Question about AT&T Lucent MLS-12D Phone
Phone goes to auto answer and I cannot get it out of that mode.
Display says to change battery with power on and I cannot find the battery. I have had the phone system (partner plus) for 17 years and have never dealt with this.
Thank you,
Mike Smith
    President:
  • AT&T Master
  • 860 Answers
Mike,
That message is displayed when the 2 aa batteries go dead on a partner ACS. The batteries are located on the "main" card on the bottom front below the plugs for the phones.It has a black slide bar that you push up to get the battery module out.Make sure you put the batteries in as shown on the module. Replace when finished. hope that helps.
Posted on Feb 10, 2009
How activate auto answer?
1 Press {AUTO ANSWER} repeatedly to display the following.
FAX ONLY MODE 3 RINGS
The display will show the ring setting in FAX ONLY mode.
The {AUTO ANSWER} light is ON.
2 If you wish to change the ring setting, press
{A} or {B} repeatedly to display the desired
setting, and press {SET}.
How faxes are received
When receiving calls, the unit will automatically
answer all calls and only receive fax documents.
Mar 08, 2012 | Panasonic KX-FL611 Plain Paper Laser Fax
Our HP 2140 fax under distinctive ring setting DRPD was answering under our Master ring (double Ring) until yesterday it switched inside somehow where it now answers regular phone ring instead of...
Was the fax plugged into another telephone line? Maybe a power surge?
My solution would be to reconfigure the fax from scratch to learn the ring pattern.
From the Manual:
Step 1-Teach the HP Fax the ring pattern
The HP Fax will learn the ring pattern when you call it from another telephone or fax
machine.
1. Be ready to call the fax machine.
2. Press Menu repeatedly until BASIC FAX displays and press OK.
3. Use LEFT ARROW - RIGHT ARROW BUTTONS to scroll through the options until DRPD Mode displays and press OK.
Call this fax from another fax machine... Waiting Ring...
will display.
4. Call the HP Fax.
DRPD OK will display when the pattern has been learned and the HP Fax will return
to Ready mode.
Step 2-Set up distinctive ring (DRPD) answer mode
Once you have activated distinctive ring, it becomes one of the answering modes you
can select by pressing the Mode/Contrast button.
Press Mode/Contrast repeatedly until DRPD Mode appears in the display.
• In Ready mode, DRPD appears in the right hand corner of the display.
• Now, the HP Fax will manage calls and faxes as if it were set to AUTO mode
(AUTO mode on page 28)
TIP: Distinctive ring must be set up again if you reassign your fax number
or connect the machine to another telephone line. Once set up again (that
is, the fax machine has learned the ring pattern and the answering mode is
correctly set), you should test the fax machine by calling the fax number
and another number on the same line. The machine should respond
appropriately to a call placed to the fax number with fax tones, and to a
normal telephone call with the expected ring pattern.
Mar 04, 2011 | HEWLETT-PACKARD HP 2140 Fax
My samsung tocco lite only rings 4 times and then goes to answer phone how do i solve this problem?
Your phone has been set to Auto Answer, to disable this, go to Call Settings and Select Answer mode and uncheck/disable the Auto Answer. Good luck.
May 18, 2010 | Samsung SYNC SGH-A707 Cellular Phone
THE CAMERA GOES DEAD VERY SOON WHEN IT TURNS ON. IT HAS GOOD BATTERIES.
Hi, I've scoured the 3 page manual and come up with this.:-
There is nothing wrong with your camera. The camera has a built-in power saving
feature that turns the camera off after 30 seconds of inactivity (default setting) to
conserve battery power. The auto off time setting can be changed in the set up menu.
Changing the Auto Off Time Setting:
1. Set the camera to Camera Mode.
2. Press the Menu button to display the main menu.
3. Press until the Setup is highlighted.
4. Press to enter the Setup submenu.
5. In the Setup menu, press to highlight “Auto Off Time”.
6. Press to enter “Auto Off Time”. Press to highlight the time you want.
7. Press the OK button to save your selection.
Hope this helps
Mar 05, 2010 | Concord Camera Eye-Q 4060AF Digital Camera
Hi who can I adjct to clock on th phone display, thanks
While the handset is still on the cradle press Program * # followed by the system password ( default is 1234). Now press 000 and then Sp-Phone.Enter the year and then scroll to the month with the right scroll key (located at the right bottom corner of the phone). To change the month use the AUTO ANS / MUTE button. Now scroll right again and change the date and day. To change the day again use the AUTO ANS / MUTE button. Now scroll right again and the time will appear. Set the time. To change am/pm scroll to it and again use the AUTO ANS / MUTE button. Press program to exit program mode and your done.
Please rate this answer if it was helpfull.
Thank you.
Oct 21, 2009 | Panasonic KX-T7730 Corded Phone
Cordless BT Equinox 1200 phone won't hold charge and auto answers
Replace the battery. They don't last forever. Make sure it's not something stupid like the phone is being left on. Go into the menu and change the auto answer settings.
Jun 30, 2009 | Lands Phones
Speaker phone indicator will not go off
Liooks like you have the phone programmed to "Handsfree answerback" this will cause the handsfree light to flash continiously.
In this mode the phone will auto answer any internal call from another extension.... so watch out.
To switch this mode off press the program button above the displey & you be given th option to switch "Auto Answer off " I think it's the first option, try it.
Jan 07, 2009 | Inter-Tel Encore Phone
How do you set the time and date?
Step 1.
Press the PROGRAM button, then press * * 1 2 3 4
The display should now read: USR-PGM NO?
Step 2.
Enter: 0 0 0
Display: Day/Time Set
Step 3.
Press NEXT (or the SPKR PHN button)
Display: shows date (if you need to change the date, see steps 5 thru. 10 below)
Step 4.
Press NEXT (or the SPKR PHN button) again
Display: shows time example: 12:00 AM
Step 5.
Enter the hour
to change current entry, press CLEAR (or the TRANSFER button)
Step 6.
Press --> (or FWD/DND button)
Step 7.
Enter the minutes
Step 8.
Step 9.
Press SEL (or AUTO ANSWER/MUTE button) to change AM or PM
Step 10.
Press STORE (or AUTO DIAL/STORE) - Don’t forget this step!
Step 11.
Press END (or HOLD button)
Step 12.
Press SPKR PHN button or pick up and hang up the phone to leave programming mode.
Dec 20, 2008 | Panasonic KX-T7731 Corded Phone
Problem with display of Nokia 6600 mobile
my nokia6600 occurs same problem
when i switch off and then switch on the phone then display comes for the time i am using the phone. As i left the phone for sometime without pressing any key it again goes to that white screen mode..but phone is functioning .plz help me to rectify the problem.....
Jul 14, 2008 | Nokia 6600
AT&T Lucent MLS-12D Phone Logo
141 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
