Question about DEI Python 1400XP Remote Start/Keyless Entry System
Intermittent arm/disarm of Python model 560XV
Alarm is on '98 ford ranger. my son worked for circuit city and installed himself years ago. I added auto door locks months back and they worked fine. lately the alarm will not arm/disarm - doesn't appear to be remote - have two and problem persists with both - is there a possibility there is a loose ground wire?
thanks
  • 1 more comment
  • eargle4 Jan 20, 2009
    Doin12volt,
    Thank you for the assistance. It apparently was a bad connection where the antenna plugged into the main unit. All is functioning well now.
  • Anonymous Mar 23, 2014
    I have a Python 990 on my 2008 ford F250. One FOB works fine but not the other. When this happened before, the FOB needed to be resynchronized to the truck. I do not remember how to do this and can't find it in the manual. How do I do this?
    When I arm or disarm the alarm the siren no longer chirps to confirm.
    Sergeant:
  • 233 Answers
This "could" be a bad ground, however, usually when these units lose ground, they activate the siren at a really low level, because they are trying to ground through the siren.
I would say to check where the antenna plugs into the main unit,(brain) but honestly, in 17 years of dealing with DEI alarms, 99.9% of these problems are due to the transmitter - it may blink the LED like it is supposed to, but that doesnt gaurantee it is sending a signal. I would recommend buying a new transmitter and programing it to the brain.
Posted on Jan 15, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Can I add an alarm to my Python 571 XP?
you will need to install another system; a generic alarm/keyless entry system is cheap ; and, easy to install you can find one on ebay
Feb 18, 2013 | Vehicle Parts & Accessories
Car alarm goes off 30 seconds after disarm and open a door
Apparently the alarm is set to passive arming and, once you disarm it, it immediately begins the arming process and it is not registering the door being open. I'm going to go out on a limb and say that the alarm door trigger is wired to the dome light and the dome light is turned off; an issue that occurs with GM vehicles that have a dome light override switch. What's the year, make and model of the vehicle?
Sep 02, 2012 | AviStart 4400 2-Way Security / Remote...
My son is at college & lost his key FOB for his truck. The Python security system won't let him start it after campus & city police came by & unlocked it for him. He will be finished with...
First, locate the valet switch. After locating the valet switch, turn igniton on, press and release the valet switch one time. The alarm will disarm allowing him to start the vehicle.
May 02, 2011 | 426P 460HP Security System - 426P
Have a mazda 6 GS 2010. When I use the starter in the street, I have no problem. When I park in my drive-way and use the starter, it rings. Why?
I cannot tell you why the factory alarm is triggering at one place and not the other but I can tell you that the remote starter is not disarming the factory alarm.
In order to disarm the factory alarm, the remote starter must supply a ground pulse to the disarm wire at the body control module (BCM). The BCM is located in the driver side kick panel and the wire is black in pin "L." To arm the factory alarm, the same wire needs a ground pulse through a 1k ohm resistor.
I have not installed the 1401, so I am not sure if that particular unit has outputs for factory arm and disarm, most DEI products do have at least a disarm wire that is light green/black. This wire outputs a negative pulse that should disarm the alarm without the addition of relays. If 1401 is equipped with a alarm rearm wire it would most likely be green/white. This wire also outputs a negative pulse but it will not be sufficient in rearming through a 1k ohm resistor without a relay. The relay terminal would be wired as follows if the 1401 is capable of this feature:
30 = vehicle black wire (solder in 1k ohm resistor)
87 = chassis ground
87a = no connection
85 = green/white wire of 1401
86 = 12v constant (fused - 5A is more than enough)
Nov 09, 2010 | 1401 Remote Start/Keyless Entry System
I have a Python alarm system installed in my service van less than a year ago and it was fine until a couple a days ago.nowwhen I activate the alarm every 35 minutes or so the alarm goes off Ive checked...
You LIKELY have electrical leakage in the door switches. Check these with an ohmeter on a high range. Check your wiring as well.
Electronic devices are sensitive to small leakage currents not detected by usual testers.
You MIGHT alksoi check your main battery connections in the vehicle. These can become intermittent and when you start the car you burn off the oxidatioon and they are good for a bit.
Jul 02, 2010 | 426P 460HP Security System - 426P
Ford factory alarm arm output and disarm output
I don't show this truck as having a factory alarm, is there maybe an aftermarket alarm in it
Dec 28, 2009 | Code-Alarm Code Alarm Transponder
How can I disarm the anti-theft alarm on my 2004 Ford Fiesta
If you are talking about the factory alarm, that is disabled simply by turning the ignition key to the run position.
If this instead is a third party alarm , then it will have a valet override button sowmehere under the dash.
Nov 25, 2009 | Accessories Alarm Siren
Python 990 isnt locking or unlocking my doors .
Its going to be either the wires going to the locks or the programming in the alarm. The only way to tell is to get the wiring tested. A plug could have just pulled out also. Do many variances for one straight answer.
Jun 04, 2009 | DEI Python 990 2-Way Security...
Security light always on, alarm won't chirp, not working
Do you have a toggle switch or button in the system ? If you do put the ignition key in the ON postion and switch toggle in opposite direction. It might now be in the VALET mode
Mar 26, 2009 | DEI Python 1400XP Remote Start/Keyless...
Circuit City installed Python 1400XP on my 2002 Suburban.
That does not sound intierly tru but what is the year ,make and model of your car and i can check for you. but if memory seves me right it just consists of alot of extra work that most tech's dont like to do.
Nov 14, 2008 | DEI Python 1400XP Remote Start/Keyless...
Open Questions:
See all DEI Python 1400XP Remote Start/Keyless Entry Questions
DEI Python 1400XP Remote Start/Keyless Entry System Logo
424 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
