Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Konica is constantly on display
I had a C-3451 error message followed the reset instruction . now the display just shows Konica logo and key pad irresponsive
  • bizwork May 11, 2010
    It could be fuser unit first, then check the ICPs on PWB MC or a fuse on the power supply may have blown.
  • 210 Answers
You have to do a NVRAM reset, this is the only way to get rid of this. Call a tech, it's not so easy and you'll need a special software to accomplish that.
Posted on Aug 23, 2009
    Sergeant:
  • 210 Answers
You need to call for service to konica. Reason your machine need the lates firmware to correct the problem. You need to download the firmware to a konica secured site only available for certified trained technician and required user id and a password to access. I wish we could help you, but at this point this not do it yourself.
Posted on Aug 11, 2009
    Problem Solver:
  • 9 Answers
You need to have a firmware upgrade on your copier.
Posted on Jun 20, 2009
My Bizhub C252 Konica Minolta is getting error C-3451? How can I fix it ?
Error c3451 is a warm up error meaning the machine has not yet reached the correct temperature within a specific time. To Reset switch machine off using the switch inside the front door, not the one on the control panel. While holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen. Tap that, OK will be displayed then turn off the machine and then turn it back on. This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing
Jun 28, 2017 | Konica Minolta Office Equipment & Supplies
I have a proplem in konica minolta bizhub c352 how to sort the problem i have an error code 3451
If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day. ENSURE YOU WAIT THE 10 SECONDS
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Jun 15, 2016 | Konica Minolta bizhub Office Equipment &...
Bizhub c352 error 3451
Error code 3541
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Dec 27, 2013 | Konica Minolta bizhub C250 All-In-One...
How do i fix error code C-3502 on a konica minolta bizhub500 photocopier
C 3502 - fusing high temperature abnormality.Check the fuser unit electrical components,wires,thermistors,thermofuses,heater lamps.To reset the error code turn OFF the copier.Press and keep pressed the function key and turn ON the copier.Keep pressed the function key until Trouble reset message appaire on display.Release the function key ,touch the message and turn Off and ON the copier.
Dec 27, 2013 | Konica Minolta bizhub C450P Laser Printer
C dc00 konica minolta c351
CDCXX-trouble related to security.Try to reset:
Turn OFF the copier.Press and keep pressed the Utility key and turn ON the copier.Keep pressed the utility key and wait to Trouble reset message appaire on the display.(1-2 minutes.).Release the utility key and touch the message.Turn OFF the copier,wait 1 minutes and turn ON.If the error code displayed call the technical rep. from Konica Minolta.
Apr 06, 2013 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta biz hub c550 error code c-EEE3 Help please
To reset the malfunction code press follow keys:
Turn OFF the copier,press and hold pressed the Utility key and turn ON the copier.Wait will apaire the Trouble reset message on the display and release the Utility key.Touch the message and turn OFF the copier.Wait 1 minutes and turn ON.Good luck.
Mar 21, 2013 | Konica Minolta Office Equipment & Supplies
I get a code c3451
C 3451 and C 3452 Fusing warm up malfuntion.Verify the fuser unit and clean the thermistors and the thermofuses and try reset the error code.For reset press following keys:
Utility - Meter count - Details - Stop - 0- Stop - 0 - 1
introduction 0-0-0-0-0-0-0-0 press enter and select the trouble reset(counter windows).
Feb 14, 2013 | Konica Minolta bizhub 250 All-In-One Laser...
Minolta bizhub c 351 code c 3451
this error code means the fuser rollers failed to heat up you can reset the code by turning the machine off and hold down the utility\counter key while you turn the machine onwhen the trouble reset button shows on the touchscreen touch it and when it says ok turn the machine off then back on if the machine gives this erro again you will have to have the fuser replaced
Nov 19, 2009 | Konica Minolta bizhub C351 All-In-One...
I have a error code F34 on a Konica Copier can anyone help
Description:
How to clear fuser abnormality codes (F34, F35, F36).
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Mar 11, 2009 | Konica Minolta DiALTA Di200 Copier
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
280 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
