the drive motor or timer.
Third through Tenth Year
Amana will provide the cabinet assembly should the part rust through.
Lifetime
Amana will provide the Stainless Steel inner drum if so equipped.
Thanks for using FixYa.
Kelly
Mar 04, 2010 | Amana DLE330RAW Electric Dryer
Amana electric dryer will not heat/ LEA60AW Everything works fine but no heat...have cleaned all lint from inside the dryer by taking front panel off. What else should I check.... I noticed it wouild come...
Check for 220 Volt at the heater entrance to the heater box (accessible from picking up the top on most models). If you have 220v there the heater element is out. If you don't have 220v on the terminals of the heater the problem is in the controls. The fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating (s), are all suspect and have to be eliminated 1 by 1. Hope this helps. With any luck all you need is a new element. Clean the duct out while replacing the heater if so because the main thing that causes heater element burn out is low air flow a kinked Dryer vent hose, lint, and plugged up fan on the motor are the 3 main causes of low air flow. If yours has little holes in the inside cabinet these can get clogged with lint also and cause a problem. Hope this helps and please rate me accordingly Thank you and good luck.
Feb 23, 2009 | Amana ALE643RB Electric Dryer
Amana dryer
If you have voltage across the heating element and it does not heat, replace the element. If you have no voltage, trace it back to the thermostat and control board.
Oct 02, 2017 | Dryers
No heat coming from Amana Dryer
2 screws at the bottom of front panel if no screws there, then pry top off with wide flat screw driver then look inside toward top of front panel remove two more screws and the front should lift right out then remove screw/s in center of drum and lift out of cabinet there should be your heat element
Jan 17, 2009 | Amana NDE2335AY Electric Dryer
Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
Dec 24, 2008 | Amana Dryers
Dryer
Probably the heater element. You need to pull the back of teh machine off and check the heating element for continuity. If its open then its shot.
These are parts that normally go bad.
Check on ebay these can be had for less than 50.00
Oct 03, 2008 | Amana ALG331RAW Gas Dryer
Amana Electric Dryer runs but does not heat up - model ndw2330ayw -
I HAVE AN AMANA DRYER MODEL LE8217W2 ITWILL COME ON FOR A SHORT TIME AND THEN CUT OFF. I CHANGE THE BELT, THE MOTOR AND THE THERMOSTAT. THE DRYER STAYS ON , BUT WILL NOT HEAT UP. WHAT'S NEXT ???? PLEASE HELP!
Nov 05, 2007 | Amana NDE2330AY Electric Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
