Question about Pool & Spa
No Heat from Spa
Bret Aquiline spa: Replaced Heater Element, New Pressure switch,
Two Heater contactors (buzzing), Heater Relay, and GFCI switch..
Everything runs as it should hi/low. Indicator switch on console lights
up ( +clicks) when calling for heat. There is No Heat, and the Heater
Light ( replaced new neon light; directly connects to the heater element), does not light. (Didn't check voltage at heater, but suspect its not getting power ?
Everything seems to run great, but no Heat. Can I jump the two wires together, that go directly into the pressure swith ( and bypass that switch) to see if I get heat: and can I do the same with the 2 wires going to the hi heat limit switch to bypass that to see if I get heat. HELP !
  • Anonymous Mar 16, 2014
    As per the above question, I have a balboa spa heater that keeps tripping. will run when the copper wires to the heater are disconnected. I have bought and replaced the heater element, but it is still doing it. What else could it be with the heater. cheers
  • Anonymous Mar 19, 2014
    I have a phoenix spa it set empty for 6 months we moved it and now I can't get the heater to come on to heat it up the element tests good but I can't get 220 to it only 110 to each side and don't no what to do
    Problem Solver:
  • 5 Answers
Heater contactors "buzzing": Do you mean normal buzzing or extra loud buzzing? Loud buzzing or chattering can be caused by low voltage to a contactor. If normal sounds, then probably the relays on the contactors is working, but the contacts may be stuck, or burned enough so as not to make contact. First, get a voltmeter and check for 240 volts AC at the heater contactor terminals. If the voltage is low, most likely you need to check the contactors further. Check for dirty contacts, clean if needed. If the contacts are not moving when energized, then you will probably need to replace one or both of the contactors.
Posted on Jan 18, 2009
Reflections Spa will not heat
Take a Multimeter and measure the voltage at the heater element. If it is getting voltage either 120v or 240v depending on the voltage to the spa, you've got a bad heating element
Dec 31, 2013 | Pool & Spa
Hotsprings Prodigy Spa
Assuming there aren't any other faulty electrical components your GFCI will trip as a result of the heater element short circuiting.
Typically this happens when water infiltrates the heater element's protective outer coating and comes in contact with the internal heating coil. The culprit could be corrosion but usually it is a pin sized hole in the element which will lead to a short circuit.
When this happens the element has failed and cannot be repaired it must be replaced.
Feb 17, 2012 | Pool & Spa
I have an older Catalina spa with acura controls. The tub will no longer heat up. The pump cycles but the heater and light does not come on
These older style controls are easily repaired but require some electrical diagnosis expertise to determine the problem.
1. Check the pressure switch to make sure it is working properly - Use a continuity checker to see if the pressure switch is closed when pump is running. If not then check for proper water flow. Dirty filter, obstruction in plumbing. If flow is good, replace the pressure switch and see if heater works.
2. Check to see if the heater has 220V at the heater terminals when heater circuit is running. If not, then check to see if the heater contactor (relay) is actuating. Check Hi-limit switch, Thermostat and pressure switch for continuity. If heater has voltage, check for current draw, using a clamp style amp meter around on of the heater wires. look for about 20 amps. If voltage is present but no current draw, the heater is bad.
3. The spa light is a completely separate circuit, check the air switch, air line, button and light bulb. Its a 12V AC circuit.
Feb 09, 2010 | RTO Pump Volute, Acura, Maverick,No IMP
Pool & Spa Logo
592 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
