Question about Stoves Monessen Variable Thermostat Controlled Forced Air Blower Heater
CFM HEF33 Electric Fireplace
When I run the heater on the fireplace there is no problem. Once I turn on the flames the heater will shut off after 2 cycles. I am running the fireplace on it own outlet. How can I solve this problem
  • kanata Jan 23, 2009
    We also have the HEF33 Electric Fireplace. After running for only a short while, it stops working and the reset button pops out. When we press the reset button back in, the fireplace will start again for a short while.
  • carol edrington Jan 12, 2013
    we have the HEF26 and do not know where the reset button is, any suggestions
4 Suggested Answers
SOURCE: My Heater stopped working on my HEF33 Electric fireplace
We have had this same problem with our heater. But I went online to find out where I could purchase replacement parts. The company that sold the fireplace went out of business. I also went on-line to try and fine a universal replacement part. So far no help to be found.
Posted on Dec 12, 2009
  • 2888 Answers
SOURCE: I have a monessen vent-free
take a tube blow out pilot jet when off or use can of air should work
Posted on Nov 12, 2010
  • 77 Answers
SOURCE: Fireplace starts right up but as soon as the flame
Sound like it could be flame sensor. This sensor is a rod hooked to a wire where the flame would hit it. Sometimes the sensor gets a coat of film on it. If it is this can clean with dollar bill. Other possibilities is if this is direct vent fireplace (sealed door) could be not getting enough combustion air, but if this just started doing this I wouldn't think it would be lack of combustion enless pipe got plugged somehow.
Posted on Jan 18, 2011
How do you change a bulb in a Febo flame electric fire place
FEBO Flame Electric Fireplace - YouTube
? 2:12
www.youtube.com/watch?v=o5A-QowBVbs
Nov 24, 2014 - Uploaded by Phatkat Allure De ****
FEBO Flame Electric Fireplace. ... I love my electric fireplace, more of a focal piece it is really pretty. Read more ...
How to Change a Light Bulb in your Electric Fireplace
Nov 07, 2015 | Heating & Cooling
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
The heat on my Pyromaster HEF33 Electric Fireplace is not working
This unit was made by Monessen Hearth Systems. The original heater/fan part has been discontinued; however, there is a new part that is compatible with your fireplace. You will need to search for part#10006404 Fan/Heater.
Nov 30, 2012 | Leisure HOMEPRIDE Electric Fireplace...
HEF33 flame not turning over, power OK and heater working, all lights on. Flame speed at stop and will not move.
i have pyromaster hef33. flames on my stop moveing also. i took off front glass and logs. then i got a long metal tool and.then i tap the moter that moves the rod that makes the flames move.and also i move the rod back and forth alittle bit. i did put just bit 3in one oil on both ends of the rod. so far its doing better now . this may help some one or it not. i thank the moter or rod was sticking
Jan 02, 2010 | Leisure HOMEPRIDE Electric Fireplace...
My electric fireplace model # HEF33WDG, the heat works, but the flames dont move. Can someone help me.
go to ebay and put in electric fireplace heater parts, the flame motor is around 20 bucks, and the heater element around 50 bucks Good luck
Oct 21, 2009 | Leisure HOMEPRIDE Electric Fireplace...
I have a pyromaster electric fireplace hef33 we have replace battery in transmitter and sometimes when can turn the unit on and off then it just stops working (transmitter)
The number provided by wilson524 is incorrect. To reach Hankscraft please call 608-524-4341. We are happy to assist you.
Thank you,
Hankscraft Inc.
Sep 29, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Gas fireplace will not stay lit
there is a probe that is in the one of the flame... This once heated builds up enough pressure do to the heat to keep the shut/off valve open... (reason, if the flame went out the gas would continue to flow) this "thermocouple is replaceable !! contact me at homeprohandyman@verizon.net
Feb 22, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Flame on my electric Pyromaster is standing still is there a bulb
basically, on the bottom of the fireplace, there are 2 screws on the sides, 3 on the back, take them off, lift bottom (it wont come off, so be careful not to bend it) there are 3 christmas light type bulbs, you can find them at any hardware store. Just replace them. Problem solved.
If the flame is standing still, i assume the motor is burnt out. or the belt is off.
Nov 20, 2008 | Leisure HOMEPRIDE Electric Fireplace...
My Heater stopped working on my HEF33 Electric fireplace. My fireplace is only 3 years old not sure what to do.
Nov 18, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Elec. fireplace on switch
I found a website that has many of these parts. Try ibuyfireplaceparts.com.
Nov 02, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
965 people viewed this question
Top Stoves Heating & Cooling Experts
Paul Carew
ghold1
Level 1 Expert
vance jones
Are you a Stoves Heating and Cooling Expert? Answer questions, earn points and help others
