Question about Fuji FinePix E510 Digital Camera
Fuji finepix e510 won't turn on
The camera will not turn on. The batteries are new and good, the green light flashes on for a second and then goes off. Any ideas!!!
  • Anonymous Mar 07, 2009
    Camera will not turn on. Green light flashes on and off and the batteries are new. What is a possible solution???
  • 4 Answers
See my possible solution at the posting by kawbene of Jan, 18, 2009 which starts out "Fiji finepix e510 won't turn on... Good luck.
Posted on Jan 18, 2009
Camers will notturn on
What kind of batteries are you using?
Jun 07, 2008 | Fuji FinePix E510 Digital Camera
Kodak Easy Share zoom digital camera
Most problems of this symptoms indicates either:
1. Weak battery; or
2. Internal fault (which can either be hardware or software).
Initially, pls try removing the batteries for an hour or so hopefully doing a reset and will work from thereon.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 03, 2008 | Cameras
Green light goes on when I turn camera on, but 3 red lights flash when I shoot & nothing happens. I tried changing multiple batteries, all alkaline. No luck yet. Any ideas?
The 3 flashing red lights indicate low battery power! This could be because of low battery power (all 4 batteries must be good), the battery contacts in the camera are poor, the make of battery being used (try different make of battery)
Aug 05, 2015 | Fujifilm Instax MINI 7s Instant Film...
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
Kodak easyshare M893 IS will not stay on. The battery has been charged and replaced, however, when the camera is turned on the green light comes on, the "Kodak EasyShare" screen appears for a second or...
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Nov 23, 2009 | Kodak EasyShare M853 Digital Camera
When I take a picture with fully charged batteries, the recovery is very slow.
Some batteries such as alkaline use a chemical reaction to create energy, these batteries typically do not supply very much current.
Flash cycle time may be longer.
As far as common batteries go, Lithium would be the fastest, followed by NiMH.
If it's still slow, buy a new camera and or external flash ( is a good resource)
Jun 24, 2009 | Fuji FinePix E510 Digital Camera
Fuji FinePix E510 Digital Camera Logo
751 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
