Question about Ovens
How to fix fault code 5
On my stanley brandon oil fired cooker as it says in book oven high switch opened
  • wcatherwood Jan 15, 2009
    would it be fault on a part on cooker as oven wasnt use very much
2 Suggested Answers
  • 401 Answers
SOURCE: I have a stanley brandon 80k oil range style cooker. The Hot water and oven work fine but the heating intermittently does not work when either set to come on via the timer or via pushing the override
Sounds like you have a valve sticking or a safety switch causing it to shut down. Does this unit exhaust first then the burner ignites that might be your issue
Posted on Jan 09, 2015
I have a stanley brandon 80k oil range style cooker. The Hot water and oven work fine but the heating intermittently does not work when either set to come on via the timer or via pushing the override...
Jan 09, 2015 | Ovens
The F5 error code?
WHIRLPOOL
Range/Stove Oven Fault Codes, Common Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective
Nov 03, 2007 | Whirlpool GBS307PR Electric Single Oven
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Bush AE66DCA cooker main oven wont come on
Hi guess you would have got your cooker fixed or replaced by now but I thought I would comment as we have had the same problem.
First I checked the bulb inside the cooker to see if there was a fault but the bulb was intact, I then checked the cooker over visually inspecting suspect broken parts I noticed the Thermosat control (3rd in from left hand side) wasn't turning properly so I ordered a new one. Couple days later it arrives and I remove the old switch and replace (very simple task) once the cooker is apart I get it all back together and it still doesn't work. So I grab my multi tester and perform a continuity test on the elements which proved to be normal range (43ohms was the reading). I was stumped. I began checking the whole cooker wiring and checking everywhere for a fault. After some time I notice a abnormality inside the main cooker control (2nd from the left hand side). Under closer inspection I realise one of the brass pins and spring has dislodged and no longer giving an electical connection. After ordering a new switch I stripped the old one and replace the pin and spring and rebuilt for a temporary fix. Rebuild the cooker and hey presto it works. Couple days later new switch arrives so I changed them over. Touch wood nothing else goes wrong but there's not much to them once they are apart.
Hope this helps others with their problem.
Feb 03, 2014 | Ovens
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Jul 31, 2011 | Stoves 720EF Electric Double Oven
I have a Bosch double oven. The upper oven works fine. The lower oven does not work at all. After turning on the oven, when I turn the thermostat, nothing happens, even the light is not on. Thanks
Hi there
i would first check that your timer is not set to auto if it is switch off cooker at mains wait 5 seconds then switch on and set time, if this is not the problem it sounds like the overheat cut-out located at the back of the oven cavity is at fault.
Ian.
Apr 16, 2011 | Ovens
Hi, The door of the oven of my kenmore cooker locked itself and the code 'F9' flashes alternatively with the code 'dr' can you please give me some help to fix this issue? Thanks
Hi, the F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Oct 08, 2010 | Kenmore 47732 / 47734 / 47739 Electric...
EG73 Hotpoint Oven heating when switched off
sounds just like hotpoint customer service "fob off"
your fault sounds more like the selector swich shorting out going by prev repairs i would isolate the cooker straight away and investigate.
ps. would not leave cooker powered up if not in use until fault repaired
Feb 28, 2008 | Ovens
Ovens Logo
125 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
